- Platform information:
- Hardware: Raspberry Pi 3 Model B Plus Rev 1.3
- OS: Raspbian GNU/Linux 10 (buster)
- Java Runtime Environment: openjdk version “11.0.10” 2021-01-19 LTS
- openHAB version: 3.0.1
- Issue of the topic:
I installed openhab yesterday from an image : openhabian-pi-raspios32-v1.6.3.img.xz
I have a new 64 GB SD card
I have attached an external USB 512GB Hard Disk
I did setup SD mirroring successfully (well I did not try a recovery yet) on said external disk. => Option 53 of openHabian Configuration Tool
It created a mount point /storage that I want to use to install Amanda System Backup to with Option 52 but it fails to complete.
It looks like a type with the “//” but I have no idea how to fix it.
Thanks for any help
It all works well until here :
$ chmod 644 /etc/systemd/system//amdump-openhab-dir.*
chmod: cannot access '/etc/systemd/system//amdump-openhab-dir.*': No such file or directory
Full log here :
openhabian@openhabian:/etc/systemd/system $ sudo openhabian-config
2021-02-16_15:50:11_CET [openHABian] Checking for root privileges... OK
2021-02-16_15:50:12_CET [openHABian] Disabling IPv6...
$ sysctl --load
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
OK
2021-02-16_15:50:12_CET [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2021-02-16_15:50:12_CET [openHABian] openHABian configuration tool version: [main]v1.6.3-1202(7a02c12)
2021-02-16_15:50:12_CET [openHABian] Checking for changes in origin branch HEAD... OK
2021-02-16_15:50:13_CET [openHABian] Switching to branch HEAD... OK
2021-02-16_15:50:18_CET [openHABian] Updating Linux package information... OK
2021-02-16_15:50:23_CET [openHABian] Beginning setup of the Amanda backup system... OK
2021-02-16_15:50:24_CET [openHABian] Configuring Amanda backup system prerequisites... 2021-02-16_15:50:30_CET [openHABian] Configuring Amanda backup system prerequisites...
$ chpasswd
$ usermod --append --groups backup openhabian
$ usermod --append --groups backup backup
$ chsh --shell /bin/bash backup
OK
2021-02-16_15:50:43_CET [openHABian] Creating Amanda filesystem...
$ mkdir -p /etc/amanda/openhab-dir /var/lib/amanda/openhab-dir/curinfo /var/log/amanda/openhab-dir /var/lib/amanda/openhab-dir/index
$ touch /etc/amanda/openhab-dir/tapelist
$ chown --recursive backup:backup /var/backups/.amandahosts /etc/amanda/openhab-dir /var/lib/amanda/openhab-dir/curinfo /var/lib/amanda/openhab-dir/index /var/log/amanda
$ chown --recursive backup:backup /storage/amandaBackup
$ chmod --recursive g+rxw /storage/amandaBackup
$ mkdir -p /storage/amandaBackup/slots
$ chown --recursive backup:backup /storage/amandaBackup/slots
$ ln -sf /storage/amandaBackup/slots /storage/amandaBackup/slots/drive0
$ ln -sf /storage/amandaBackup/slots /storage/amandaBackup/slots/drive1
$ chmod 644 /etc/amanda/openhab-dir/amanda.conf
OK
2021-02-16_15:50:43_CET [openHABian] Creating Amanda configuration...
$ rm -f /etc/amanda/openhab-dir/disklist
$ chmod 644 /etc/amanda/openhab-dir/disklist /etc/amanda/openhab-dir/amanda-client.conf
OK
2021-02-16_15:50:45_CET [openHABian] Preparing storage location...
$ mkdir -p /storage/amandaBackup/slots/slot15
$ chown --recursive backup:backup /storage/amandaBackup/slots/slot15
$ mkdir -p /storage/amandaBackup/slots/slot14
$ chown --recursive backup:backup /storage/amandaBackup/slots/slot14
$ mkdir -p /storage/amandaBackup/slots/slot13
$ chown --recursive backup:backup /storage/amandaBackup/slots/slot13
$ mkdir -p /storage/amandaBackup/slots/slot12
$ chown --recursive backup:backup /storage/amandaBackup/slots/slot12
$ mkdir -p /storage/amandaBackup/slots/slot11
$ chown --recursive backup:backup /storage/amandaBackup/slots/slot11
$ mkdir -p /storage/amandaBackup/slots/slot10
$ chown --recursive backup:backup /storage/amandaBackup/slots/slot10
$ mkdir -p /storage/amandaBackup/slots/slot9
$ chown --recursive backup:backup /storage/amandaBackup/slots/slot9
$ mkdir -p /storage/amandaBackup/slots/slot8
$ chown --recursive backup:backup /storage/amandaBackup/slots/slot8
$ mkdir -p /storage/amandaBackup/slots/slot7
$ chown --recursive backup:backup /storage/amandaBackup/slots/slot7
$ mkdir -p /storage/amandaBackup/slots/slot6
$ chown --recursive backup:backup /storage/amandaBackup/slots/slot6
$ mkdir -p /storage/amandaBackup/slots/slot5
$ chown --recursive backup:backup /storage/amandaBackup/slots/slot5
$ mkdir -p /storage/amandaBackup/slots/slot4
$ chown --recursive backup:backup /storage/amandaBackup/slots/slot4
$ mkdir -p /storage/amandaBackup/slots/slot3
$ chown --recursive backup:backup /storage/amandaBackup/slots/slot3
$ mkdir -p /storage/amandaBackup/slots/slot2
$ chown --recursive backup:backup /storage/amandaBackup/slots/slot2
OK
FAILED (permissions)
2021-02-16_15:50:49_CET [openHABian] Checking for default openHABian username:password combination... OK
2021-02-16_15:50:49_CET [openHABian] We hope you got what you came for! See you again soon ;)
