An I/O error has occurred while writing a response message entity to the container output stream
Thanks. Very helpful!
@matt1 - can you do this for multiple lines of text - my Regex is terrible. Id like to add
Response Failure: null
as an OR condition
Yes it already has an OR in it, currently it matches
URI is too large >8192
I would try this line…
.*(URI is too large >8192|while writing a response message entity to the container output stream|Response Failure: null).*
I am also not good at it but the ā€˜|’ charater is a way or saying OR in some programming languages.
brilliant thanks - i am not getting the exact error so I had done my own which had removed the pipe
Sorry for pulling this up again. I run on 2.5.3 Release Build and still get this error.
As you mention to remove when moving to a higher version than 2.4 I got curious - should this be sorted in general with 2.5?
Or should I just go ahead with your recommendation still?
Matthias
I would upgrade to 2.5 as it will be the last of the ver 2 and it may be a while before version 3 is ready with good documentation and all polished up. The log filtering is not needed in 2.5 for those entries.
I did a full clean install of 2.5 and it went very smooth.
But my point is that I run already on 2.5.3 and still get these:
2020-03-30 09:10:28.937 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) ~[bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [bundleFile:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [bundleFile:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [bundleFile:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [bundleFile:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [bundleFile:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [bundleFile:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [bundleFile:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [bundleFile:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_191]
Caused by: org.eclipse.jetty.io.EofException
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:283) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:422) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:277) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:381) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:812) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:223) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:549) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:852) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:929) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:250) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:226) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:551) ~[bundleFile:9.4.20.v20190813]
at java.io.OutputStream.write(OutputStream.java:75) ~[?:1.8.0_191]
at org.glassfish.jersey.servlet.internal.ResponseWriter$NonCloseableOutputStreamWrapper.write(ResponseWriter.java:320) ~[?:?]
at org.glassfish.jersey.message.internal.CommittingOutputStream.write(CommittingOutputStream.java:218) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$UnCloseableOutputStream.write(WriterInterceptorExecutor.java:294) ~[bundleFile:?]
at org.eclipse.smarthome.io.rest.core.internal.GsonProvider.writeTo(GsonProvider.java:71) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:265) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:250) ~[bundleFile:?]
at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:106) ~[?:?]
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:86) ~[?:?]
... 53 more
Caused by: java.io.IOException: Datenübergabe unterbrochen (broken pipe)
at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:1.8.0_191]
at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:1.8.0_191]
at sun.nio.ch.IOUtil.write(IOUtil.java:148) ~[?:1.8.0_191]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:504) ~[?:1.8.0_191]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:263) ~[bundleFile:9.4.20.v20190813]
... 53 more
Sorry I have no idea as I don’t get them anymore, but I do run a very low number of bindings.
From memory it was mainly when I locked my iPhone that that error occurred and I have installed the latest iOS app. You need to work out what causes it, or just ignore it / filter if there are no downsides to doing that.
It’s usually associated with some UI, like a panel that needs a disconnect/reconnect after host reboot.
Meanwhile I’m pretty sure that there is some relation to the items database in the background.
I can reproduce this error by calling the list of all items in the REST API.
The error message occours on my system everytime an external software (e.g. VSCode) tries to get the list of items.
In my system there seem to be some ā€œghost itemsā€ that are no part of myitems.items. Even if this file is empty there remain some items from ā€œNowhere?ā€.
Don’t know how to delete this corrupt items at the moment from the database.
Maybe someone can help me with this?
I gathered my known information here: Paper UI stays empty / IO Error
Hi @matzR,
can you check the result of http://YourOpenHabIP:8080/rest/items and http://YourOpenHabIP:8080/rest/things please?
Yours wbuh
Same here (latest 2.5.4).
In the meantime I got a serious problem with this:
the connected node-red instance is not running anymore.
I prepare values from the inverter of my solar system and the power metering in nodered that is send to openhab afterwards.
For this I use the node-red-contrib-openhab2 node.
This node communicates over REST API.
It seems to query the openhab items at startup.
Due to the error in my openhab now I get
grafik
What I think is the result of
grafik
Due to this nodered is at full stop now.
As it is in control of the solar heater of the warm water heating system this system is off now.
So it costs money (I know, my personal problem).
I’ll try to bypass the openhab node and use mqtt to exchange values between nodered and openhab.
But I would be very thankful, if someone with expertise in deleting corrupt items in openhab jsondb can give me some support!
Tried this and get back JSON files with the items respectively things.
