a few days ago I suddenly saw thousands of those error log entries:
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:215) ~[?:?]
... 15 more
2021-10-31 14:42:29.870 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-10-31 14:42:29.979 [WARN ] [mazonechocontrol.internal.Connection] - Parsing json failed:
<!doctype html><html class="a-no-js a-touch a-mobile" data-19ax5a9jf="mongoose">
<head>
<script type='text/javascript'>var ue_t0=ue_t0||+new Date();</script>
window.ue_ihb = (window.ue_ihb || window.ueinit || 0) + 1;
if (window.ue_ihb === 1) {
var ue_csm = window,
ue_hob = +new Date();
(function(d){var e=d.ue=d.ue||{},f=Date.now||function(){return+new Date};e.d=function(b){return f()-(b?0:d.ue_t0)};e.stub=function(b,a){if(!b[a]){var c=[];b[a]=function(){c.push([c.slice.call(arguments),e.d(),d.ue_id])};b[a].replay=function(b){for(var a;a=c.shift();)b(a[0],a[1],a[2])};b[a].isStub=1}};e.exec=function(b,a){return function(){try{return b.apply(this,arguments)}catch(c){ueLogError(c,{attribution:a||"undefined",logLevel:"WARN"})}}}})(ue_csm);
var ue_err_chan = 'jserr-rw';
(function(d,e){function h(f,b){if(!(a.ec>a.mxe)&&f){a.ter.push(f);b=b||{};var c=f.logLevel||b.logLevel;c&&c!==k&&c!==m&&c!==n&&c!==p||a.ec++;c&&c!=k||a.ecf++;b.pageURL=""+(e.location?e.location.href:"");b.logLevel=c;b.attribution=f.attribution||b.attribution;a.erl.push({ex:f,info:b})}}function l(a,b,c,e,g){d.ueLogError({m:a,f:b,l:c,c:""+e,err:g,fromOnError:1,args:arguments},g?{attribution:g.attribution,logLevel:g.logLevel}:void 0);return!1}var k="FATAL",m="ERROR",n="WARN",p="DOWNGRADED",a={ec:0,ecf:0,
pec:0,ts:0,erl:[],ter:[],mxe:50,startTimer:function(){a.ts++;setInterval(function(){d.ue&&a.pec<a.ec&&d.uex("at");a.pec=a.ec},1E4)}};l.skipTrace=1;h.skipTrace=1;h.isStub=1;d.ueLogError=h;d.ue_err=a;e.onerror=l})(ue_csm,window);
var ue_id = 'S26KCFWPYX5YKK8MHA3V',
ue_url = '/ap/uedata',
ue_navtiming = 1,
ue_mid = 'A1PA6795UKMFR9',
ue_sid = '258-2961822-3372164',
ue_sn = 'www.amazon.de',
ue_furl = 'fls-eu.amazon.com',
ue_surl = 'https://unagi-eu.amazon.com/1/events/com.amazon.csm.nexusclient.prod',
ue_int = 0,
ue_fcsn = 1,
ue_urt = 3,
ue_rpl_ns = 'cel-rpl',
ue_ddq = 1,
ue_fpf = '//fls-eu.amazon.com/1/batch/1/OP/A1PA6795UKMFR9:258-2961822-3372164:S26KCFWPYX5YKK8MHA3V$uedata=s:',
ue_sbuimp = 1,
ue_cel_lclia = 1,
ue_ibft = 0,
ue_fnt = 0,
ue_swi = 1;
var ue_viz=function(){(function(b,e,a){function k(c){if(b.ue.viz.length<p&&!l){var a=c.type;c=c.originalEvent;/^focus./.test(a)&&c&&(c.toElement||c.fromElement||c.relatedTarget)||(a=e[m]||("blur"==a||"focusout"==a?"hidden":"visible"),b.ue.viz.push(a+":"+(+new Date-b.ue.t0)),"visible"==a&&(b.ue.isl&&q("at"),l=1))}}for(var l=0,q=b.uex,f,g,m,n=["","webkit","o","ms","moz"],d=0,p=20,h=0;h<n.length&&!d;h++)if(a=n[h],f=(a?a+"H":"h")+"idden",d="boolean"==typeof e[f])g=a+"visibilitychange",m=(a?a+"V":"v")+
"isibilityState";k({});d&&e.addEventListener(g,k,0);b.ue&&d&&(b.ue.pageViz={event:g,propHid:f})})(ue_csm,ue_csm.document,ue_csm.window)};
(function(d,k,K){function G(a){return a&&a.replace&&a.replace(/^\s+|\s+$/g,"")}function q(a){return"undefined"===typeof a}function C(a,b){for(var c in b)b[t](c)&&(a[c]=b[c])}function L(a){try{var b=K.cookie.match(RegExp("(^| )"+a+"=([^;]+)"));if(b)return b[2].trim()}catch(c){}}function M(n,b,c){var e=(x||{}).type;if("device"!==c||2!==e&&1!==e)n&&(d.ue_id=a.id=a.rid=n,y=y.replace(/((.*?:){2})(\w+)/,function(a,b){return b+n})),b&&(y=y.replace(/(.*?:)(\w|-)+/,function(a,c){return c+b}),d.ue_sid=b),c&&
a.tag("page-source:"+c),d.ue_fpf=y}function O(){var a={};return function(b){b&&(a[b]=1);b=[];for(var c in a)a[t](c)&&b.push(c);return b}}function u(d,b,c,e){if(0<v&&0<=(aa||[]).indexOf(d)&&!b){for(var g=z.now(),k=0;z.now()-g<v;)k++;a.tag("marker-delayed:"+d)}e=e||+new z;var w;if(b||q(c)){if(d)for(w in g=b?h("t",b)||h("t",b,{}):a.t,g[d]=e,c)c[t](w)&&h(w,b,c[w]);return e}}function h(d,b,c){var e=b&&b!=a.id?a.sc[b]:a;e||(e=a.sc[b]={});"id"===d&&c&&(P=1);return e[d]=c||e[d]}function Q(d,b,c,e,g){c="on"+
c;var h=b[c];"function"===typeof h?d&&(a.h[d]=h):h=function(){};b[c]=function(a){g?(e(a),h(a)):(h(a),e(a))};b[c]&&(b[c].isUeh=1)}function R(n,b,c,e){function r(b,c){var d=[b],e=0,f={},g,k;c?(d.push("m=1"),f[c]=1):f=a.sc;for(k in f)if(f[t](k)){var r=h("wb",k),l=h("t",k)||{},p=h("t0",k)||a.t0,m;if(c||2==r){r=r?e++:"";d.push("sc"+r+"="+k);for(m in l)q(l[m])||null===l[m]||d.push(m+r+"="+(l[m]-p));d.push("t"+r+"="+l[n]);if(h("ctb",k)||h("wb",k))g=1}}!v&&g&&d.push("ctb=1");return d.join("&")}function N(b,
c,f,e){if(b){var g=d.ue_err;d.ue_url&&!e&&b&&0<b.length&&(e=new Image,a.iel.push(e),e.src=b,a.count&&a.count("postbackImageSize",b.length));if(y){var h=k.encodeURIComponent;h&&b&&(e=new Image,b=""+d.ue_fpf+h(b)+":"+(+new z-d.ue_t0),a.iel.push(e),e.src=b)}else a.log&&(a.log(b,"uedata",{n:1}),a.ielf.push(b));g&&!g.ts&&g.startTimer();a.b&&(g=a.b,a.b="",N(g,c,f,1))}}function w(b){var c=x?x.type:D,d=2==c||a.isBFonMshop,c=c&&!d,e=a.bfini;P||(e&&1<e&&(b+="&bfform=1",c||(a.isBFT=e-1)),d&&(b+="&bfnt=1",a.isBFT=
a.isBFT||1),a.ssw&&a.isBFT&&(a.isBFonMshop&&(a.isNRBF=0),q(a.isNRBF)&&(d=a.ssw(a.oid),d.e||q(d.val)||(a.isNRBF=1<d.val?0:1)),q(a.isNRBF)||(b+="&nrbf="+a.isNRBF)),a.isBFT&&!a.isNRBF&&(b+="&bft="+a.isBFT));return b}if(!a.paused&&(b||q(c))){for(var p in c)c[t](p)&&h(p,b,c[p]);a.isBFonMshop||u("pc",b,c);p=h("id",b)||a.id;var s=h("id2",b),f=a.url+"?"+n+"&v="+a.v+"&id="+p,v=h("ctb",b)||h("wb",b),A;v&&(f+="&ctb="+v);s&&(f+="&id2="+s);1<d.ueinit&&(f+="&ic="+d.ueinit);if(!("ld"!=n&&"ul"!=n||b&&b!=p)){if("ld"==
