I am always getting the following error when I acces the REST API:
{"schemaValidationMessages":[{"level":"error","message":"Can't read from file http://rpi3.karnsfamily.org/rest/swagger.json"}]}
Is this a known bug?
Did you try adding the openHAB port?
http://rpi3.karnsfamily.org:8080/rest/swagger.json
I have port 8080 accesses forwarded to port 80, but I get the same result when I access port 8080. I get this:
I have searched for the file swagger.json under /var/lib/openhab2, but it is nowhere to be found.
that is correct
