Amazon Echo Control Binding gets uninistalled
  • Platform information: Raspberry Pi Nano
    • Hardware: Raspberry Pi Nano
    • OS: Rasbian image from openHABian
    • Java Runtime Environment:Zulu Embedded OpenJDK Java 8
    • openHAB version: 2
  • Issue of the topic: I have two Raspberry Pis running the same config. On one instance the Amazon Echo Control Binding randomly becomes not installed. This seems to be related to some kind of security feature (CAPTCHA?) but I’m note sure. When I reinstall it sometimes works right away, other times I have to reenter passwords and make sure the /amazonechocontrol/ page loads. How can I keep this binding installed?
    • Items configuration related to the issue
  • Sitemap configuration related to the issue n/a
  • Rules code related to the issue
  • Services configuration related to the issue
    hue Binding
  • If logs where generated please post these here using code fences:
I also have the Alexa binding and the need to reenter my password occurs every few weeks. As this is a known issue, I’m sure there will be a resolution soon. You can follow the progress and see what others are are doing to fix here: https://community.openhab.org/t/released-openhab2-amazon-echo-control-binding-controlling-alexa-from-openhab2/37844?u=h102
