Do the old jars work? I didn’t make any significant changes to that code recently. Hoping its not a regression.
I didn’t keep any of the old jars. But I thought power and volume worked.
I will restart the binding to see if it has any effect.
ShieldTV looks like it’s still working…
2023-03-03 11:35:50.779 [TRACE] [tocol.googletv.GoogleTVMessageParser] - livingroom - Received GoogleTV message - Length: 5 Message: c202020800
2023-03-03 11:35:50.779 [TRACE] [l.googletv.GoogleTVConnectionManager] - livingroom - Setting power to false
2023-03-03 11:35:50.793 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ShieldTV_LIV_POWER' changed from NULL to OFF
2023-03-03 11:37:39.433 [TRACE] [tocol.googletv.GoogleTVMessageParser] - livingroom - Received GoogleTV message - Length: 5 Message: c202020801
2023-03-03 11:37:39.434 [TRACE] [l.googletv.GoogleTVConnectionManager] - livingroom - Setting power to true
2023-03-03 11:37:39.435 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ShieldTV_LIV_POWER' changed from OFF to ON
2023-03-03 11:38:17.814 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'ShieldTV_LIV_POWER' received command OFF
2023-03-03 11:38:17.815 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'ShieldTV_LIV_POWER' predicted to become OFF
2023-03-03 11:38:17.818 [TRACE] [.androidtv.internal.AndroidTVHandler] - livingroom - Command received at handler: power OFF
2023-03-03 11:38:17.819 [TRACE] [l.googletv.GoogleTVConnectionManager] - livingroom - Command received: power
2023-03-03 11:38:17.819 [TRACE] [l.googletv.GoogleTVConnectionManager] - livingroom - Raw GoogleTV command decodes as: 065204081a1003
2023-03-03 11:38:17.820 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ShieldTV_LIV_POWER' changed from ON to OFF
2023-03-03 11:38:18.600 [TRACE] [l.googletv.GoogleTVConnectionManager] - livingroom - GoogleTV Message: 5 05c202020800
2023-03-03 11:38:18.600 [TRACE] [tocol.googletv.GoogleTVMessageParser] - livingroom - Received GoogleTV message - Length: 5 Message: c202020800
2023-03-03 11:38:18.601 [TRACE] [l.googletv.GoogleTVConnectionManager] - livingroom - Setting power to false
The thing is coming to a full online state right?
@morph166955 I have reinstalled openhab from scratch. Got everything working again except the Shield which stays offline:
2023-03-04 13:46:09.389 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:46:09.390 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:46:09.394 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:46:09.395 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:46:12.216 [TRACE] [.androidtv.internal.AndroidTVHandler] - 763c047c - Command received at handler: pincode REQUEST
2023-03-04 13:46:12.217 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Command received: pincode
2023-03-04 13:46:12.217 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - ShieldTV PIN Process Started
2023-03-04 13:46:12.217 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080a120308cd08
2023-03-04 13:46:12.257 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080a120308cf08180a
2023-03-04 13:46:12.258 [DEBUG] [tocol.shieldtv.ShieldTVMessageParser] - PIN Process Started
2023-03-04 13:46:14.390 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:46:14.391 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:46:14.393 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:46:14.393 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:46:19.391 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:46:19.392 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:46:19.393 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:46:19.394 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:46:24.392 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:46:24.393 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:46:24.394 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:46:24.395 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:46:29.393 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:46:29.394 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:46:29.395 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:46:29.396 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:46:34.394 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:46:34.395 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:46:34.396 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:46:34.397 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:46:39.395 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:46:39.396 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:46:39.398 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:46:39.398 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:46:44.396 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:46:44.397 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:46:44.398 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:46:44.399 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:46:49.397 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:46:49.398 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:46:49.441 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:46:49.442 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:46:54.398 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:46:54.399 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:46:54.451 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080b120308cd08
2023-03-04 13:46:54.452 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 08f30712020805
2023-03-04 13:46:54.452 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:46:54.453 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:46:54.453 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 08f10712020800
2023-03-04 13:46:54.453 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 08ec0712020806
2023-03-04 13:46:54.453 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080b124708b51012420a06534849454c44120d3139322e3136382e322e323338189b462210653162396135373937363363303437632a0b61726d656162692d7637612a0761726d65616269180b
2023-03-04 13:46:54.454 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Longer Hostname Reply
2023-03-04 13:46:54.454 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Hostname: SHIELD
2023-03-04 13:46:54.454 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - ipAddress: 192.168.2.238
2023-03-04 13:46:54.454 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - deviceId: e1b9a579763c047c
2023-03-04 13:46:54.455 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - arch: armeabi-v7a,armeabi
2023-03-04 13:46:54.455 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - readerThreadJob received ffffffff. Disconnecting hard.
