I have been using the Amazon Echo Binding from version 3 on and it always worked but just a few days ago it stopped working. I am always on the latest OH version as I am using docker (very easy migration). It keeps responding “CONFIGURATION_PENDING Please login in through servlet: …”. When I try to do that it returns an error even though I am using correct credentials. Something must have changed.
i have the same issue, bridge and echo things all offline. tried to login with correct credentials but giving me “Login to ‘amazon.com’ failed: Could not register as app. Try again”
Hello All. My more that THANKS belongs special to @digitaldan and also to @lsiepel
You have more than my recpect, that the binding is working again like a charme.
The experiance, after serveral weeks now offline, and now, doing only a update from 5.02 to the 5.03, is such high, which I have never expected.
I have nothing different than, as an classic update from 5.02 to 5.03 and everything works,
OK, I have had to manual install the webhock binding, but this is fine.
So I never had with OH such of a positive experiance after a binding was not more working as it should be.