n){try{k[H]&&k[H].isUeh&&(k[H]=null)}catch(F){}if(k.chrome)for(s=0;s<I.length;s++)S(E,I[s]);(s=K.ue_backdetect)&&s.ue_back&&s.ue_back.value++;d._uess&&(A=d._uess());a.isl=1}a._bf&&(f+="&bf="+a._bf());d.ue_navtiming&&g&&(h("ctb",p,"1"),a.isBFonMshop||u("tc",D,D,J));!B||a.isBFonMshop||T||(g&&C(a.t,{na_:g.navigationStart,ul_:g.unloadEventStart,_ul:g.unloadEventEnd,rd_:g.redirectStart,_rd:g.redirectEnd,fe_:g.fetchStart,lk_:g.domainLookupStart,_lk:g.domainLookupEnd,co_:g.connectStart,_co:g.connectEnd,
sc_:g.secureConnectionStart,rq_:g.requestStart,rs_:g.responseStart,_rs:g.responseEnd,dl_:g.domLoading,di_:g.domInteractive,de_:g.domContentLoadedEventStart,_de:g.domContentLoadedEventEnd,_dc:g.domComplete,ld_:g.loadEventStart,_ld:g.loadEventEnd,ntd:("function"!==typeof B.now||q(J)?0:new z(J+B.now())-new z)+a.t0}),x&&C(a.t,{ty:x.type+a.t0,rc:x.redirectCount+a.t0}),T=1);a.isBFonMshop||C(a.t,{hob:d.ue_hob,hoe:d.ue_hoe});a.ifr&&(f+="&ifr=1")}u(n,b,c,e);c="ld"==n&&b&&h("wb",b);var m,l;c||b&&b!==p||ba(b);
c||p==a.oid||ca(p,(h("t",b)||{}).tc||+h("t0",b),+h("t0",b));(e=d.ue_mbl)&&e.cnt&&!c&&(f+=e.cnt());c?h("wb",b,2):"ld"==n&&(a.lid=G(p));for(m in a.sc)if(1==h("wb",m))break;if(c){if(a.s)return;f=r(f,null)}else e=r(f,null),e!=f&&(e=w(e),a.b=e),A&&(f+=A),f=r(f,b||a.id);f=w(f);if(a.b||c)for(m in a.sc)2==h("wb",m)&&delete a.sc[m];A=0;a._rt&&(f+="&rt="+a._rt());e=k.csa;if(!c&&e)for(l in m=h("t",b)||{},e=e("PageTiming"),m)m[t](l)&&e("mark",da[l]||l,m[l]);c||(a.s=0,(l=d.ue_err)&&0<l.ec&&l.pec<l.ec&&(l.pec=
l.ec,f+="&ec="+l.ec+"&ecf="+l.ecf),A=h("ctb",b),"ld"!==n||b||a.markers||(a.markers={},C(a.markers,h("t",b))),h("t",b,{}));a.tag&&a.tag().length&&(f+="&csmtags="+a.tag().join("|"),a.tag=O());l=a.viz||[];(m=l.length)&&(f+="&viz="+l.splice(0,m).join("|"));q(d.ue_pty)||(f+="&pty="+d.ue_pty+"&spty="+d.ue_spty+"&pti="+d.ue_pti);a.tabid&&(f+="&tid="+a.tabid);a.aftb&&(f+="&aftb=1");!a._ui||b&&b!=p||(f+=a._ui());a.a=f;N(f,n,A,c)}}function ba(a){var b=k.ue_csm_markers||{},c;for(c in b)b[t](c)&&u(c,a,D,b[c])}
function F(a,b,c){c=c||k;if(c[U])c[U](a,b,!1);else if(c[V])c[V]("on"+a,b)}function S(a,b,c){c=c||k;if(c[W])c[W](a,b,!1);else if(c[X])c[X]("on"+a,b)}function Y(){function a(){d.onUl()}function b(a){return function(){c[a]||(c[a]=1,R(a))}}var c={},e,g;d.onLd=b("ld");d.onLdEnd=b("ld");d.onUl=b("ul");e={stop:b("os")};k.chrome?(F(E,a),I.push(a)):e[E]=d.onUl;for(g in e)e[t](g)&&Q(0,k,g,e[g]);d.ue_viz&&ue_viz();F("load",d.onLd);u("ue")}function ca(g,b,c){var e=d.ue_mbl,h=k.csa,q=h&&h("SPA"),h=h&&h("PageTiming");
e&&e.ajax&&e.ajax(b,c);q&&h&&(q("newPage",{requestId:g,transitionType:"soft"}),h("mark","transitionStart",b));a.tag("ajax-transition")}d.ueinit=(d.ueinit||0)+1;var a=d.ue=d.ue||{};a.t0=k.aPageStart||d.ue_t0;a.id=d.ue_id;a.url=d.ue_url;a.rid=d.ue_id;a.a="";a.b="";a.h={};a.s=1;a.t={};a.sc={};a.iel=[];a.ielf=[];a.viz=[];a.v="0.217562.0";a.paused=!1;var t="hasOwnProperty",E="beforeunload",H="on"+E,U="addEventListener",W="removeEventListener",V="attachEvent",X="detachEvent",da={cf:"criticalFeature",af:"aboveTheFold",
fn:"functional",fp:"firstPaint",fcp:"firstContentfulPaint",bb:"bodyBegin",be:"bodyEnd",ld:"loaded"},z=k.Date,B=k.performance||k.webkitPerformance,g=(B||{}).timing,x=(B||{}).navigation,J=(g||{}).navigationStart,y=d.ue_fpf,aa=d.ue_tx_md,v=d.ue_tx_ad,P=0,T=0,I=[],D;a.oid=G(a.id);a.lid=G(a.id);a._t0=a.t0;a.tag=O();a.ifr=k.top!==k.self||k.frameElement?1:0;a.markers=null;a.attach=F;a.detach=S;if("000-0000000-8675309"===d.ue_sid){var Z=L("cdn-rid"),$=L("session-id");Z&&$&&M(Z,$,"cdn")}d.uei=Y;d.ueh=Q;d.ues=
h;d.uet=u;d.uex=R;a.reset=M;a.pause=function(d){a.paused=d};Y();0<v&&u("ho")})(ue_csm,ue_csm.window,ue_csm.document);
ue.stub(ue,"log");ue.stub(ue,"onunload");ue.stub(ue,"onflush");
(function(c){var a=c.ue;a.cv={};a.cv.scopes={};a.count=function(d,c,b){var e={},f=a.cv,g=b&&0===b.c;e.counter=d;e.value=c;e.t=a.d();b&&b.scope&&(f=a.cv.scopes[b.scope]=a.cv.scopes[b.scope]||{},e.scope=b.scope);if(void 0===c)return f[d];f[d]=c;d=0;b&&b.bf&&(d=1);ue_csm.ue_sclog||!a.clog||0!==d||g?a.log&&a.log(e,"csmcount",{c:1,bf:d}):a.clog(e,"csmcount",{bf:d})};a.count("baselineCounter2",1);a&&a.event&&(a.event({requestId:c.ue_id||"rid",server:c.ue_sn||"sn",obfuscatedMarketplaceId:c.ue_mid||"mid"},
"csm","csm.CSMBaselineEvent.4"),a.count("nexusBaselineCounter",1,{bf:1}))})(ue_csm);
var ue_hoe = +new Date();
window.ueinit = window.ue_ihb;
</script>
<!-- 3ttlluy654uowfz4q540n0g917pwxx -->
<script>window.ue && ue.count && ue.count('CSMLibrarySize', 9671)</script><script>var aPageStart = (new Date()).getTime();</script><meta name="viewport" content="width=device-width, maximum-scale=1, minimum-scale=1, initial-scale=1, user-scalable=no, shrink-to-fit=no"/><meta charset="utf-8"/>
<title dir="ltr">Amazon Anmelden</title>
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, user-scalable=0" />
<link rel="stylesheet" href="https://images-eu.ssl-images-amazon.com/images/I/71wSZQ4zdGL.css?AUIClients/AuthenticationPortalAlexaSkin#mobile.us.not-trident" />
<link rel="stylesheet" href="https://images-eu.ssl-images-amazon.com/images/I/01SdjaY0ZsL._RC|31jdWD+JB+L.css,41K9WJ9wk7L.css_.css?AUIClients/AuthenticationPortalAssets&QmmAyoMU#mobile.194821-T1" />
<link rel="stylesheet" href="https://images-eu.ssl-images-amazon.com/images/I/11vbcpUoDhL.css?AUIClients/CVFAssets#mobile" />
<script>
