Hi All,
Alexa works just fine using a rule/dummy switch item with tag “Switchable” to voice control the air conditioner.
However, taking it further to send voice temperature commands seems a bit tricky, especially if you have 5 preset temps you’d like or multiple fan speed adjustments.
It works by creating a dummy item for every single temperature and then creating this rule. In the Alexa App, I create a routine to Switch this item on/off. And that changes the temperature. The voice trigger command
"Alexa, change the temp to eighteen"
gets the job done, although not overly elegant
Is there a better, more streamlined way? I have Fan speed and Temp controls.
Rule:
// Aircon to 18 degrees via Alexa Dummy Item
rule "Aircon Alexa to 18 degrees"
Item Aircon_18 received command
switch (receivedCommand)
case ON: Aircon.sendCommand("Temp18")
ITEMS:
String Heater "Heater [MAP(en.map):%s]" { channel="broadlink:rm3:78-0f-77-18-43-03:command" }
String Aircon "Aircon [MAP(en.map):%s]" { channel="broadlink:rm3:78-0f-77-5a-cb-fa:command" }
String TV "TV" { channel="broadlink:rm3:78-0f-77-18-43-03:command" }
Dimmer TV_Alexa "TV" [ "Switchable" ] // Dummy Item for Alexa as it doesnt understand Strings
Dimmer Heater_Alexa "Heater" [ "Switchable" ] // Dummy Item for Alexa as it doesnt understand Strings
Switch Aircon_Alexa "Aircon" [ "Switchable" ] // Dummy Item for Alexa as it doesnt understand Strings
Switch Aircon_18 "Temp18" [ "Switchable" ] // Dummy Item for Setting the Aircon to 18 degrees
Thank you
