Amazon Echo SmartJ Binding Last Voice Command not working anymore
Friday or Saturday :slight_smile: It’s already merged, I just need to do the release.
In our short email conversation we found out how to filter it, right?
I was just wondering if I can do the filtering myself via a rule or if that needs to be done in the bindings code. (Not a programmer/developer, so please excuse it if the question is stupid)
I donā€˜t think you have access to the necessary information in a rule. Yes, your logs were very helpful.
Alright thank you for the quick response and clarifying that it can not be done by rule. Will be patiently waiting then.
I there,
the lastVoiceCommand does not work again…
I use the following version of the binding:
316 │ Active │ 80 │ 4.1.0.202311121746 │ SmartHome/J Add-ons :: Bundles :: Amazon Echo Control Binding
with OpenHAB 4.1 M4
Has something changed again?
@J-N-K
Just do this:
update org.smarthomej.binding.amazonechocontrol https://download.smarthomej.org/org.smarthomej.binding.amazonechocontrol-4.1.0-SNAPSHOT.jar
@J-N-K Do you know, when you will find time to release the new version?
this has worked! thank you!
For OH4 I have already released 4.0.2 which contains all the fixes. For 4.1 the fixes are included in the latest snapshot, but I can’t do a release before the OH 4.1 release. Artifacts on Maven Central can’t depend on non-release artifacts.
When I download the snapshot over https://download.smarthomej.org/addons-beta.json which leads to https://download.smarthomej.org/org.smarthomej.binding.amazonechocontrol-4.1.0-SNAPSHOT.kar, I get the version is from the 12th of November. That version has the bug with LastVoiceCommand. The update (https://download.smarthomej.org/org.smarthomej.binding.amazonechocontrol-4.1.0-SNAPSHOT.jar) from the 27th November is working very well.
So I think, it would be great, if you provide the actual version as a snapshot via https://download.smarthomej.org/addons-beta.json
Of course a ā€œrealā€ release for 4.1 can not be present before 4.1 is released. I like working snapshots much more, than not working release builds. :wink:
Will the 4.1 version include the filtering that only the device that was actually spoken to will be updated?
(Maybe a stupid question but when is the release of 4.1?)
The openHAB version? No. The SmartHome/J version? Yes. Please don’t use the addons-beta.json. Use addons.json for release-versions (3.2 / 4.0 at the moment) and addons-snapshot.json for the latest openHAB-version that is not release (4.1 at the moment). Once openHAB 4.1 is release, I’ll also release version 4.1 and you can switch to addons.json.
Hi @J-N-K thank you for the response, this means I can update to the latest version at addons-snapshot.json and it will be the version where only the spoken to device updates? Or did I missunderstood it just now?
Exactly
I am currently on 4.0.2 and used this command to update:
Now I got the following error:
2023-12-15 17:28:25.344 [ERROR] [Events.Framework                    ] - FrameworkEvent ERROR
org.osgi.framework.BundleException: Could not resolve module: org.smarthomej.binding.amazonechocontrol [300]
  Unresolved requirement: Import-Package: org.smarthomej.commons; version="[4.1.0,4.2.0)"
	at org.eclipse.osgi.container.Module.start(Module.java:463) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer.update(ModuleContainer.java:419) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.storage.Storage.update(Storage.java:969) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.storage.Storage.update(Storage.java:935) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.update(EquinoxBundle.java:490) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.apache.karaf.bundle.command.Update.update(Update.java:74) ~[?:?]
	at org.apache.karaf.bundle.command.Update.doExecute(Update.java:51) ~[?:?]
	at org.apache.karaf.bundle.command.BundleCommand.execute(BundleCommand.java:49) ~[?:?]
	at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:84) ~[?:?]
	at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:68) ~[?:?]
	at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:86) ~[?:?]
	at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:599) ~[?:?]
	at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:526) ~[?:?]
	at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:415) ~[?:?]
	at org.apache.felix.gogo.runtime.Pipe.doCall(Pipe.java:416) ~[?:?]
	at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:229) ~[?:?]
	at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:59) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
	at java.lang.Thread.run(Thread.java:833) ~[?:?]
Do I need to update my OpenHab before I can use this version I updated too?
Don’t use karaf commands if you don’t know what you do. Uninstall the binding from UI (that should work) and then re-install from UI. You tried adding a 4.1 version of the binding to a 4.0 openHAB release. That’ll not work. There is a 4.0.2 version of the binding which is the same as the 4.1.0-SNAPSHOT, just for openHAB 4.0.x.
Just to confirm, I’m running OH 4.0.4 and I can run 4.1.0-SNAPSHOT of your binding?
Best, Jay
No, run version 4.0.2 of the binding (from the 3rd Party store). Always install addons.json (and only that) for releases of openHAB. Disable ā€œshow incompatible addonsā€. Install what you see in the addon store.
It’s same code, just compiled for 4.0.x instead of 4.1.x.
That is the important sentence! I used the beta and so I always were not on the lastest version. The first small look with my test system is good. I’ll test it in my productive environment in the next days.
Thanks for the hint. :+1:
Short status:
  • The last version in my 4.1M5 productive environment runs like clockwork. :grinning:
  • 4.1RC1 in test environment also looks very good.
Many thanks for that.
