Hi, my binding has been working flawlesly for a month or so, but suddenly it started to appear password errors in my log. I’ve followed the instructions in the log and tried to log from:
Login failed: Login fails. Check your credentials and try to login with your webbrowser to http(s)://<youropenhab:yourport>/amazonechocontrol/account1
I get the Alexa login page, but with a captcha!!. If I put my password and the correct captcha, I get this other message:
Password must match the configured password of your thing. Change your configuration or retype your password.
Try again
I’ve also enable debug for the module, and I can see in the log that the answer that the binding gets also has the captcha. These lines are captured from my log
<div id="auth-warning-message-box" class="a-box a-alert a-alert-warning auth-server-side-message-box a-spacing-base"><div class="a-box-inner a-alert-container"><h4 class="a-alert-heading">Important Message!</h4><div class="a-alert-content">
<ul class="a-unordered-list a-nostyle a-vertical" role="alert">
<li><span class="a-list-item">
To better protect your account, please re-enter your password and then enter the characters as they are shown in the image below.
</span></li>
</ul>
</div></div></div>