2023-03-04 13:46:54.456 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Attempting to reconnect to the ShieldTV
2023-03-04 13:46:54.456 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Disconnecting ShieldTV
2023-03-04 13:46:54.457 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Command sender thread exiting
2023-03-04 13:46:54.463 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Opening ShieldTV SSL connection to 192.168.2.238:8987
2023-03-04 13:46:54.491 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - Assuming server certificate is valid
2023-03-04 13:46:54.493 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - Subject DN: C=US, O=Nvidia, OU=Nvidia, CN=nvbeyonder/sif/sif/SHIELD Android TV
2023-03-04 13:46:54.495 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - Issuer DN: C=US, O=Nvidia, OU=Nvidia, CN=nvbeyonder/sif/sif/SHIELD Android TV
2023-03-04 13:46:54.496 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - Serial number: 1589375708311
2023-03-04 13:46:54.529 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Message reader thread started
2023-03-04 13:46:54.529 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Starting ShieldTV keepalive job with interval 5
2023-03-04 13:46:54.529 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Message reader thread exiting
2023-03-04 13:46:54.530 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Command sender thread started
2023-03-04 13:46:54.530 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 0801121a0801121073616d73756e6720534d2d4739393855180128fbff04
2023-03-04 13:46:54.537 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080a121308e807120e08011206534849454c4418d7fd04180a
2023-03-04 13:46:54.538 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Shield Hostname: 534849454c44 12
2023-03-04 13:46:54.539 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Shield Hostname Encoded: SHIELD
2023-03-04 13:46:59.529 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:46:59.530 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:46:59.580 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:46:59.580 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:47:04.530 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:47:04.531 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:47:04.590 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:47:04.591 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:47:09.531 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:47:09.532 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:47:09.534 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:47:09.576 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:47:10.889 [TRACE] [.androidtv.internal.AndroidTVHandler] - 763c047c - Command received at handler: pincode 841622
2023-03-04 13:47:10.890 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Command received: pincode
2023-03-04 13:47:10.890 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - ShieldTV PIN Process Started
2023-03-04 13:47:10.890 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080a121f08d108121a0a06383431363232121036646564646461326639366635646261
2023-03-04 13:47:14.532 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:47:14.533 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:47:14.535 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:47:14.535 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:47:19.533 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:47:19.534 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:47:19.535 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:47:19.536 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:47:24.534 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:47:24.535 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:47:24.537 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:47:24.576 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:47:29.535 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:47:29.536 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:47:29.538 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:47:29.616 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:47:34.536 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:47:34.537 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:47:34.538 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:47:34.539 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:47:39.537 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:47:39.538 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:47:39.540 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:47:39.540 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:47:44.538 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:47:44.539 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:47:44.540 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:47:44.541 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:47:49.539 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:47:49.540 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:47:49.541 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:47:49.541 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:47:54.540 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:47:54.540 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:47:54.542 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:47:54.542 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:47:59.541 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:47:59.541 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:47:59.586 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:47:59.586 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
@morph166955 by sending a new PIN request I get a the new pin. Here the log after the second attempt:
