Yes, I’m aware of that.
the problem is that in the case of a squeezebox audio sink, the polly service is creating an mp3 file and telling squeezebox to play it from http://:8080/audio, which is a non existing location:
HTTP ERROR 404
Problem accessing /audio/90348251-8077-4ca5-bd13-b3c343bc1c3f.mp3. Reason:
Not Found
Powered by Jetty://
I am still using it in a snapshot, not the latest though - Its about 3 weeks old. And I had no issues at all running it on 2.1 stable.
However, I’m about to upgrade to latest snapshot the upcoming days, so I guess with your experience @kubawolanin , I’ll have to find another voice service. Maybe go back to voicerss, or find out if google works.
With my pull request the code review was extensive requiring numerous changes. I started to work on them but got stalled with the 2.2 version bump. I tried to up grade to 2.2 but the logger wasn’t working. If it’s ready I can upgrade and check out the polly service. No sure how developers work on the new release and the next version at the same time. Have versions working on different computers?
Yes the voice service should work under 2.1 as it’s working under my current configuration. The 2.0 and 2.1 versions are not compatible. Version 2.0 should work on openhab 2.0 and 2.1. Version 2.1 only works on openhab 2.1.
I just updated the development environment to master (current snapshot). There is a problem. I need to update the log functions since the snapshot is using a different logger.
I just updated my installation, using the update script in runtime/bin, and I get these error on the polly service;
13:19:05.810 [INFO ] [.voicerss.internal.VoiceRSSTTSService] - Using VoiceRSS cache folder /home/micke/oh/userdata/voicerss/cache
13:19:06.138 [INFO ] [e.core.internal.i18n.I18nProviderImpl] - Locale set to sv_SE, Location set to null, Time zone set to Europe/Brussels
13:19:07.215 [WARN ] [fig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/config/config.xml' in module 'org.openhab.voice.pollytts' could not be parsed: The URI 'null' in node 'config-description' is invalid! : null
---- Debugging information ----
message : The URI 'null' in node 'config-description' is invalid!
cause-exception : java.lang.NullPointerException
cause-message : null
class : org.eclipse.smarthome.config.core.ConfigDescription
required-type : org.eclipse.smarthome.config.core.ConfigDescription
converter-type : org.eclipse.smarthome.config.xml.ConfigDescriptionConverter
path : /config-descriptions/config-description
line number : 8
class[1] : java.util.ArrayList
converter-type[1] : com.thoughtworks.xstream.converters.collections.CollectionConverter
version : 1.4.7
com.thoughtworks.xstream.converters.ConversionException: The URI 'null' in node 'config-description' is invalid! : null
line number : 8
version : 1.4.7
at org.eclipse.smarthome.config.xml.ConfigDescriptionConverter.unmarshal(ConfigDescriptionConverter.java:71) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:72) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at com.thoughtworks.xstream.core.AbstractReferenceUnmarshaller.convert(AbstractReferenceUnmarshaller.java:65) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:66) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:50) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at com.thoughtworks.xstream.converters.collections.AbstractCollectionConverter.readItem(AbstractCollectionConverter.java:71) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at com.thoughtworks.xstream.converters.collections.CollectionConverter.addCurrentElementToCollection(CollectionConverter.java:98) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at com.thoughtworks.xstream.converters.collections.CollectionConverter.populateCollection(CollectionConverter.java:91) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at com.thoughtworks.xstream.converters.collections.CollectionConverter.populateCollection(CollectionConverter.java:85) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at com.thoughtworks.xstream.converters.collections.CollectionConverter.unmarshal(CollectionConverter.java:80) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:134) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:32) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1185) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1169) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1115) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1062) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at org.eclipse.smarthome.config.xml.util.XmlDocumentReader.readFromXML(XmlDocumentReader.java:87) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.parseDocuments(XmlDocumentBundleTracker.java:349) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.processBundle(XmlDocumentBundleTracker.java:336) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker.access$3(XmlDocumentBundleTracker.java:331) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at org.eclipse.smarthome.config.xml.osgi.XmlDocumentBundleTracker$2.run(XmlDocumentBundleTracker.java:307) [108:org.eclipse.smarthome.config.xml:0.9.0.201712011551]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Caused by: java.lang.NullPointerException
at java.net.URI$Parser.parse(URI.java:3042) ~[?:?]
at java.net.URI.<init>(URI.java:588) ~[?:?]
at org.eclipse.smarthome.config.xml.ConfigDescriptionConverter.unmarshal(ConfigDescriptionConverter.java:69) ~[?:?]
... 31 more
First of all, thanks for maintaining the PollyTTS integration with OpenHAB!
I was running a rather old version of your binding (org.openhab.voice.pollytts-2.1.0-SNAPSHOT-20170615.jar). I decided to upgrade to your latest release (org.openhab.voice.pollytts-2.2.0-SNAPSHOT.jar 06-Dec-2017 19:58).
After putting the JAR file in the /addons folder, I get the error messages below.
I run a OH 2.3 snapshot (build #1173). I cleared my cache and tmp folders and restarted OH, but that did not work either.
Is there anything else I can try?
2018-01-08 17:18:02.644 [ERROR] [org.openhab.voice.pollytts ] - [org.openhab.pollytts(246)] The activate method has thrown an exception
at org.openhab.voice.pollytts.internal.PollyTTSService.modified(PollyTTSService.java:78) [235:org.openhab.voice.pollytts:2.2.0.201712061958]
at org.openhab.voice.pollytts.internal.PollyTTSService.activate(PollyTTSService.java:63) [235:org.openhab.voice.pollytts:2.2.0.201712061958]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:298) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [42:org.apache.felix.scr:2.0.12]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619) [?:?]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:915) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [42:org.apache.felix.scr:2.0.12]
at org.apache.felix.utils.extender.AbstractExtender.addingBundle(AbstractExtender.java:187) [42:org.apache.felix.scr:2.0.12]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156) [?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:470) [?:?]
at org.eclipse.osgi.container.ModuleContainer.start(ModuleContainer.java:736) [?:?]
at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:727) [?:?]
at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:497) [?:?]
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:443) [?:?]
at org.eclipse.osgi.container.ModuleContainer.refresh(ModuleContainer.java:987) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1368) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2018-01-08 17:18:02.653 [WARN ] [org.openhab.voice.pollytts ] - FrameworkEvent WARNING - org.openhab.voice.pollytts
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) [?:?]
The problem seems to be happening in the actuation methods.
Try using the paperui and check your parameters under
configuration > services > voice > polltTTS > expert Mode
The audioFormat field has changed to “disable” to “default”