(function(f,h,Q,E){function F(a){u&&u.tag&&u.tag(q(":","aui",a))}function v(a,b){u&&u.count&&u.count("aui:"+a,0===b?0:b||(u.count("aui:"+a)||0)+1)}function m(a){try{return a.test(navigator.userAgent)}catch(b){return!1}}function x(a,b,c){a.addEventListener?a.addEventListener(b,c,!1):a.attachEvent&&a.attachEvent("on"+b,c)}function q(a,b,c,e){b=b&&c?b+a+c:b||c;return e?q(a,b,e):b}function G(a,b,c){try{Object.defineProperty(a,b,{value:c,writable:!1})}catch(e){a[b]=c}return c}function ta(a,b){var c=a.length,
e=c,g=function(){e--||(R.push(b),S||(setTimeout(ca,0),S=!0))};for(g();c--;)da[a[c]]?g():(z[a[c]]=z[a[c]]||[]).push(g)}function ua(a,b,c,e,g){var d=h.createElement(a?"script":"link");x(d,"error",e);g&&x(d,"load",g);a?(d.type="text/javascript",d.async=!0,c&&/AUIClients|images[/]I/.test(b)&&d.setAttribute("crossorigin","anonymous"),d.src=b):(d.rel="stylesheet",d.href=b);h.getElementsByTagName("head")[0].appendChild(d)}function ea(a,b){return function(c,e){function g(){ua(b,c,d,function(b){T?v("resource_unload"):
d?(d=!1,v("resource_retry"),g()):(v("resource_error"),a.log("Asset failed to load: "+c));b&&b.stopPropagation?b.stopPropagation():f.event&&(f.event.cancelBubble=!0)},e)}if(fa[c])return!1;fa[c]=!0;v("resource_count");var d=!0;return!g()}}function va(a,b,c){for(var e={name:a,guard:function(c){return b.guardFatal(a,c)},guardTime:function(a){return b.guardTime(a)},logError:function(c,d,e){b.logError(c,d,e,a)}},g=[],d=0;d<c.length;d++)H.hasOwnProperty(c[d])&&(g[d]=U.hasOwnProperty(c[d])?U[c[d]](H[c[d]],
e):H[c[d]]);return g}function A(a,b,c,e,g){return function(d,h){function n(){var a=null;e?a=h:"function"===typeof h&&(p.start=w(),a=h.apply(f,va(d,k,l)),p.end=w());if(b){H[d]=a;a=d;for(da[a]=!0;(z[a]||[]).length;)z[a].shift()();delete z[a]}p.done=!0}var k=g||this;"function"===typeof d&&(h=d,d=E);b&&(d=d?d.replace(ha,""):"__NONAME__",V.hasOwnProperty(d)&&k.error(q(", reregistered by ",q(" by ",d+" already registered",V[d]),k.attribution),d),V[d]=k.attribution);for(var l=[],m=0;m<a.length;m++)l[m]=
a[m].replace(ha,"");var p=B[d||"anon"+ ++wa]={depend:l,registered:w(),namespace:k.namespace};c?n():ta(l,k.guardFatal(d,n));return{decorate:function(a){U[d]=k.guardFatal(d,a)}}}}function ia(a){return function(){var b=Array.prototype.slice.call(arguments);return{execute:A(b,!1,a,!1,this),register:A(b,!0,a,!1,this)}}}function W(a,b){return function(c,e){e||(e=c,c=E);var g=this.attribution;return function(){t.push(b||{attribution:g,name:c,logLevel:a});var d=e.apply(this,arguments);t.pop();return d}}}
function I(a,b){this.load={js:ea(this,!0),css:ea(this)};G(this,"namespace",b);G(this,"attribution",a)}function ja(){h.body?r.trigger("a-bodyBegin"):setTimeout(ja,20)}function C(a,b){a.className=X(a,b)+" "+b}function X(a,b){return(" "+a.className+" ").split(" "+b+" ").join(" ").replace(/^ | $/g,"")}function ka(a){try{return a()}catch(b){return!1}}function J(){if(K){var a={w:f.innerWidth||n.clientWidth,h:f.innerHeight||n.clientHeight};5<Math.abs(a.w-Y.w)||50<a.h-Y.h?(Y=a,L=4,(a=k.mobile||k.tablet?450<
a.w&&a.w>a.h:1250<=a.w)?C(n,"a-ws"):n.className=X(n,"a-ws")):0<L&&(L--,la=setTimeout(J,16))}}function xa(a){(K=a===E?!K:!!a)&&J()}function ya(){return K}function ma(){D.forEach(function(a){F(a)})}function na(a,b,c){if(b){a=m(/Chrome/i)&&!m(/Edge/i)&&!m(/OPR/i)&&!a.capabilities.isAmazonApp&&!m(new RegExp(Z+"bwv"+Z+"b"));var e="sw:browser:"+c+":";b.browser&&a&&(D.push(e+"supported"),b.browser.action(e,c));!a&&b.browser&&D.push(e+"unsupported")}}"use strict";var M=Q.now=Q.now||function(){return+new Q},
w=function(a){return a&&a.now?a.now.bind(a):M}(f.performance),N=w(),p=f.AmazonUIPageJS||f.P;if(p&&p.when&&p.register){N=[];for(var l=h.currentScript;l;l=l.parentElement)l.id&&N.push(l.id);return p.log("A copy of P has already been loaded on this page.","FATAL",N.join(" "))}var u=f.ue;F();F("aui_build_date:3.21.4-2021-08-16");var R=[],S=!1;var ca=function(){for(var a=setTimeout(ca,0),b=M();R.length;)if(R.shift()(),50<M()-b)return;clearTimeout(a);S=!1};var da={},z={},fa={},T=!1;x(f,"beforeunload",function(){T=
!0;setTimeout(function(){T=!1},1E4)});var ha=/^prv:/,V={},H={},U={},B={},wa=0,Z=String.fromCharCode(92),t=[],oa=f.onerror;f.onerror=function(a,b,c,e,g){g&&"object"===typeof g||(g=Error(a,b,c),g.columnNumber=e,g.stack=b||c||e?q(Z,g.message,"at "+q(":",b,c,e)):E);var d=t.pop()||{};g.attribution=q(":",g.attribution||d.attribution,d.name);g.logLevel=d.logLevel;g.attribution&&console&&console.log&&console.log([g.logLevel||"ERROR",a,"thrown by",g.attribution].join(" "));t=[];oa&&(d=[].slice.call(arguments),
d[4]=g,oa.apply(f,d))};I.prototype={logError:function(a,b,c,e){b={message:b,logLevel:c||"ERROR",attribution:q(":",this.attribution,e)};if(f.ueLogError)return f.ueLogError(a||b,a?b:null),!0;console&&console.error&&(console.log(b),console.error(a));return!1},error:function(a,b,c,e){a=Error(q(":",e,a,c));a.attribution=q(":",this.attribution,b);throw a;},guardError:W(),guardFatal:W("FATAL"),guardCurrent:function(a){var b=t[t.length-1];return b?W(b.logLevel,b).call(this,a):a},guardTime:function(a){var b=
t[t.length-1],c=b&&b.name;return c&&c in B?function(){var b=w(),g=a.apply(this,arguments);B[c].async=(B[c].async||0)+w()-b;return g}:a},log:function(a,b,c){return this.logError(null,a,b,c)},declare:A([],!0,!0,!0),register:A([],!0),execute:A([]),AUI_BUILD_DATE:"3.21.4-2021-08-16",when:ia(),now:ia(!0),trigger:function(a,b,c){var e=M();this.declare(a,{data:b,pageElapsedTime:e-(f.aPageStart||NaN),triggerTime:e});c&&c.instrument&&O.when("prv:a-logTrigger").execute(function(b){b(a)})},handleTriggers:function(){this.log("handleTriggers deprecated")},
