I have problem with restore image of full sd card from Amanda.
I’m running OH3 on RPI4. There is Amanda backup of full card. Backup is performed on NAS server based on RPI4 and OMV. Backups seems ok - every day there are new files with archives in the NAS folder.
My intetntion was to create new sd card with OH (without any things, items etc) to use it only in case of problems (lets name it as OH-clean). I wanted to use this card to write backup on the second ssd card.
The problem is that I can’t restore backup.
Please see outputs from OH-clean: amadmin
[19:21:19] backup@openhabian:/etc$ amadmin openhab-dir find openhabianpi /dev/mmcblk0 /var/lib/openhab
Argument ‘openhabianpi’ matches neither a host nor a disk.
Argument ‘/dev/mmcblk0’ matches neither a host nor a disk.
Argument ‘/var/lib/openhab’ matches neither a host nor a disk.
Argument ‘/var/lib/openhab’ matches neither a host nor a disk.No dump to list
and from amtape
[19:30:36] backup@openhabian:/etc$ amtape openhab-dir show
scanning all 15 slots in changer:
slot 1: date 20210516005529 label openHABian-openhab-dir-014 (label do not match labelstr)
slot 2: date 20210426010133 label openHABian-openhab-dir-015 (label do not match labelstr)
slot 3: date 20210427005925 label openHABian-openhab-dir-016 (label do not match labelstr)
slot 4: date 20210428005548 label openHABian-openhab-dir-017 (label do not match labelstr)
slot 5: date 20210429005935 label openHABian-openhab-dir-018 (label do not match labelstr)
slot 6: date 20210430005647 label openHABian-openhab-dir-019 (label do not match labelstr)
slot 7: date 20210501010103 label openHABian-openhab-dir-020 (label do not match labelstr)
slot 8: date 20210508092210 label openHABian-openhab-dir-021 (label do not match labelstr)
slot 9: date 20210509005907 label openHABian-openhab-dir-022 (label do not match labelstr)
slot 10: date 20210510005705 label openHABian-openhab-dir-023 (label do not match labelstr)
slot 11: date 20210511010332 label openHABian-openhab-dir-024 (label do not match labelstr)
slot 12: date 20210512010017 label openHABian-openhab-dir-025 (label do not match labelstr)
slot 13: date 20210513005744 label openHABian-openhab-dir-026 (label do not match labelstr)
slot 14: date 20210514010236 label openHABian-openhab-dir-027 (label do not match labelstr)
slot 15: date 20210515010329 label openHABian-openhab-dir-028 (label do not match labelstr)
and output from main OH main server
amadmin
[19:22:28] backup@openhab:/home/openhabian$ amadmin openhab-dir find openhabian pi /dev/mmcblk0 /var/lib/openhab
amtape
[19:22:33] backup@openhab:/home/openhabian$ amtape openhab-dir show
