@binderth
I had the problem that the binding didn’t connect today too. I finally uninstalled and reinstalled the binding and after that it worked again.
Hmmm. I switched from the Smarthome/J to the “normal” binding and back today.
Still same outcome… what country are you in and to what URL were your binding connected?
url is https://eu-api-alexa.amazon.com
location is Germany
I use the smarthomej-version.
You cleaned the cache too?
Yes, I did clean it in between. Hmmmmm. Seems like an amazon issue at first. Or they changed some procedures in the API.
well, I had to clean after changing the url. It didn’t work before. And had to un- and reinstall the binding.
Amazon seems quite busy changing things. Time to find another speech command solution… But my next one will be without cloud.
Ive tried it all and have this issue
Im running OH 5.0.1 stable. Ive recreated the thing many times, cleared the cache and restared
The error I get is:
Login to ‘amazon.com’ failed: Could not register as app.
Try again
Any suggestions?