attributeErrors:function(a){return new I(a)},_namespace:function(a,b){return new I(a,b)}};var r=G(f,"AmazonUIPageJS",new I);var O=r._namespace("PageJS","AmazonUI");O.declare("prv:p-debug",B);r.declare("p-recorder-events",[]);r.declare("p-recorder-stop",function(){});G(f,"P",r);ja();if(h.addEventListener){var pa;h.addEventListener("DOMContentLoaded",pa=function(){r.trigger("a-domready");h.removeEventListener("DOMContentLoaded",pa,!1)},!1)}var n=h.documentElement,aa=function(){var a=["O","ms","Moz",
"Webkit"],b=h.createElement("div");return{testGradients:function(){return!0},test:function(c){var e=c.charAt(0).toUpperCase()+c.substr(1);c=(a.join(e+" ")+e+" "+c).split(" ");for(e=c.length;e--;)if(""===b.style[c[e]])return!0;return!1},testTransform3d:function(){return!0}}}();p=n.className;var qa=/(^| )a-mobile( |$)/.test(p),ra=/(^| )a-tablet( |$)/.test(p),k={audio:function(){return!!h.createElement("audio").canPlayType},video:function(){return!!h.createElement("video").canPlayType},canvas:function(){return!!h.createElement("canvas").getContext},
svg:function(){return!!h.createElementNS&&!!h.createElementNS("http://www.w3.org/2000/svg","svg").createSVGRect},offline:function(){return navigator.hasOwnProperty&&navigator.hasOwnProperty("onLine")&&navigator.onLine},dragDrop:function(){return"draggable"in h.createElement("span")},geolocation:function(){return!!navigator.geolocation},history:function(){return!(!f.history||!f.history.pushState)},webworker:function(){return!!f.Worker},autofocus:function(){return"autofocus"in h.createElement("input")},
inputPlaceholder:function(){return"placeholder"in h.createElement("input")},textareaPlaceholder:function(){return"placeholder"in h.createElement("textarea")},localStorage:function(){return"localStorage"in f&&null!==f.localStorage},orientation:function(){return"orientation"in f},touch:function(){return"ontouchend"in h},gradients:function(){return aa.testGradients()},hires:function(){var a=f.devicePixelRatio&&1.5<=f.devicePixelRatio||f.matchMedia&&f.matchMedia("(min-resolution:144dpi)").matches;v("hiRes"+
(qa?"Mobile":ra?"Tablet":"Desktop"),a?1:0);return a},transform3d:function(){return aa.testTransform3d()},touchScrolling:function(){return m(/Windowshop|android|OS ([5-9]|[1-9][0-9]+)(_[0-9]{1,2})+ like Mac OS X|Chrome|Silk|Firefox|Trident.+?; Touch/i)},ios:function(){return m(/OS [1-9][0-9]*(_[0-9]*)+ like Mac OS X/i)&&!m(/trident|Edge/i)},android:function(){return m(/android.([1-9]|[L-Z])/i)&&!m(/trident|Edge/i)},mobile:function(){return qa},tablet:function(){return ra},rtl:function(){return"rtl"===
n.dir}};for(l in k)k.hasOwnProperty(l)&&(k[l]=ka(k[l]));for(var ba="textShadow textStroke boxShadow borderRadius borderImage opacity transform transition".split(" "),P=0;P<ba.length;P++)k[ba[P]]=ka(function(){return aa.test(ba[P])});var K=!0,la=0,Y={w:0,h:0},L=4;J();x(f,"resize",function(){clearTimeout(la);L=4;J()});var sa={getItem:function(a){try{return f.localStorage.getItem(a)}catch(b){}},setItem:function(a,b){try{return f.localStorage.setItem(a,b)}catch(c){}}};n.className=X(n,"a-no-js");C(n,"a-js");
!m(/OS [1-8](_[0-9]*)+ like Mac OS X/i)||f.navigator.standalone||m(/safari/i)||C(n,"a-ember");p=[];for(l in k)k.hasOwnProperty(l)&&k[l]&&p.push("a-"+l.replace(/([A-Z])/g,function(a){return"-"+a.toLowerCase()}));C(n,p.join(" "));n.setAttribute("data-aui-build-date","3.21.4-2021-08-16");r.register("p-detect",function(){return{capabilities:k,localStorage:k.localStorage&&sa,toggleResponsiveGrid:xa,responsiveGridEnabled:ya}});m(/UCBrowser/i)||k.localStorage&&C(n,sa.getItem("a-font-class"));r.declare("a-event-revised-handling",
!1);try{var y=navigator.serviceWorker}catch(a){F("sw:nav_err")}y&&(x(y,"message",function(a){a&&a.data&&v(a.data.k,a.data.v)}),y.controller&&y.controller.postMessage("MSG-RDY"));var D=[];(function(a){var b=a.reg,c=a.unreg;y&&y.getRegistrations?(O.when("A").execute(function(a){na(a,c,"unregister")}),x(f,"load",function(){O.when("A").execute(function(a){na(a,b,"register");ma()})})):(b&&b.browser&&D.push("sw:browser:register:unsupported"),c&&c.browser&&D.push("sw:browser:unregister:unsupported"),ma())})({reg:{},
unreg:{}});r.declare("a-fix-event-off",!1);v("pagejs:pkgExecTime",w()-N)})(window,document,Date);
(window.AmazonUIPageJS ? AmazonUIPageJS : P).load.js('https://images-eu.ssl-images-amazon.com/images/I/61-6nKPKyWL._RC|11Y+5x+kkTL.js,01qkmZhGmAL.js,71z7cQWWSXL.js_.js?AUIClients/AuthenticationPortalAlexaSkin#mobile');
(window.AmazonUIPageJS ? AmazonUIPageJS : P).load.js('https://images-eu.ssl-images-amazon.com/images/I/21G215oqvfL._RC|21OJDARBhQL.js,218GJg15I8L.js,31lucpmF4CL.js,2119M3Ks9rL.js,51WeK3j9XRL.js_.js?AUIClients/AuthenticationPortalAssets&QmmAyoMU#mobile.194821-T1');
(window.AmazonUIPageJS ? AmazonUIPageJS : P).load.js('https://images-eu.ssl-images-amazon.com/images/I/01wGDSlxwdL.js?AUIClients/AuthenticationPortalInlineAssets');
(window.AmazonUIPageJS ? AmazonUIPageJS : P).load.js('https://images-eu.ssl-images-amazon.com/images/I/31SD4PT22dL.js?AUIClients/CVFAssets#mobile');
(window.AmazonUIPageJS ? AmazonUIPageJS : P).load.js('https://images-eu.ssl-images-amazon.com/images/I/81oDzXaLrLL.js?AUIClients/SiegeClientSideEncryptionAUI');
(window.AmazonUIPageJS ? AmazonUIPageJS : P).load.js('https://images-eu.ssl-images-amazon.com/images/I/31vIos-Q9qL.js?AUIClients/AmazonUIFormControlsJS#mobile');
(window.AmazonUIPageJS ? AmazonUIPageJS : P).load.js('https://images-eu.ssl-images-amazon.com/images/I/71fUSQvu7lL.js?AUIClients/FWCIMAssets');
(window.AmazonUIPageJS ? AmazonUIPageJS : P).load.js('https://images-eu.ssl-images-amazon.com/images/I/61Oc4hE2cwL.js?AUIClients/ACICAssets');
</script>
window.ue_ihe = (window.ue_ihe || 0) + 1;