2023-03-04 13:57:58.493 [TRACE] [.androidtv.internal.AndroidTVHandler] - 763c047c - Command received at handler: pincode REQUEST
2023-03-04 13:57:58.493 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Command received: pincode
2023-03-04 13:57:58.494 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - ShieldTV PIN Process Started
2023-03-04 13:57:58.494 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080a120308cd08
2023-03-04 13:57:58.503 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080a120308cf08180a
2023-03-04 13:57:58.504 [DEBUG] [tocol.shieldtv.ShieldTVMessageParser] - PIN Process Started
2023-03-04 13:58:00.475 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:58:00.476 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:58:00.477 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:58:00.477 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:58:05.476 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:58:05.476 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:58:05.478 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:58:05.478 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:58:10.477 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:58:10.477 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:58:10.478 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:58:10.478 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:58:15.477 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:58:15.478 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:58:15.479 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:58:15.479 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:58:20.478 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:58:20.478 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:58:20.538 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:58:20.538 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:58:25.478 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:58:25.479 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:58:25.521 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:58:25.521 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:58:30.479 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:58:30.479 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:58:30.481 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:58:30.481 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:58:35.480 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 13:58:35.480 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 13:58:35.528 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080b120308cd08
2023-03-04 13:58:35.528 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 08f30712020805
2023-03-04 13:58:35.528 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 08f10712020800
2023-03-04 13:58:35.528 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 08ec0712020806
2023-03-04 13:58:35.528 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 13:58:35.529 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 13:58:35.529 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080b124708b51012420a06534849454c44120d3139322e3136382e322e323338189b462210653162396135373937363363303437632a0b61726d656162692d7637612a0761726d65616269180b
2023-03-04 13:58:35.529 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Longer Hostname Reply
2023-03-04 13:58:35.529 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Hostname: SHIELD
2023-03-04 13:58:35.529 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - ipAddress: 192.168.2.238
2023-03-04 13:58:35.529 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - deviceId: e1b9a579763c047c
2023-03-04 13:58:35.530 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - arch: armeabi-v7a,armeabi
2023-03-04 13:58:35.530 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - readerThreadJob received ffffffff. Disconnecting hard.
2023-03-04 13:58:35.530 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Attempting to reconnect to the ShieldTV
2023-03-04 13:58:35.530 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Disconnecting ShieldTV
2023-03-04 13:58:35.530 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Command sender thread exiting
2023-03-04 13:58:35.531 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Opening ShieldTV SSL connection to 192.168.2.238:8987
2023-03-04 13:58:35.556 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - Assuming server certificate is valid
2023-03-04 13:58:35.557 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - Subject DN: C=US, O=Nvidia, OU=Nvidia, CN=nvbeyonder/sif/sif/SHIELD Android TV
2023-03-04 13:58:35.557 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - Issuer DN: C=US, O=Nvidia, OU=Nvidia, CN=nvbeyonder/sif/sif/SHIELD Android TV
2023-03-04 13:58:35.557 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - Serial number: 1589375708311
2023-03-04 13:58:35.564 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Starting ShieldTV keepalive job with interval 5
2023-03-04 13:58:35.564 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Message reader thread started
2023-03-04 13:58:35.565 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Message reader thread exiting
2023-03-04 13:58:35.565 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Command sender thread started
2023-03-04 13:58:35.565 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 0801121a0801121073616d73756e6720534d2d4739393855180128fbff04
2023-03-04 13:58:35.603 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080a121308e807120e08011206534849454c4418d7fd04180a
Thanks!
With the new jar I could switch the TV on and off. But now the Thing no longer goes online. Both when I send WOL and when I switch on the TV manually, the Thing stays in offline mode.
