Hello Openhab-Community,
I am currently changing all my scripts from Openhab2 to Openhab3 and renewing them. Now I’m stuck with my alarm system and would be grateful for your help!
I have a number of Alexa Echos in the house that should trigger a “PlayAlarmSound” when a burglar alarm is triggered.
I have triggered before the items with the following rule …
sendCommand(Echo_OG_Gaestezimmer_PlayAlarmSound, 'ECHO:system_alerts_atonal_02') Thread::sleep(500) sendCommand(Echo_EG_Wohnzimmer_PlayAlarmSound, 'ECHO:system_alerts_atonal_02') Thread::sleep(500) sendCommand(Echo_OG_Schlafzimmer_PlayAlarmSound, 'ECHO:system_alerts_atonal_02')
In my new script, I use the same command …
sendCommand(Alexa_Wohnzimmer_Show_PlayAlarmSound, 'ECHO:system_alerts_atonal_02')
No alarm sounds appear …
The log entries give no informations where the problem could be …
2022-10-18 21:47:20.162 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘Alexa_Wohnzimmer_Show_PlayAlarmSound’ received command
2022-10-18 21:47:20.163 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘Alexa_Wohnzimmer_Show_PlayAlarmSound’ predicted to become
2022-10-18 21:47:20.163 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Alexa_Wohnzimmer_Show_PlayAlarmSound’ changed from ECHO:system_alerts_atonal_02 to
2022-10-18 21:47:20.907 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Alexa_Wohnzimmer_Show_NextAlarm’ changed from 2022-10-19T21:47:06.048+0000 to UNDEF
On the item the change was successful but the alexa not respond with any sound …
Even when I try to change the sound directly in the openhab UI no change happens.
I have tried this appearance on two alexas now with the same behavior. Do you please have any idea how can I solve the problem?
Thanks for your help