if (window.ue_ihe === 1) {
(function(k,l,g){function m(a){c||(c=b[a.type].id,"undefined"===typeof a.clientX?(e=a.pageX,f=a.pageY):(e=a.clientX,f=a.clientY),2!=c||h&&(h!=e||n!=f)?(r(),d.isl&&l.setTimeout(function(){p("at",d.id)},0)):(h=e,n=f,c=0))}function r(){for(var a in b)b.hasOwnProperty(a)&&d.detach(a,m,b[a].parent)}function s(){for(var a in b)b.hasOwnProperty(a)&&d.attach(a,m,b[a].parent)}function t(){var a="";!q&&c&&(q=1,a+="&ui="+c);return a}var d=k.ue,p=k.uex,q=0,c=0,h,n,e,f,b={click:{id:1,parent:g},mousemove:{id:2,
parent:g},scroll:{id:3,parent:l},keydown:{id:4,parent:g}};d&&p&&(s(),d._ui=t)})(ue_csm,window,document);
(function(s,l){function m(b,e,c){c=c||new Date(+new Date+t);c="expires="+c.toUTCString();n.cookie=b+"="+e+";"+c+";path=/"}function p(b){b+="=";for(var e=n.cookie.split(";"),c=0;c<e.length;c++){for(var a=e[c];" "==a.charAt(0);)a=a.substring(1);if(0===a.indexOf(b))return decodeURIComponent(a.substring(b.length,a.length))}return""}function q(b,e,c){if(!e)return b;-1<b.indexOf("{")&&(b="");for(var a=b.split("&"),f,d=!1,h=!1,g=0;g<a.length;g++)f=a[g].split(":"),f[0]==e?(!c||d?a.splice(g,1):(f[1]=c,a[g]=
f.join(":")),h=d=!0):2>f.length&&(a.splice(g,1),h=!0);h&&(b=a.join("&"));!d&&c&&(0<b.length&&(b+="&"),b+=e+":"+c);return b}var k=s.ue||{},t=3024E7,n=ue_csm.document||l.document,r=null,d;a:{try{d=l.localStorage;break a}catch(u){}d=void 0}k.count&&k.count("csm.cookieSize",document.cookie.length);k.cookie={get:p,set:m,updateCsmHit:function(b,e,c){try{var a;if(!(a=r)){var f;a:{try{if(d&&d.getItem){f=d.getItem("csm-hit");break a}}catch(k){}f=void 0}a=f||p("csm-hit")||"{}"}a=q(a,b,e);r=a=q(a,"t",+new Date);
try{d&&d.setItem&&d.setItem("csm-hit",a)}catch(h){}m("csm-hit",a,c)}catch(g){"function"==typeof l.ueLogError&&ueLogError(Error("Cookie manager: "+g.message),{logLevel:"WARN"})}}}})(ue_csm,window);
(function(l,e){function c(b){b="";var c=a.isBFT?"b":"s",d=""+a.oid,g=""+a.lid,h=d;d!=g&&20==g.length&&(c+="a",h+="-"+g);a.tabid&&(b=a.tabid+"+");b+=c+"-"+h;b!=f&&100>b.length&&(f=b,a.cookie?a.cookie.updateCsmHit(m,b+("|"+ +new Date)):e.cookie="csm-hit="+b+("|"+ +new Date)+n+"; path=/")}function p(){f=0}function d(b){!0===e[a.pageViz.propHid]?f=0:!1===e[a.pageViz.propHid]&&c({type:"visible"})}var n="; expires="+(new Date(+new Date+6048E5)).toGMTString(),m="tb",f,a=l.ue||{},k=a.pageViz&&a.pageViz.event&&
a.pageViz.propHid;a.attach&&(a.attach("click",c),a.attach("keyup",c),k||(a.attach("focus",c),a.attach("blur",p)),k&&(a.attach(a.pageViz.event,d,e),d({})));a.aftb=1})(ue_csm,ue_csm.document);
ue_csm.ue.stub(ue,"impression");
ue.stub(ue,"trigger");
if(window.ue&&uet) { uet('bb'); }
</script>
<script>window.ue && ue.count && ue.count('CSMLibrarySize', 2729)</script></head>
<body class="a-color-offset-background auth-alexa ap-locale-de_DE a-m-us a-aui_72554-c a-aui_button_aria_label_markup_348458-c a-aui_csa_templates_buildin_ww_exp_337518-c a-aui_csa_templates_buildin_ww_launch_337517-c a-aui_csa_templates_declarative_ww_exp_337521-c a-aui_csa_templates_declarative_ww_launch_337520-c a-aui_dynamic_img_a11y_markup_345061-c a-aui_mm_desktop_exp_291916-c a-aui_mm_desktop_launch_291918-c a-aui_mm_desktop_targeted_exp_291928-c a-aui_mm_desktop_targeted_launch_291922-c a-aui_pci_risk_banner_210084-c a-aui_preload_261698-c a-aui_rel_noreferrer_noopener_309527-c a-aui_template_weblab_cache_333406-c a-aui_tnr_v2_180836-c"> <img height="1" width="1" style='display:none;visibility:hidden;' src='//fls-eu.amazon.com/1/batch/1/OP/A1PA6795UKMFR9:258-2961822-3372164:S26KCFWPYX5YKK8MHA3V$uedata=s:%2Fap%2Fuedata%3Fstaticb%26id%3DS26KCFWPYX5YKK8MHA3V:0' alt="" onload="window.ue_sbl && window.ue_sbl();"/>
<script>
!function(){function n(n,t){var r=i(n);return t&&(r=r("instance",t)),r}var r=[],c=0,i=function(t){return function(){var n=c++;return r.push([t,[].slice.call(arguments,0),n,{time:Date.now()}]),i(n)}};n._s=r,this.csa=n}();;
csa('Config', {});
if (window.csa) {
csa("Config", {
'Events.Namespace': 'csa',
'ObfuscatedMarketplaceId': 'A1PA6795UKMFR9',
'Events.SushiEndpoint': 'https://unagi.amazon.de/1/events/com.amazon.csm.csa.prod',
'CacheDetection.RequestID': "S26KCFWPYX5YKK8MHA3V",
'CacheDetection.Callback': window.ue && ue.reset,
'LCP.elementDedup': 1
csa("Events")("setEntity", {
page: {requestId: "S26KCFWPYX5YKK8MHA3V", meaningful: "interactive"},
session: {id: "258-2961822-3372164"}
!function(r){var i,e,o="splice",u=r.csa,f={},c={},a=r.csa._s,s=0,l={},g={},h={},n=Object.keys,v=function(){};function t(n,t){return u(n,t)}function d(n,t){var r=c[n]||{};I(r,t),c[n]=r,E(D,0)}function p(n,t,r){var i=!0;return t=y(t),r&&r.buffered&&(i=(h[n]||[]).every(function(n){return!1!==t(n)})),i?(l[n]||(l[n]=[]),l[n].push(t),function(){!function(n,t){var r=l[n];r&&r[o](r.indexOf(t),1)}(n,t)}):v}function m(n,t){if(t=y(t),n in g)return t(g[n]),v;return p(n,function(n){return t(n),!1})}function w(n,t){if(u("Errors")("logError",n),f.DEBUG)throw t||n}function b(){return Math.abs(4294967295*Math.random()|0).toString(36)}function y(n,t){return function(){try{return n.apply(this,arguments)}catch(n){w(n.message||n,n)}}}function E(n,t){return r.setTimeout(y(n),t)}function D(){for(var n=0;n<a.length;){var t=a[n],r=t[0]in c;if(!r&&!e)return void(s=t.length);r?