This is from my last atempt inputting a wrong PIN. No error message on screen:
2023-03-04 14:13:19.775 [TRACE] [.androidtv.internal.AndroidTVHandler] - 763c047c - Command received at handler: pincode REQUEST
2023-03-04 14:13:19.776 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Command received: pincode
2023-03-04 14:13:19.776 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - ShieldTV PIN Process Started
2023-03-04 14:13:19.776 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080a120308cd08
2023-03-04 14:13:19.790 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080a120308cf08180a
2023-03-04 14:13:19.790 [DEBUG] [tocol.shieldtv.ShieldTVMessageParser] - PIN Process Started
2023-03-04 14:13:24.510 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 14:13:24.511 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 14:13:24.563 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 14:13:24.564 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 14:13:29.511 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 14:13:29.512 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 14:13:29.656 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 14:13:29.656 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 14:13:34.512 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 14:13:34.513 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 14:13:34.567 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 14:13:34.567 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 14:13:39.513 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 14:13:39.513 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 14:13:39.584 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 14:13:39.584 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 14:13:44.514 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 14:13:44.514 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 14:13:44.559 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 14:13:44.559 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 14:13:49.514 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 14:13:49.515 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 14:13:49.566 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 14:13:49.566 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 14:13:54.515 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 14:13:54.516 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 14:13:54.570 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 14:13:54.571 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 14:13:59.516 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 14:13:59.516 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 14:13:59.648 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 14:13:59.648 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 14:14:04.517 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 14:14:04.663 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 14:14:04.665 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 14:14:04.665 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 14:14:09.664 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 14:14:09.664 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 14:14:09.704 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 14:14:09.704 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 14:14:14.664 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 14:14:14.665 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 14:14:14.783 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 14:14:14.783 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 14:14:14.792 [TRACE] [.androidtv.internal.AndroidTVHandler] - 763c047c - Command received at handler: pincode 000000
2023-03-04 14:14:14.792 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Command received: pincode
2023-03-04 14:14:14.792 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - ShieldTV PIN Process Started
2023-03-04 14:14:14.793 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080a121f08d108121a0a06303030303030121036646564646461326639366635646261
2023-03-04 14:14:14.795 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080a121208b510120d0802120957726f6e672050494e180a
2023-03-04 14:14:14.796 [DEBUG] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Unknown payload received. 080a121208b510120d0802120957726f6e672050494e180a
2023-03-04 14:14:19.665 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 14:14:19.666 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 14:14:19.766 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 14:14:19.766 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 14:14:24.666 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 14:14:24.666 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 14:14:24.707 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 14:14:24.707 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 14:14:29.667 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 14:14:29.667 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 14:14:29.713 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 14:14:29.714 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 14:14:34.667 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 14:14:34.720 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 14:14:34.721 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 14:14:34.721 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 14:14:39.720 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Sending ShieldTV keepalive query
2023-03-04 14:14:39.720 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 14:14:39.767 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 080b120308cd08
2023-03-04 14:14:39.767 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 08f30712020805
2023-03-04 14:14:39.768 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 08f10712020800
2023-03-04 14:14:39.768 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 08ec0712020806
2023-03-04 14:14:39.768 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 14:14:39.768 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Canceling ShieldTV scheduled reconnect job.
2023-03-04 14:14:39.769 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Received ShieldTV message from: SHIELD - Message: 080b124708b51012420a06534849454c44120d3139322e3136382e322e323338189b462210653162396135373937363363303437632a0b61726d656162692d7637612a0761726d65616269180b
2023-03-04 14:14:39.769 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Longer Hostname Reply
2023-03-04 14:14:39.769 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - Hostname: SHIELD
2023-03-04 14:14:39.769 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - ipAddress: 192.168.2.238
2023-03-04 14:14:39.769 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - deviceId: e1b9a579763c047c
2023-03-04 14:14:39.770 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 763c047c - arch: armeabi-v7a,armeabi
2023-03-04 14:14:39.770 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - readerThreadJob received ffffffff. Disconnecting hard.
2023-03-04 14:14:39.770 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Attempting to reconnect to the ShieldTV
2023-03-04 14:14:39.771 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Disconnecting ShieldTV
2023-03-04 14:14:39.772 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Command sender thread exiting
2023-03-04 14:14:39.773 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Opening ShieldTV SSL connection to 192.168.2.238:8987
2023-03-04 14:14:39.800 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - Assuming server certificate is valid
2023-03-04 14:14:39.801 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - Subject DN: C=US, O=Nvidia, OU=Nvidia, CN=nvbeyonder/sif/sif/SHIELD Android TV
2023-03-04 14:14:39.801 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - Issuer DN: C=US, O=Nvidia, OU=Nvidia, CN=nvbeyonder/sif/sif/SHIELD Android TV
2023-03-04 14:14:39.802 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - Serial number: 1589375708311
2023-03-04 14:14:39.808 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Message reader thread started
2023-03-04 14:14:39.808 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Starting ShieldTV keepalive job with interval 5
2023-03-04 14:14:39.809 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Message reader thread exiting
2023-03-04 14:14:39.809 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Command sender thread started
2023-03-04 14:14:39.809 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 763c047c - Raw ShieldTV command decodes as: 0801121a0801121073616d73756e6720534d2d4739393855180128fbff04
@Norixone I looked through your logs and I’ll admit it’s a little confusing. The shield for no reason I’m seeing isn’t logging you in. Usually we get a specific message that the binding sees as a login.
