Hallo.
I’m using the OH3 with a raspi as openhabian.
After the OH3 set up completely fresh, the amazon echo control binding became to be unable to find the channels(e.g. power state) from a smart home device detected and registered by the binding.
when I used OH2, it could be detected and controlled as an item in the PaperUI.
Now I’m using the MainUI with OH3 to configure the binding and items so on.
I don’t use a textual configuration, all configuration is set with the MainUI.
Does anyone have a solution to this problem?
I already tried restarting the platform and re-installing the binding.
P.S I can find channels and can register the items of other than the smart home device(e.g. Amazon Account or echo device) in the MainUI.
I have this issue since updating to OH3. I can still access the channels i.e. ‘PowerState’ via VS code and API but can’t create OH Equipment as there’s no channels on the AmazonEchoControl things.
