Hi guys,
Can you suggest what could cause this error:
2019-09-02 18:16:17.981 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
Caused by: org.eclipse.jetty.io.EofException
Caused by: java.io.IOException: Broken pipe
OH seems to be working without any issues. I lately only added a new sensor data to sitemap, which should not cause this.
Reading in forums I suggested also an issue with Alexa? Tried to disable the skill but no change…
Also it doesn’t look like there is a problem with sitemap config.
Also all desired bindings are normally installed.
Tried to restart service, reboot machine. The computer is quite powerful, a lot more than my previous RPI3.
Do you have any other suggestions?
Thanks!