Can you confirm the shield model and OS version for me? I’m seeing some other things in the logs which aren’t consistent with what I’m used to seeing. For example, on the line here:
I’m used to seeing “arm64-v8a,armeabi-v7a,armeabi” come back. It’s subtle, but it could indicate a small difference between different versions that I haven’t run into.
Glad to see we are one step closer. Can you shoot me the trace log so I can see what it is/isn’t doing?
The model is Shield Tv 2019 (P3430) running on android 11 and latest firmawre 9.1.1
I have just done a total hard reset of the Shield and found that the system was somehow overlayed in the sence the home screen was not up to date and some functions like the beta for “same frame as video” have now gone. Definetly something went very wrong during the last up-date. I have then tried again the binding and discovered that it is no longer showing the two options: Shield and Google Tv. Only Shield shows up now in the autodiscavery. I am doing some further testing before giving up and moving on.
When I select the Shield in the autodiscavery, I get the following message:“GoogleTV: Error opening GoogleTV SSL connection. Check log. | ShieldTV: Initializing”. This is what I get in the event log:
2023-03-04 16:56:20.745 [INFO ] [openhab.event.InboxRemovedEvent ] - Discovery Result with UID ‘androidtv:shieldtv:74046a0a’ has been removed.
2023-03-04 16:56:20.753 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘androidtv:shieldtv:74046a0a’ changed from UNINITIALIZED to INITIALIZING
2023-03-04 16:56:20.759 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘androidtv:shieldtv:74046a0a’ changed from INITIALIZING to OFFLINE: Protocols Starting
2023-03-04 16:56:21.358 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘androidtv:shieldtv:74046a0a’ changed from OFFLINE: Protocols Starting to OFFLINE: GoogleTV: Error opening GoogleTV SSL connection. Check log.
2023-03-04 16:56:21.598 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘androidtv:shieldtv:74046a0a’ changed from OFFLINE: GoogleTV: Error opening GoogleTV SSL connection. Check log. to OFFLINE: GoogleTV: Error opening GoogleTV SSL connection. Check log. | ShieldTV: Initializing
2023-03-04 16:58:01.612 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘androidtv:shieldtv:74046a0a’ changed from OFFLINE: GoogleTV: Error opening GoogleTV SSL connection. Check log. | ShieldTV: Initializing to OFFLINE: GoogleTV: Error opening GoogleTV SSL connection. Check log. | ShieldTV: reconnecting
2023-03-04 16:58:01.648 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘androidtv:shieldtv:74046a0a’ changed from OFFLINE: GoogleTV: Error opening GoogleTV SSL connection. Check log. | ShieldTV: reconnecting to OFFLINE: GoogleTV: Error opening GoogleTV SSL connection. Check log. | ShieldTV: Initializing
TRACE LOGS:
2023-03-04 17:00:21.457 [DEBUG] [l.googletv.GoogleTVConnectionManager] - 74046a0a - Opening GoogleTV SSL connection to 192.168.2.238:6466
2023-03-04 17:00:21.482 [DEBUG] [l.googletv.GoogleTVConnectionManager] - Assuming server certificate is valid
2023-03-04 17:00:21.484 [TRACE] [l.googletv.GoogleTVConnectionManager] - Subject DN: CN=atvremote/sif/sif/SHIELD Android TV/00:04:4B:F1:A8:38
2023-03-04 17:00:21.485 [TRACE] [l.googletv.GoogleTVConnectionManager] - Issuer DN: CN=atvremote/sif/sif/SHIELD Android TV/00:04:4B:F1:A8:38
2023-03-04 17:00:21.485 [TRACE] [l.googletv.GoogleTVConnectionManager] - Serial number: 1665976001535
2023-03-04 17:00:21.486 [DEBUG] [l.googletv.GoogleTVConnectionManager] - Returning empty certificate for getAcceptedIssuers
2023-03-04 17:00:21.494 [INFO ] [l.googletv.GoogleTVConnectionManager] - 74046a0a - Error opening GoogleTV SSL connection to 192.168.2.238:6466 Connection reset by peer (Write failed)
2023-03-04 17:00:21.495 [DEBUG] [l.googletv.GoogleTVConnectionManager] - 74046a0a - Disconnecting GoogleTV
2023-03-04 17:00:21.495 [DEBUG] [l.googletv.GoogleTVConnectionManager] - 74046a0a - Scheduling GoogleTV connection retry in 60 seconds
2023-03-04 17:00:21.691 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:00:21.693 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:00:21.695 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:00:21.695 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:00:26.692 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:00:26.694 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:00:26.695 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:00:26.696 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:00:31.694 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:00:31.694 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:00:31.696 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:00:31.697 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:00:36.694 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:00:36.695 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:00:36.697 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:00:36.698 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:00:41.695 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:00:41.696 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:00:41.698 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:00:41.698 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:00:46.696 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:00:46.697 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:00:46.738 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:00:46.738 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:00:46.924 [TRACE] [.androidtv.internal.AndroidTVHandler] - 74046a0a - Command received at handler: pincode REFRESH
