Is there any way of finding out which Echo device triggered a rule?
I would like to have a simple “lights on” routine on Alexa, and the device which received the command be known to openHAB so the appropriate lights can be switched.
I can’t find anything in the Alexa events or properites which has this information.
lastvoicecommand should at least help you find out df the last command to an echo was about lights. Maybe you can use „received update“ on an item linked to that channel and check if the command was „lights on“?