(a[o](s=n,1),S(t)):n++}}function S(n){var arguments,t=c[n[0]],r=(arguments=n[1])[0];if(!t||!t[r])return w("Undefined function: "+t+"/"+r);i=n[3],c[n[2]]=t[r].apply(t,arguments.slice(1))||{},i=0}function U(){e=1,D()}function I(t,r){n(r).forEach(function(n){t[n]=r[n]})}m("$beforeunload",U),d("Config",{instance:function(n){I(f,n)}}),u.plugin=y(function(n){n(t)}),t.config=f,t.register=d,t.on=p,t.once=m,t.blank=v,t.emit=function(n,t,r){for(var i=l[n]||[],e=0;e<i.length;)!1===i[e](t)?i[o](e,1):e++;g[n]=t||{},r&&r.buffered&&(h[n]||(h[n]=[]),100<=h[n].length&&h[n].shift(),h[n].push(t||{}))},t.UUID=function(){return[b(),b(),b(),b()].join("-")},t.time=function(n){var t=i?new Date(i.time):new Date;return"ISO"===n?t.toISOString():t.getTime()},t.error=w,t.warn=function(n,t){if(u("Errors")("logWarn",n),f.DEBUG)throw t||n},t.exec=y,t.timeout=E,t.interval=function(n,t){return r.setInterval(y(n),t)},(t.global=r).csa._s.push=function(n){n[0]in c&&(!a.length||e)?S(n):a[o](s++,0,n)},D(),E(function(){E(U,f.SkipMissingPluginsTimeout||5e3)},1)}("undefined"!=typeof window?window:global);csa.plugin(function(o){var f="addEventListener",e="requestAnimationFrame",t=o.exec,r=o.global,u=o.on;o.raf=function(n){if(r[e])return r[e](t(n))},o.on=function(n,e,t,r){if(n&&"function"==typeof n[f]){var i=o.exec(t);return n[f](e,i,r),function(){n.removeEventListener(e,i,r)}}return"string"==typeof n?u(n,e,t,r):o.blank}});csa.plugin(function(o){var t,n,r={},e="localStorage",c="sessionStorage",a="local",i="session",u=o.exec;function s(e,t){var n;try{r[t]=!!(n=o.global[e]),n=n||{}}catch(e){r[t]=!(n={})}return n}function f(){t=t||s(e,a),n=n||s(c,i)}function l(e){return e&&e[i]?n:t}o.store=u(function(e,t,n){f();var o=l(n);return e?t?void(o[e]=t):o[e]:Object.keys(o)}),o.storageSupport=u(function(){return f(),r}),o.deleteStored=u(function(e,t){f();var n=l(t);if("function"==typeof e)for(var o in n)n.hasOwnProperty(o)&&e(o,n[o])&&delete n[o];else delete n[e]})});csa.plugin(function(o){function r(n){return function(r){o("Metrics",{producerId:"csa",dimensions:{message:r}})("recordMetric",n,1)}}o.register("Errors",{logError:r("jsError"),logWarn:r("jsWarn")})});csa.plugin(function(r){var o,e=r.global,i=r("Events"),f=e.location,d=e.document,a=((e.performance||{}).navigation||{}).type,t=r.on,u=r.emit,g={};function n(a,e){var t=!!o,n=(e=e||{}).keepPageAttributes;t&&(u("$beforePageTransition"),u("$pageTransition")),t&&!n&&i("removeEntity","page"),o=r.UUID(),n?g.id=o:g={schemaId:"<ns>.PageEntity.1",id:o,url:f.href,server:f.hostname,path:f.pathname,referrer:d.referrer,title:d.title},Object.keys(a||{}).forEach(function(e){g[e]=a[e]}),i("setEntity",{page:g}),u("$pageChange",g,{buffered:1}),t&&u("$afterPageTransition")}function l(){u("$load"),u("$ready"),u("$afterload")}function s(){u("$ready"),u("$beforeunload"),u("$unload"),u("$afterunload")}f&&d&&(t(e,"beforeunload",s),t(e,"pagehide",s),"complete"===d.readyState?l():t(e,"load",l),r.register("SPA",{newPage:n}),n({transitionType:{0:"hard",1:"refresh",2:"back-button"}[a]||"unknown"}))});csa.plugin(function(c){var t="Events",e="UNKNOWN",a="id",u="all",n="messageId",i="timestamp",f="producerId",o="application",r="obfuscatedMarketplaceId",s="entities",d="schemaId",l="version",p="attributes",v="<ns>",g=c.config,h=(c.global.location||{}).host,m=g[t+".Namespace"]||"csa_other",I=g.Application||"Other"+(h?":"+h:""),b=c("Transport"),y={},O=function(t,e){Object.keys(t).forEach(e)};function E(n,i,o){O(i,function(t){var e=o===u||(o||{})[t];t in n||(n[t]={version:1,id:i[t][a]||c.UUID()}),U(n[t],i[t],e)})}function U(e,n,i){O(n,function(t){!function(t,e,n){return"string"!=typeof e&&t!==l?c.error("Attribute is not of type string: "+t):!0===n||1===n||(t===a||!!~(n||[]).indexOf(t))}(t,n[t],i)||(e[t]=n[t])})}function N(o,t,r){O(t,function(t){var e=o[t];if(e[d]){var n={},i={};n[a]=e[a],n[f]=e[f]||r,n[d]=e[d],n[l]=e[l]++,n[p]=i,S(n),U(i,e,1),k(i),b("log",n)}})}function S(t){t[i]=function(t){return"number"==typeof t&&(t=new Date(t).toISOString()),t||c.time("ISO")}(t[i]),t[n]=t[n]||c.UUID(),t[o]=I,t[r]=g.ObfuscatedMarketplaceId||e,t[d]=t[d].replace(v,m)}function k(t){delete t[l],delete t[d],delete t[f]}function w(o){var r={};this.log=function(t,e){var n={},i=(e||{}).ent;return t?"string"!=typeof t[d]?c.error("A valid schema id is required for the event"):(S(t),E(n,y,i),E(n,r,i),E(n,t[s]||{},i),O(n,function(t){k(n[t])}),t[f]=o[f],t[s]=n,void b("log",t)):c.error("The event cannot be undefined")},this.setEntity=function(t){E(r,t,u),N(r,t,o[f])}}g["KillSwitch."+t]||c.register(t,{setEntity:function(t){E(y,t,u),N(y,t,"csa")},removeEntity:function(t){delete y[t]},instance:function(t){return new w(t)}})});csa.plugin(function(s){var c,l="Transport",g="post",u="preflight",r="csa.cajun.",i="store",a="deleteStored",f="sendBeacon",t=0,e=s.config[l+".BufferSize"]||2e3,h=s.config[l+".RetryDelay"]||1500,o=[],p=0,d=[],v=s.global,n=s.on,y=s.once,m=v.document,E=s.timeout,R=s.config[l+".FlushInterval"]||5e3,S=0;function b(n){if(864e5<s.time()-+new Date(n.timestamp))return s.warn("Event is too old: "+n);p<e&&(o.push(n),p++,!S&&t&&(S=E(w,R)))}function w(){d.forEach(function(t){var e=[];o.forEach(function(n){t.accepts(n)&&e.push(n)}),e.length&&(t.chunks?t.chunks(e).forEach(function(n){I(t,n)}):I(t,e))}),o=[],S=0}function I(t,e){function o(){s[a](r+n)}var n=s.UUID();s[i](r+n,JSON.stringify(e)),[function(n,t,e){var o=v.navigator||{},r=v.cordova||{};if(!o[f]||!n[g])return 0;n[u]&&r&&"ios"===r.platformId&&!c&&((new Image).src=n[u]().url,c=1);var i=n[g](t);if(!i.type&&o[f](i.url,i.body))return e(),1},function(n,t,e){if(!n[g])return 0;var o=n[g](t),r=o.url,i=o.body,c=o.type,u=new XMLHttpRequest,a=0;function f(n,t,e){u.open("POST",n),e&&u.setRequestHeader("Content-Type",e),u.send(t)}return u.onload=function(){u.status<299?e():s.config[l+".XHRRetries"]&&a<3&&E(function(){f(r,i,c)},++a*h)},f(r,i,c),1}].some(function(n){try{return n(t,e,o)}catch(n){}})}y("$afterload",function(){t=1,function(e){(s[i]()||[]).forEach(function(n){if(!n.indexOf(r))try{var t=s[i](n);s[a](n),JSON.parse(t).forEach(e)}catch(n){s.error(n)}})}(b),n(m,"visibilitychange",w,!1),w()}),y("$afterunload",function(){t=1,w()}),n("$afterPageTransition",function(){p=0}),s.register(l,{log:b,register:function(n){d.push(n)}})});csa.plugin(function(n){var r=n.config["Events.SushiEndpoint"];n("Transport")("register",{accepts:function(n){return n.schemaId},post:function(n){var t=n.map(function(n){return{data:n}});return{url:r,body:JSON.stringify({events:t})}},preflight:function(){var n,t=/\/\/(.