2023-03-04 17:00:46.925 [TRACE] [l.googletv.GoogleTVConnectionManager] - 74046a0a - Command received: pincode
2023-03-04 17:00:51.697 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:00:51.698 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:00:51.793 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:00:51.794 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:00:56.698 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:00:56.699 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:00:56.750 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:00:56.750 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:01:01.699 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:01:01.700 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:01:01.748 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:01:01.748 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:01:06.700 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:01:06.700 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:01:06.794 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:01:06.795 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:01:06.835 [TRACE] [.androidtv.internal.AndroidTVHandler] - 74046a0a - Command received at handler: pincode REQUEST
2023-03-04 17:01:06.836 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Command received: pincode
2023-03-04 17:01:06.836 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - ShieldTV PIN Process Started
2023-03-04 17:01:06.836 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080a120308cd08
2023-03-04 17:01:06.858 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080a120308cf08180a
2023-03-04 17:01:06.859 [DEBUG] [tocol.shieldtv.ShieldTVMessageParser] - PIN Process Started
2023-03-04 17:01:11.701 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:01:11.701 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:01:11.803 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:01:11.803 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:01:16.701 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:01:16.702 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:01:16.748 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:01:16.749 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:01:21.496 [DEBUG] [l.googletv.GoogleTVConnectionManager] - 74046a0a - Opening GoogleTV SSL connection to 192.168.2.238:6466
2023-03-04 17:01:21.522 [DEBUG] [l.googletv.GoogleTVConnectionManager] - Assuming server certificate is valid
2023-03-04 17:01:21.522 [TRACE] [l.googletv.GoogleTVConnectionManager] - Subject DN: CN=atvremote/sif/sif/SHIELD Android TV/00:04:4B:F1:A8:38
2023-03-04 17:01:21.523 [TRACE] [l.googletv.GoogleTVConnectionManager] - Issuer DN: CN=atvremote/sif/sif/SHIELD Android TV/00:04:4B:F1:A8:38
2023-03-04 17:01:21.523 [TRACE] [l.googletv.GoogleTVConnectionManager] - Serial number: 1665976001535
2023-03-04 17:01:21.523 [DEBUG] [l.googletv.GoogleTVConnectionManager] - Returning empty certificate for getAcceptedIssuers
2023-03-04 17:01:21.531 [INFO ] [l.googletv.GoogleTVConnectionManager] - 74046a0a - Error opening GoogleTV SSL connection to 192.168.2.238:6466 Connection reset by peer (Write failed)
2023-03-04 17:01:21.531 [DEBUG] [l.googletv.GoogleTVConnectionManager] - 74046a0a - Disconnecting GoogleTV
2023-03-04 17:01:21.532 [DEBUG] [l.googletv.GoogleTVConnectionManager] - 74046a0a - Scheduling GoogleTV connection retry in 60 seconds
2023-03-04 17:01:21.702 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:01:21.703 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:01:21.744 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080b120308cd08
2023-03-04 17:01:21.744 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 08f30712020805
2023-03-04 17:01:21.745 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:01:21.745 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 08f10712020800
2023-03-04 17:01:21.745 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:01:21.745 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 08ec0712020806
2023-03-04 17:01:21.747 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080b124708b51012420a06534849454c44120d3139322e3136382e322e323338189b462210316139313931336437343034366130612a0b61726d656162692d7637612a0761726d65616269180b
2023-03-04 17:01:21.747 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Longer Hostname Reply
2023-03-04 17:01:21.748 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Hostname: SHIELD
2023-03-04 17:01:21.748 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - ipAddress: 192.168.2.238
2023-03-04 17:01:21.748 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - deviceId: 1a91913d74046a0a
2023-03-04 17:01:21.749 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - arch: armeabi-v7a,armeabi
2023-03-04 17:01:21.749 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - readerThreadJob received ffffffff. Disconnecting hard.
