Whenever I try to use the Android App for openHAB, I receive an error message: “HTTP Error: Ok”, I can’t see or open my sitemap. But I can see my device in My Openhab via PC. Any clues? What Information could I deliver, to figure it out?
What are your settings?
openHAB URL should look like: http://<openhab server ip>:8080
openHAB Remote URL should look like: https://my.openhab.org
Username should be your my.openhab login
Password should be your my.openhab password
The Security setting in openhab.cfg should be External
Hi Rich,
thanks for taking the time!
the URLs were as described, but I suffixed a “/openhab.app?sitemap=sitemapname”, maybe that was it. Have to start the Server again to check when I come home.
Username and Password is correct, Security Settings I will check, might be Internal.
I will post results here.
Cheers
Ingo
Hi Rich,
sometimes things are so easy, without the suffixes everything works fine now. Thank you very much!
Regards
Ingo