*?)\//.exec(r);return t&&t[1]&&(n="https://"+t[1]+"/ping"),{url:n}},chunks:function(n){for(var t=[];500<n.length;)t.push(n.splice(0,500));return t.push(n),t}})});csa.plugin(function(n){var t,a,o,r,e=n.config,i="PageViews",d=e[i+".ImpressionMinimumTime"]||1e3,s="hidden",c="innerHeight",g="innerWidth",l="renderedTo",f=l+"Viewed",m=l+"Meaningful",u=l+"Impressed",p=1,v=2,h=3,w=4,y=5,P="loaded",I=7,T=8,b=n.global,E=n.on,V=n("Events",{producerId:"csa"}),$=b.document,M={},S={},H=y;function K(e){if(!M[I]){var i;if(M[e]=n.time(),e!==h&&e!==P||(t=t||M[e]),t&&H===w)a=a||M[e],(i={})[m]=t-o,i[f]=a-o,R("PageView.4",i),r=r||n.timeout(j,d);if(e!==y&&e!==p&&e!==v||(clearTimeout(r),r=0),e!==p&&e!==v||R("PageRender.3",{transitionType:e===p?"hard":"soft"}),e===I)(i={})[m]=t-o,i[f]=a-o,i[u]=M[e]-o,R("PageImpressed.2",i)}}function R(e,i){S[e]||(i.schemaId="<ns>."+e,V("log",i,{ent:"all"}),S[e]=1)}function W(){0===b[c]&&0===b[g]?(H=T,n("Events")("setEntity",{page:{viewport:"hidden-iframe"}})):H=$[s]?y:w,K(H)}function j(){K(I),r=0}function k(){var e=o?v:p;M={},S={},a=t=0,o=n.time(),K(e),W()}function q(){var e=$.readyState;"interactive"===e&&K(h),"complete"===e&&K(P)}e["KillSwitch."+i]||($&&void 0!==$[s]?(k(),E($,"visibilitychange",W,!1),E($,"readystatechange",q,!1),E("$afterPageTransition",k),E("$timing:loaded",q),n.once("$load",q)):n.warn("Page visibility not supported"))});csa.plugin(function(c){var s=c.config["Interactions.ParentChainLength"]||15,e="click",r="touches",f="timeStamp",o="length",u="pageX",g="pageY",p="pageXOffset",h="pageYOffset",m=250,v=5,d=200,l=.5,t={capture:!0,passive:!0},X=c.global,Y=c.emit,n=c.on,x=X.Math.abs,a=(X.document||{}).documentElement||{},y={x:0,y:0,t:0,sX:0,sY:0},N={x:0,y:0,t:0,sX:0,sY:0};function b(t){if(t.id)return"//*[@id='"+t.id+"']";var e=function(t){var e,n=1;for(e=t.previousSibling;e;e=e.previousSibling)e.nodeName===t.nodeName&&(n+=1);return n}(t),n=t.nodeName;return 1!==e&&(n+="["+e+"]"),t.parentNode&&(n=b(t.parentNode)+"/"+n),n}function I(t,e,n){var a=c("Content",{target:n}),i={schemaId:"<ns>.ContentInteraction.1",interaction:t,interactionData:e,messageId:c.UUID()};if(n){var r=b(n);r&&(i.attribution=r);var o=function(t){for(var e=t,n=e.tagName,a=!1,i=t?t.href:null,r=0;r<s;r++){if(!e||!e.parentElement){a=!0;break}n=(e=e.parentElement).tagName+"/"+n,i=i||e.href}return a||(n=".../"+n),{pc:n,hr:i}}(n);o.pc&&(i.interactionData.parentChain=o.pc),o.hr&&(i.interactionData.href=o.hr)}a("log",i),Y("$content.interaction",i)}function i(t){I(e,{interactionX:""+t.pageX,interactionY:""+t.pageY},t.target)}function C(t){if(t&&t[r]&&1===t[r][o]){var e=t[r][0];N=y={e:t.target,x:e[u],y:e[g],t:t[f],sX:X[p],sY:X[h]}}}function D(t){if(t&&t[r]&&1===t[r][o]&&y&&N){var e=t[r][0],n=t[f],a=n-N.t,i={e:t.target,x:e[u],y:e[g],t:n,sX:X[p],sY:X[h]};N=i,d<=a&&(y=i)}}function E(t){if(t){var e=x(y.x-N.x),n=x(y.y-N.y),a=x(y.sX-N.sX),i=x(y.sY-N.sY),r=t[f]-y.t;if(m<1e3*e/r&&v<e||m<1e3*n/r&&v<n){var o=n<e;o&&a&&e*l<=a||!o&&i&&n*l<=i||I((o?"horizontal":"vertical")+"-swipe",{interactionX:""+y.x,interactionY:""+y.y,endX:""+N.x,endY:""+N.y},y.e)}}}n(a,e,i,t),n(a,"touchstart",C,t),n(a,"touchmove",D,t),n(a,"touchend",E,t)});
csa.plugin(function(b){var a=b.global,c=a.uet,e=a.uex,f=a.ue,a=a.Object,g={largestContentfulPaint:"lcp",speedIndex:"si",atfSpeedIndex:"atfsi",visuallyLoaded50:"vl50",visuallyLoaded90:"vl90",visuallyLoaded100:"vl100"};b&&c&&e&&a.keys&&f&&a.keys(g).forEach(function(a){b.on("$timing:"+a,function(b){var d=g[a];if(f.isl){var h="csa:"+d;c(d,h,void 0,b);e("at",h)}else c(d,void 0,void 0,b)})})});
</script>
(function(){function l(a){for(var c=b.location.search.substring(1).split("&"),e=0;e<c.length;e++){var d=c[e].split("=");if(d[0]===a)return d[1]}}window.amzn=window.amzn||{};amzn.copilot=amzn.copilot||{};var b=window,f=document,g=b.P||b.AmazonUIPageJS,h=f.head||f.getElementsByTagName("head")[0],m=0,n=0;amzn.copilot.checkCoPilotSession=function(){f.cookie.match("cpidv")&&("undefined"!==typeof jQuery&&k(jQuery),g&&g.when&&g.when("jQuery").execute(function(a){k(a)}),b.amznJQ&&b.amznJQ.available&&b.amznJQ.available("jQuery",
function(){k(jQuery)}),b.jQuery||g||b.amznJQ||q())};var q=function(){m?b.ue&&"function"===typeof b.ue.count&&b.ue.count("cpJQUnavailable",1):(m=1,f.addEventListener?f.addEventListener("DOMContentLoaded",amzn.copilot.checkCoPilotSession,!1):f.attachEvent&&f.attachEvent("onreadystatechange",function(){"complete"===f.readyState&&amzn.copilot.checkCoPilotSession()}))},k=function(a){if(!n){n=1;amzn.copilot.jQuery=a;a=l("debugJS");var c="https:"===b.location.protocol?1:0,e=1;url="/gp/copilot/handlers/copilot_strings_resources.html";
window.texas&&texas.locations&&(url=texas.locations.makeUrl(url));g&&g.AUI_BUILD_DATE&&(e=0);amzn.copilot.jQuery.ajax&&amzn.copilot.jQuery.ajax({url:url,dataType:"json",data:{isDebug:a,isSecure:c,includeAUIP:e},success:function(a){amzn.copilot.vip=a.serviceEndPoint;amzn.copilot.enableMultipleTabSession=a.isFollowMe;r(a)},error:function(){b.ue.count("cpLoadResourceError",1)}})}},r=function(a){var c=amzn.copilot.jQuery,e=function(){amzn.copilot.setup(c.extend({isContinuedSession:!0},a))};a.CSSUrls&&
