here’s my rule, you can see ive added a couple of sendMails to help with debugging. I always get the first mail, never the second, and the rule doesn’t trigger.
Item Powermax_zone6_status changed to ON
{sendMail("colin@.com", "zone 6 triggered", "zone 6 triggered")}
if (NightTime.state == ON && Light_GF_Hall_Lamp.state == OFF)
{sendMail("colin@.com", "zone 6 triggered step 2", "zone 6 triggered step2 ")
sendCommand(Light_GF_Hall_Lamp, ON)
Thread::sleep(200000)
sendCommand(Light_GF_Hall_Lamp, OFF)
Curly braces are a way to define a context. One is not required to define a new context around a single line of code and they are certainly not required to call an action. So at best the curly braces are unnecessary and at worse they could be causing problems if the Rules interpreter is not expecting them to be there.
In addition to curly braces, indentation is also used to visually indicated context. So the code that is in the curly braces that are part of your if statement should all be indented and all indented at the same level.
This is not functional but it really really makes it easier to read the code (kind of like when they decided to put spaces between words in medieval Latin).
