Own Certificate Authority
sudo openhabian-config
openhab related >reverse proxy
Client configuration
this works with setup via openhabian-config
sudo -s
openssl pkcs12 -export -out /etc/ssl/certificate.pfx -inkey /etc/ssl/certs/openhab.key -in /etc/ssl/certs/openhab.crt
password which will be needed when adding certificate to android device.
You can download certificate via any SCP client(windows WinSCP) /etc/ssl/certificate.pfx
certificate.pfx can be used for android authentication.
remote url in android device https://YOURHOUSEIP-OR-HOST
credits
Create a .pfx/.p12 Certificate File Using OpenSSL - SSL.com
MY PROBLEM WAS
I get error “ssl handshake failed - maybe you need a valid certificate”
What i did
I set-up reverse proxy Nginx
I basicly set IP with my internet provider IP (WAN)
I can connect to https://IP with browser
Everything is working okay but I can not get android app to work with
remote url: https://IP:443
SSL client sertificate :none
I dont know how to get that certificate i thing that could be the problem
