I’ve been trying to set up Amanda so that I can automate backups. I’m using a NAS drive to achieve this which I’ve mounted under /mnt folder and that is all working OK. I then used the openHabian configuration tool to install the Amanda backup as per the instructions. All went well until I got to running
amcheck openhab-dir
This gave the output of
Amanda Tape Server Host Check
ERROR: directory ‘/mnt/SynologyBackups/OpenHabBackup/slots’ does not exist
NOTE: host info dir /var/lib/amanda/openhab-dir/curinfo/openHABianPi does not exist
NOTE: it will be created on the next run.
NOTE: index dir /var/lib/amanda/openhab-dir/index/openHABianPi does not exist
Server check took 1.853 secondsAmanda Backup Client Hosts Check
ERROR: openHABianPi: [/etc (/etc/amanda-security.conf) is not owned by root]
Client check: 1 host checked in 5.139 seconds. 2 problems found.(brought to you by Amanda 3.3.9)
I fixed the
by changing the permissions to allow user “backup” to get access. This resulted in the output becoming
slot 1: contains an empty volume
Will write label ‘openHABian-openhab-dir-001’ to new volume in slot 1.
NOTE: skipping tape-writable test
Server check took 1.452 secondsAmanda Backup Client Hosts Check
Client check: 1 host checked in 5.121 seconds. 2 problems found.(brought to you by Amanda 3.3.9)
When I look at the file /etc/amanda-security.conf I get the following
-rw-r–r-- 1 root root 1986 Jan 24 2017 amanda-security.conf
so the file is owned by root. However the permissions for the /etc folder are
drwxr-xr-x 100 openhabian openhabian 4096 Jun 12 14:00 etc
so /etc is owned by openhabian. I assume that this is where my problem lies. Can I change the ownership of /etc to root or is that going to mess up the rest of the system ?
Tim
