I upgraded my openhab to v3, but after the upgrade all items are uninitialised. I can see my bindings under the settings tab, but when adding items the binding list is empty.
I can also see my zwave controller being uninitialised.
I tried to remove 1 item to add it again - but it gets stuck in “removing” state.
Found a way to solve it. I installed a new random binding and that did the trick.I tried deleting the cache first, restarts, etc. Nothing worked, but the new binding install triggered something… and suddenly it all worked.
Same thing just happened to me. I’ve been on OH3.5 for a while now, installed some minor updates, rebooted and all my bindings were gone. I installed a random binding and everything popped back online.
Man this is a life saver comment. The same just happened to me and installing a new binding brought everything back online. Not sure if this is a known bug, but saved a lot of work. Thanks…
I just encountered a similar thing. I’m running version 3.3 currently and saw some open updates. I decided to update these from the config tool. After I did this I also executed option 10 to install the improvemnet and ironically the console output reported back something like “because it can’t hurt you”.
Similar to @gualcosta I had the scare off my life after only half of my configuration not returning. openhab log reported initially:
] [core.karaf.internal.FeatureInstaller] - Some .kar files are not installed yet. Delaying add-on installation by 15s. that didn’t look too promising at first glance:
After rebooting once again, the jar problems disappeared, but now I noticed that all my items came online first and they were even persisted with historical values. But then they then mysteriously disappeared again within a minute and I found log entries like:
2022-10-31 20:11:03.540 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Stopped HABPanel
2022-10-31 20:11:05.144 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'astro:sun:local' changed from ONLINE to UNINITIALIZED
2022-10-31 20:11:05.154 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'astro:sun:local' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2022-10-31 20:11:05.375 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'enphase:inverter:121842042748:055727' changed from ONLINE to UNINITIALIZED
2022-10-31 20:11:05.670 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2022-10-31 20:11:05.398 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'enphase:inverter:121842042748:055727' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2022-10-31 20:11:05.399 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'enphase:inverter:121842042748:065526' changed from ONLINE to UNINITIALIZED
2022-10-31 20:15:03.212 [INFO ] [openhab.core.model.script.DSMR.rules] - Gasmetervalue: 2486.151 ㎥
2022-10-31 20:15:03.214 [WARN ] [nce.extensions.PersistenceExtensions] - There is no queryable persistence service registered with the id 'rrd4j'
Then I found this thread. I first made the mistake to install a binding that was already part of my config, but unused. the installation timed out and I decided to try something more exotic. The binding was installed succesfully, but it needed another reboot to get everything back to working mode.
