Grabber66
(Christoph)
February 8, 2019, 11:25pm
#1
I’m using the Amazon Echo Control Binding with the .item .thing and .sitemap like in the tutorial.
My Problem is that i want to connect bluetooth with a rule. But it doesn’t work.
I think the “EXECUTION_BLOCK” is wrong, but i don’t know what to do.
rule “ALEXA_Bluetooth”
Item Steckdose_01 received update ON
Echo_Living_Room_Bluetooth.sendCommand(ON)
Can anyone help me please…
I believe your When statement is incorrect. It should just be received update, this triggers the rule upon any change even if the change is the same, if you are only looking to have this rule run when it ‘changed from OFF to ON’ then you need to change things around.
H102
(CM6.5 H102)
February 9, 2019, 2:31pm
#3
As @anonymous.one mentioned you may need to change the when part.
Example:
Item Steckdose_01 changed from OFF to ON
or just use from OFF b/c it has only two states.
