All Paper-UI copied Things are marked as file in PaperUI
  • Platform information:
    • Hardware: CPUArchitecture/RAM/storage RASPI 3B+
    • OS: what OS is used and which version Openhabian-Image
    • Java Runtime Environment: _which java platform is used and what version_Standard
    • openHAB version:4.3.0 Release Build
  • Issue of the topic: please be detailed explaining your issue
  • Copied Generic MQTT - Thing. Is afterwards noct changeable - Error Message ‘Created as file’. Bur there was never a file in the things directory and there ist still no one existing. Attempt to delete via select also failes with the same issue.
  • Any propsal recommended that helps removing the Things or delete it.
    • Items configuration related to the issue
    • Sitemap configuration related to the issue
    • Rules code related to the issue
    • Services configuration related to the issue
  • If logs where generated please post these here using code fences:
Try upgrading to 4.3.2, I think it’s fixed there.
Also, you’ll need to delete the copied / duplicated Thing manually in the jsondb. AFAIK there’s no other way.
Thanks for the quick Info. Helps a lot, but will take time - upgrading always includes the risk that things don’t work anymore and therefore requires some preparation work.
Have in between arrived at another issue. Can not create more generic thiings for the Zigbee2mqtt Broker - have 3 working and two non-editable ones which may count as well. Trying to add a 6th one ends after the create button without any error message or hint, but thing is not created.
Is that probably another facette of the same issue and repaired with the upgrade or a different Problem ?
Kind regards
