@halloween
Can you test the alarm clock with 2.10.19-beta?
What do you mean with that?
I released 2.11.0 and started the rollout at 20%.
ā¢ Improve widgets and Tasker plugin.
ā¢ Show only the default Sitemap in the side menu. Thereās a new setting to show all Sitemaps there.
ā¢ Disable HTTP for new remote connections.
Please look out for any kind of bugs with icons on 2.11.8-beta. This version contains a code refactor of the icon code: https://github.com/openhab/openhab-android/pull/1731
Hi, i am on latest beta and using my config since long time. In the last time i could see a weird behaviour, my Android App connects always Witz remote server, even when i am at homeā¦
Any Idea?
@halloween Weād need an app log to check this. Also, the Android version of your device would be interesting.
I changed the MIUI ROM with Android 8.1 to Android 9 pixel rom on my redmi note 5 - now i only can connect with remote cloud service. I tried https and http connection. The phone of my wife with (i think) android 8.1 is still working with both types of connection.
How can i log the interesting things for you? Should i switch on the logging, then close (even from taskmanager in android) the app and restart it again with logging on?
Will try that, when iĀ“m at home on my private network.
Yeah, that approach sounds good.
Welcome to the openHAB forum.
If you ewant to become a programmer, youād better start reading the documentation. In there you will find how code is shared.
I need new beta to do this. I know about the meta thanks to shareit for pc sharing at shareitdownloat.net and itās really great. My data is shared very quickly and unlimited number of shares
With 2.11.15 beta i still donāt get local connection.
Edit: when i remove the app inside adguard, now it works. But i wanted to let it in adguard, but with no filtering, so that i could see the data volume the app is usingā¦
Since 2.11.16 it is working.
Sorry for posting in the beta thread.
Running 2.11.0
Some self made icons appear smaller, top left aligned instead of fitting like the standard icons.
This is observed only on the phone, samsung s10 with android10 os. It is not visible when running on a larger tablet screen, s3 tab.
Has this been seen by others as well?
Can you open a new thread for that? Please try the latest beta version as well and tell us the version of your openHAB server, the icon format and post one of the icons, that are wrongly aligned.
