I am not sure if it is a problem with Alexa or myopenhab.org. But it seems that the cloud connection would work. I was using openhab2 in the actual version. I changed something inside my items and rules file and after that I can not detect all (the needed) items.
What I have done was to unininstall the Cloud Connector Service, also the Amazon Echo Control Binding (but I think it was not used to the detect the items), restarted openHAB multiple times, delete all devices which could be found by amazon and searched multiple times for new items. I also changed the system state of these items and inside the Alexa App I deactivated and reactivated the openHAB Skill multiple times, agreed the oAuth access inside myopenhab and so on. Everything does not work.
The following is the example code for the missing items:
Switch iKonferenz_Amazon_EchoDot_Befehl_Morgenroutine "Befehl Morgen-Routine" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
Switch iKonferenz_Amazon_EchoDot_Befehl_Ausgangszustand "Befehl Ausgangszustand" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
Switch iKonferenz_Amazon_EchoDot_Befehl_Wecker "Befehl Wecker" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
Switch iKonferenz_Amazon_EchoDot_Befehl_BadLicht "Befehl Badlicht" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
Switch iKonferenz_Amazon_EchoDot_Befehl_MultimediaLichtBlau "Befehl MultimedialichtBlau" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
Switch iKonferenz_Amazon_EchoDot_Befehl_Gefrierschrank "Befehl Gefrierschrank" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
Switch iKonferenz_Amazon_EchoDot_Befehl_LinkinPark "Befehl LinkinPark" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
Switch iKonferenz_Amazon_EchoDot_Befehl_Verstecken "Befehl Verstecken" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
Switch iKonferenz_Amazon_EchoDot_Befehl_GutenMorgen "Befehl GutenMorgen" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
Switch iKonferenz_Amazon_EchoDot_Befehl_GuteNacht "Befehl GuteNacht" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
Switch iKonferenz_Amazon_EchoDot_Befehl_Party "Befehl Party" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
Switch iKonferenz_Amazon_EchoDot_Befehl_Luefter "Befehl Lüfter" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
Switch iKonferenz_Amazon_EchoDot_Befehl_KuechenLicht "Befehl Kuechenlicht" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
Switch iKonferenz_Amazon_EchoDot_Befehl_MultimediaLicht "Befehl Multimedialicht" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
Switch iKonferenz_Amazon_EchoDot_Befehl_IoTLicht "Befehl Iotlicht" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
Switch iKonferenz_Amazon_EchoDot_Befehl_Saugroboter "Befehl Saugroboter" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
Switch iKonferenz_Amazon_EchoDot_Befehl_Meeting "Befehl Meeting" <switch> (gKonferenz_Amazon_EchoDot_Befehl) ["Switchable"] {alexa="Switchable"}
So as you can see I tried it as first with ["Switchable"]
and later with {alexa="Switchable"}
. The first one I have used before upgrading openHAB but after upgrading openHAB Alexa also worked fine. I just changed a few of this items, then the new one aren`t detected so I deleted all the devices and searched for all devices. After that the other items disappeared.
Under https://myopenhab.org/rest/items/ I can find as example:
2377
link "https://myopenhab.org/rest/items/iApplikation_Alexa_MultimediaLichtBlau"
name "iApplikation_Alexa_MultimediaLichtBlau"
2620
link "https://myopenhab.org/rest/items/iApplikation_Alexa_GutenMorgen"
name "iApplikation_Alexa_GutenMorgen"
2934
link "https://myopenhab.org/re…pplikation_Alexa_Luefter"
name "iApplikation_Alexa_Luefter"
2960
link "https://myopenhab.org/rest/items/iApplikation_Alexa_Meeting"
name "iApplikation_Alexa_Meeting"
So it should be found. In general, the Alexa app only shows me all the lamps. Not a single other item is recognized, and there would definitely have to be others in addition to those that I would like to have.
Since I have uninstalled everything and reinstalled addons, several times the usual tips have gone through, I do not know what to do. That was last week already a cramp to get this to work at all.
Hope one can help me. Thanks in advance.
