I can’t tell from the closed threads on the subject if I should be able to get this to work or not, but I’m having no luck in any event.
Web Socket close 1005. Reason: null
This drives a number of automations for us - so I’m trying to decide if I need to code for a work-around by having items in Alexa instead of just recognized phrases.
@NCO I am not sure when it was introduced, but in 3.2M3 on the bindings tab, you now have an option of installing bindings from the distribution or from the marketplace. You will see the Echo Control binding in both locations. Install from the marketplace.
I am on 3.2.0.M4 using the binding from the openHAB Distribution. Everything is working but the lastVoiceCommand. My understanding from reading above is that this version should be working?
