Is it possible to run the AVS on the same Pi as the OH2 Webserver?
Is it harmless or should I set Alexa up on my ZeroW?
Thanks in advantage!
Not sure i understand what you want to achieve, did you read this:
https://docs.openhab.org/addons/ios/alexa-skill/readme.html
and this:
https://docs.openhab.org/addons/ios/hueemulation/readme.html
What are you missing that cannot be done through the above?
Hey,
I’m not quite sure if it makes a difference running the Voice Service on the Pi.
I don’t have an echo or other amazon alexa devices.
You can install the Voice service from Amazon.developers and run it a Device.
My Goal is to run the AVS on the same as Openhabian, but Im not sure if this will work…
