Hello all!
I put this a local url in my android app.
http://192.168.1.200:8080/basicui/app?sitemap=default
I just get an error saying nothing found. Am I doing something wrong? Trying to test prior to creating a couple more sitemaps. I want to use this feature and put the 5 switches for my child’s room on a separate map. No security requirement just a separation .
hr3
(Harry)
August 9, 2018, 2:57pm
2
Is there at least one sitemap without errors? Check you log please.
sihui
(SiHui)
August 9, 2018, 4:33pm
3
Switching sitemaps is done the usual Android way: swipe from left to right and you will see all available sitemaps.
opus
(Jürgen Baginski)
August 9, 2018, 4:44pm
4
That URL would work in a browser. In the android app the local address should be like: " http://IP:8080 "
I am asking if you can point at a specific sitemap in the apps? Apparently, you can’t.
I don’t want to setup a reverse proxy for this. I was hoping it would work out the gate. The documents online lead me to believe it would.
opus
(Jürgen Baginski)
August 10, 2018, 6:04am
6
You can set the default sitemap in PaperUI, however that will affect all devices using BasicUI.
