So I just setup openHAB for the first time using PaperUI. Discovered a bunch of Z-wave devices and configured everything for Amazon Echo. I see that in order for Alexa to Discover the Items, Items must have Tags in the .items files. Well, since everything was setup using PaperUI, there are no .Items files. So my questions are
Is there a way to add tags through PaperUI or HABAdmin?
If not, is there a way to generate .item files from Items setup in PaperUI?
I don’t see a way to add the tag through PaperUI. If you need to add the tag for alexa, I think for now the only way it to configure will be via items file manually.
All the manually config files are located in /etc/openhab2.
I had the same issue.
Thought about the same process at first, but then I decided to duplicate the items I want in an alexa.items file.
I have the physical items (light switch, etc) and also ‘virtual’ (named macro below) that triggers spefice rules for Alexa Voice commands
Bonjour Aymeric,
I have the same problem to control paper UI based items with Alexa but I am not sure to understand your solution.
Are your Alex.items only virtual items and are you mapping them to the real ones through a dedicated rule for each of them?
