Hi all, I’m getting crazy with the fact that in PaperUI or Sitemap I cannot update light switch status for all the SmartHome Devices imported via echocontrol Bindings.
All Items works if I send a command from OH PaperUI or Sitemap.
If I send a command via Alexa or from the real world bu manually toggling the switch, I cannot see any update on OH and not even any log of the event.
All items are lights belonghing to LivingNow and are imported to openhab with the following “travel”:
Legrand to Alexa --> Legrand Skill
Alexa to OH --> Alexa echocontrol Binding
I tried with and without item tagging and with autoupdate= true or false and nothing helped.
I really do not know what to try further. The only thing that seems to work is to use a command refresh but this is a workaround with several drawbacks and rules implication.
Thanks very much ! I was really getting mad.
I’m a beginner with OH so could you link me to find the right way to test 2.5.11-SNAPSHOT ?
May be it is sufficent to rename the old jar and replace with the new one but I’m confident there is the right post with a how to
I have installed the new 2.5.11-SNAPSHOT openhab> bundle:list -s | grep echo 274 x Active x 80 x 2.5.11.202011260340 x org.openhab.binding.amazonechocontrol
New SNAPSHOT works fine … it takes a bit for updating but WORKS ! Thanks for the assistance.
