In the PaperUI, I have a volume control thing that is accessed via W200Hangar_Volume, and that’s great and all, but I’d really like to do something like this:
If you give the AllPlay Thing a user-friendly name, you could use this one. On PpaerUI you can set the Default Audiosink from a list, this list contains all AudioSinks (using the thing name).
Sorry, it is not only the given name that is required, you need the use use the string that is displayed 2 lines under the thing name on the PaperUI thing list.
I’m using Sonos with a given name of PlayBuero and the needed string is sonos:PLAY1:PlayBuero