c.each(a.CSSUrls[0],function(a,c){var b=f.createElement("link");b.type="text/css";b.rel="stylesheet";b.href=c;h.appendChild(b)});a.CSSTag&&s(a.CSSTag);if(a.JSUrls){var d=l("forceSynchronousJS"),b=a.JSUrls[0];c.each(b,function(a,c){a===b.length-1?p(c,d,e):p(c,d)})}a.JSTag&&(t(a.JSTag),P.when("CSCoPilotPresenterAsset").execute(function(){e()}))},t=function(a){var c=f.createElement("div");c.innerHTML=a;a=0;for(var b=c.children.length;a<b;a++){var d=f.createElement("script");d.type="text/javascript";
d.innerHTML=c.children[a].innerHTML;h.appendChild(d)}},s=function(a){var b=f.createElement("div");b.innerHTML=a;a=0;for(var e=b.children.length;a<e;a++)h.appendChild(b.children[a])},p=function(a,b,e){var d=f.createElement("script");d.type="text/javascript";d.src=a;d.async=b?!1:!0;e&&(d.onload=e);h.appendChild(d)}})();
amzn.copilot.checkCoPilotSession();
</script>
<script>window.ue && ue.count && ue.count('CSMLibrarySize', 14475)</script><div id="a-page"><script type="a-state" data-a-state="{"key":"a-wlab-states"}">{}</script>
<div class="a-section a-spacing-none">
<div class="a-container a-global-nav-wrapper">
<div class="a-section a-spacing-none a-text-center">
<img src="https://images-na.ssl-images-amazon.com/images/G/03/authportal/dee/prod/alexa_logo_stacked_light._CB485943092_.png" alt="Amazon Alexa"/>
</div>
</div>
</div>
<div class="a-container">
</div>
<div class="a-section a-spacing-none auth-pagelet-mobile-container">
</div>
<div class="a-section auth-pagelet-mobile-container">
<script type="a-state" data-a-state="{"key":"auth-prepopulate-credential-state"}">{"isPrepopulateEnabled":true}</script>
<!-- Set cross domain sso variables to be used for making Ajax calls to central Identity domain -->
<div id="auth-alert-window" class="a-box a-alert a-alert-error" aria-live="assertive" role="alert"><div class="a-box-inner a-alert-container"><h4 class="a-alert-heading">Ein Problem ist aufgetreten:</h4><div class="a-alert-content">
<ul class="a-unordered-list a-vertical auth-error-messages" role="alert">
<li id="auth-email-missing-alert"><span class="a-list-item">
Bitte geben Sie Ihre E-Mail-Adresse oder Mobiltelefonnummer ein
</span></li>
<li id="auth-email-invalid-email-alert"><span class="a-list-item">
Ungültige E-Mail-Adresse oder Mobiltelefonnummer
</span></li>
<li id="auth-password-missing-alert"><span class="a-list-item">
Geben Sie Ihr Passwort ein
</span></li>
<li id="auth-guess-missing-alert"><span class="a-list-item">
Geben Sie die Zeichen so ein, wie sie auf dem Bild erscheinen.
</span></li>
<li id="auth-signin-legal-agreement-checkbox-unchecked-alert"><span class="a-list-item">
</span></li>
</ul>
</div></div></div>
<!-- show a warning modal dialog when the third party account is connected with Amazon -->
<form name="signIn" method="post" novalidate action="https://www.amazon.de/ap/signin" class="auth-validate-form auth-clearable-form">
<input type="hidden" name="appActionToken" value="WVNcq4qBjlJgSAFins2HDQTZj2FAwj3D" /><input type="hidden" name="appAction" value="SIGNIN" />
<input type="hidden" name="openid.return_to" value="ape:aHR0cHM6Ly9hbGV4YS5hbWF6b24uZGUvYXBpL2RldmljZXMtdjIvZGV2aWNlP2NhY2hlZD1mYWxzZQ==" />
<input type="hidden" name="prevRID" value="ape:UzI2S0NGV1BZWDVZS0s4TUhBM1Y=" />
<input type="hidden" name="workflowState" value="eyJ6aXAiOiJERUYiLCJlbmMiOiJBMjU2R0NNIiwiYWxnIjoiQTI1NktXIn0.QJL7Uf-nhWkmBHYdNkLzYe6Ju9RuRUW78i_bqToBnog4h1cBpwmG_w.ddkQ2EX9CRrr1WDj.VU2IBpTdQpewfjHFVN0EKQgraykbNoZLHUptW0Afez_87YtsVMxdb_5aVn0o9-MXtqF-EDJGtfgJC8mXOXI76I6Z2tzBQyR1JTkmCwcCawnCq_Fq4s0YXfD7DU70CkCYmbXqIB0VrJyKCh1PGa5ApNaIwbgd_Iz1rz-lWBIg62yvzq2PRFyDLy8M5WAu_fcCkbIvHfFp64XUVCeo6_kSjnUQVtZtO6M3yQ-10k-UDzywmWm4Mhjutfftq5g4I57fnmGXF6px8Y08081V4oArnK4Cp4wJmtSdpnkE0dXISp6whi4FaXMbxf3jS3HzxVoIyF723w.s-Kr3AYKx3gFkLgM9FCfmA" />
<h1 class="a-spacing-micro a-spacing-top-small a-text-left">
Anmelden
</h1>
<div class="a-section a-spacing-base a-text-right">
<a id="auth-fpp-link-bottom" class="a-link-normal" target="_top" rel="noopener" tabindex="9" href="https://www.amazon.de/ap/forgotpassword?showRememberMe=true&showRmrMe=1&openid.identity=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0%2Fidentifier_select&pageId=amzn_dp_project_dee_de&openid.return_to=https%3A%2F%2Falexa.amazon.de%2Fapi%2Fdevices-v2%2Fdevice%3Fcached%3Dfalse&prevRID=S26KCFWPYX5YKK8MHA3V&openid.assoc_handle=amzn_dp_project_dee_de&openid.mode=checkid_setup&prepopulatedLoginId=&failedSignInCount=0&openid.claimed_id=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0%2Fidentifier_select&openid.ns=http%3A%2F%2Fspecs.openid.net%2Fauth%2F2.0">
Passwort vergessen
</a>
</div>
<div class="a-input-text-group a-spacing-medium a-spacing-top-micro">
<label for="ap_email" class="a-form-label auth-mobile-label">
</label>
<div class="a-input-text-wrapper auth-required-field auth-fill-claim"><input type="email" maxlength="128" id="ap_email" autocomplete="username" placeholder="E-Mail-Adresse oder Mobiltelefonnummer" name="email" tabindex="1" autocorrect="off" autocapitalize="off"/></div>
<div id="ap_email_icon" class="auth-clear-icons">
<i class="a-icon a-icon-close" role="img" aria-label="E-Mail-Textfeld löschen, Button"></i>
</div>
<script type="a-state" data-a-state="{"key":"auth-show-password"}">{"isShowPasswordEnabled":true,"showPasswordChecked":false}</script>
and so on....
