A lag of 3-6 seconds (normally) is what I see - it takes some time for the DB to power-up and to ask for a DHCP address (which is what the script checks for). That should be the minimum for any solution that relies of intercepting the network traffic.
On the restart issue: no idea, I never had that problem - the solution is rock-solid for months here.
def arp_display(pkt):
if pkt.haslayer(DHCP):
print (pkt[Ether].src)
for index in range(len(dash_mac)):
if pkt[Ether].src == dash_mac[index]: #die MAC Adresse des Button mit Kleinbuchstaben!
You need to go through the setup for the Dash button through the Amazon app in order to set up the Wi-Fi on the button. You don’t need to associate a product - just set up the Wi-Fi. You can then go to your router’s configuration dialogs to find that button’s IP and in turn int corresponding MAC. This is the MAC address you need.
In my case (OH 2.4 stable on Raspberry Pi 3), just renaming the thing differently (e.g. change between uppercase and lower case) in Paper UI sets it back online. No need to delete things.
after updating my system it suddendly crashed and I had to start from the beginning. now I have a problem concerning this old threat.
2 amazon DashButtons are woking … 2 other ones not
this is the not working one:
it´s not switching the item
019-12-25 15:04:11.245 [ome.event.ItemCommandEvent] - Item 'DashDecke' received command ON
2019-12-25 15:04:11.249 [nt.ItemStatePredictedEvent] - DashDecke predicted to become NULL
the working one is this:
2019-12-25 14:58:48.841 [ome.event.ItemCommandEvent] - Item 'Schrank_Kueche1' received command OFF
2019-12-25 14:58:48.867 [vent.ItemStateChangedEvent] - Dashfinish changed from ON to OFF
2019-12-25 14:58:48.873 [vent.ItemStateChangedEvent] - Schrank_Kueche1 changed from ON to OFF
i have found the solution:
in paperui there is a a function in things.
the thing must be configured with the auto update funktion “enforce an auto update”
