On Openhab 2 we had, the posibility, on the control menu, to see all the things that we had, with their items, to see their status and control them.
Is there also a direct posibility in Openhab 3? I can’t find it
The control menu was a failed attempt at what has become the Main UI. If you model your items using the semantic model then they appear under those tabs at the bottom of the overview screen, in groups by properties, location, etc.
So if I have created then using text files, they won’t appear?
If the text files have groups & tags following the semantic model they will appear just like they were modeled through the UI. You cannot use the UI to model text file-based Items though.