Which is I assume what is to be expected?
Hello, I also see this error, when I leave the Android App open on my tablet. That’s why I want to filter out this error as described here.
I run OpenHAB 2.5.4 in docker, so the file ā€œ/var/lib/openhab2/etc/org.ops4j.pax.logging.cfgā€ does not exist on my server.
I specified a conf, userdata and addons folder for the docker container, but I also could not find the file in these folders.
So how do I edit this file when running OpenHAB in docker?
edit: Found it :slight_smile:
It is located in the ā€œuserdata/etcā€ folder, so in my case it is
ā€œ/opt/openhab254/userdata/etc/org.ops4j.pax.logging.cfgā€
Since update ot 2.5.9-1 (from 2.5.8-1) the message comes up again:
2020-10-01 19:00:27.520 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_252]
at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:818) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:857) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:525) ~[bundleFile:9.4.20.v20190813]
at org.glassfish.jersey.servlet.internal.ResponseWriter$NonCloseableOutputStreamWrapper.write(ResponseWriter.java:325) ~[?:?]
at org.glassfish.jersey.message.internal.CommittingOutputStream.write(CommittingOutputStream.java:229) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$UnCloseableOutputStream.write(WriterInterceptorExecutor.java:299) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.ReaderWriter.writeTo(ReaderWriter.java:116) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.AbstractMessageReaderWriterProvider.writeTo(AbstractMessageReaderWriterProvider.java:79) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.InputStreamProvider.writeTo(InputStreamProvider.java:105) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.InputStreamProvider.writeTo(InputStreamProvider.java:60) ~[bundleFile:?]
… 53 more
at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:1.8.0_252]
at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:1.8.0_252]
at sun.nio.ch.IOUtil.write(IOUtil.java:148) ~[?:1.8.0_252]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:501) ~[?:1.8.0_252]
… 53 more
Can anybody ghelp me to fix
Stef
Nohing changed:
Platform information:
*Tinkerboard 2GB RAM
Debian Buster
java -version
Picked up JAVA_TOOL_OPTIONS: -Dgnu.io.rxtx.SerialPorts=/dev/tty96B0
openjdk version ā€œ1.8.0_252ā€
OpenJDK Runtime Environment (Zulu 8.46.0.225-CA-linux_aarch32hf) (build 1.8.0_252-b225)
OpenJDK Client VM (Zulu 8.46.0.225-CA-linux_aarch32hf) (build 25.252-b225, mixed mode, Evaluation)
Statements ā€œsince updateā€¦ā€ and ā€œnothing changedā€ are conflicting a bit.
In the first instance, close and restart your app/browser after restarting openHAB
Yep - korrekt since 2.5.8-1 without this problem
Sorry for not exactly precise
Stefan Heinz
Hinweis: Der Inhalt dieser eMail ist vertraulich und ausschließlich für den bezeichneten Adressaten bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser eMail sein sollten, setzen Sie sich bitte mit dem Absender der eMail oder unter der angegebenen Telefonnummer in Verbindung und vernichten Sie diese eMail auf Ihren Speichermedien.
Notice: The information contained in this email is confidential. It is intended solely for the addressee named above. If you are not the intended recipient, please notify the sender immediately and destroy this message on any media of yours.
Send mobile
what about a solution instead of an indoctrination?
takes a little bit more time but is the main goal of posting
  • for regular users! sorry for not been exactly accurate and don’t stoppung afterhearing and commenting
cheers Stef
Indoctrination? Advice for your problem will be based on info you supply, it’s up to you how well the overall process goes.
The last message I read was ā€œsince 2.5.8 without a problemā€. I appreciate there is a language barrier, but interpreted that as ā€œI no longer have a problemā€.
Information missing at the moment from my viewpoint. Did you reload your UI browser or app after the last openHAB reboot?
This is not an idle question to uhh ā€œindoctrinateā€ you, it’s because that error message is most often associated with a UI that is still trying to communicate with the ā€œoldā€ openHAB.
The available solution for that is to reload the UI to start fresh communication.
Any news here? Since updating to 2.5.9 stable this one spams my openhab.log
2020-10-13 20:12:10.614 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_212]
at java.io.OutputStream.write(OutputStream.java:75) ~[?:1.8.0_212]
... 53 more
at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:1.8.0_212]
at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:1.8.0_212]
at sun.nio.ch.IOUtil.write(IOUtil.java:148) ~[?:1.8.0_212]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:504) ~[?:1.8.0_212]
... 53 more
