- Platform information:
- Hardware: QNAP 469
- OS: Linux
- Java 8 something
- openHAB version: 2.5.6
- Issue of the topic: please be detailed explaining your issue
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
I was able to setup alex connection and the necessary definition in openhab
Dimmer Esszimmer_Licht_Level "Licht Esszimmer Helligkeit" {channel="amazonechocontrol:smartHomeDevice:ab2297d4:0d5268d3-1905-4f66-af3a-dffc158c7abb:brightness"}
Switch Esszimmer_Licht "Licht Esszimmer" {channel="amazonechocontrol:smartHomeDevice:ab2297d4:0d5268d3-1905-4f66-af3a-dffc158c7abb:powerState"}
I have connected via enet skill some Jung Enet Dimmers to Alexa (via INSTA - that is written somwhere)
I also can dimm the light - but there is no feedback
sometimes i put the slider to e.g. 30% - but i remains at 0% even if the light is shining
when changing the value via e.g. the JUNG Enet - I can see the result in the Alexa App - but even after minutes not in the openhab sitemap …
Is there any chance to syncronize ??
