- Platform information:
- openHAB version: Docker 2.3
- Issue of the topic: I want to use my amazon echo as tts device. It works fine with plain text but not with SSML (I used the example config from the documentation). It reads out the text including the tags. I tried to wrap it as json object but this is also interpreted as plain text.
Same here. Plain text works like a charm, but if I insert and around the text alexa won’t speak anymore. Running version 2.5 of Amazon Echo Control
Hi, I had the same problem with my echo show 8.
SSML not working, plain text works fine.
After turning off “Do not disturb” (“Bitte nicht stören”) in the settings of the device everything works as expected.