2023-03-04 17:01:21.750 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Attempting to reconnect to the ShieldTV
2023-03-04 17:01:21.750 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Disconnecting ShieldTV
2023-03-04 17:01:21.751 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Command sender thread exiting
2023-03-04 17:01:21.753 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Opening ShieldTV SSL connection to 192.168.2.238:8987
2023-03-04 17:01:21.780 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - Assuming server certificate is valid
2023-03-04 17:01:21.782 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - Subject DN: C=US, O=Nvidia, OU=Nvidia, CN=nvbeyonder/sif/sif/SHIELD Android TV
2023-03-04 17:01:21.784 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - Issuer DN: C=US, O=Nvidia, OU=Nvidia, CN=nvbeyonder/sif/sif/SHIELD Android TV
2023-03-04 17:01:21.784 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - Serial number: 1677941504649
2023-03-04 17:01:21.793 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Message reader thread started
2023-03-04 17:01:21.794 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Starting ShieldTV keepalive job with interval 5
2023-03-04 17:01:21.794 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Command sender thread started
2023-03-04 17:01:21.794 [DEBUG] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Message reader thread exiting
2023-03-04 17:01:21.794 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 0801121a0801121073616d73756e6720534d2d4739393855180128fbff04
2023-03-04 17:01:21.829 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080a121308e807120e08011206534849454c4418d7fd04180a
2023-03-04 17:01:21.830 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Shield Hostname: 534849454c44 12
2023-03-04 17:01:21.831 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Shield Hostname Encoded: SHIELD
2023-03-04 17:01:26.795 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:01:26.795 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:01:26.853 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:01:26.854 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:01:31.795 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:01:31.796 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:01:31.839 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:01:31.839 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:01:36.796 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:01:36.797 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:01:36.846 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:01:36.846 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:01:41.797 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:01:41.798 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:01:41.953 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:01:41.954 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:01:46.798 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:01:46.799 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:01:46.850 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:01:46.850 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:01:51.799 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:01:51.800 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:01:51.849 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:01:51.849 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:01:56.800 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:01:56.800 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:01:56.894 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:01:56.895 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:02:01.801 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:02:01.801 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:02:01.851 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:02:01.851 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:02:04.736 [TRACE] [.androidtv.internal.AndroidTVHandler] - 74046a0a - Command received at handler: pincode 535389
2023-03-04 17:02:04.737 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Command received: pincode
2023-03-04 17:02:04.737 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - ShieldTV PIN Process Started
2023-03-04 17:02:04.737 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080a121f08d108121a0a06353335333839121036646564646461326639366635646261
2023-03-04 17:02:06.802 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:02:06.802 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:02:06.849 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:02:06.850 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:02:11.802 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:02:11.803 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:02:11.955 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:02:11.956 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:02:16.803 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:02:16.804 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:02:16.851 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:02:16.852 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:02:21.532 [DEBUG] [l.googletv.GoogleTVConnectionManager] - 74046a0a - Opening GoogleTV SSL connection to 192.168.2.238:6466
2023-03-04 17:02:21.560 [DEBUG] [l.googletv.GoogleTVConnectionManager] - Assuming server certificate is valid
2023-03-04 17:02:21.560 [TRACE] [l.googletv.GoogleTVConnectionManager] - Subject DN: CN=atvremote/sif/sif/SHIELD Android TV/00:04:4B:F1:A8:38
2023-03-04 17:02:21.561 [TRACE] [l.googletv.GoogleTVConnectionManager] - Issuer DN: CN=atvremote/sif/sif/SHIELD Android TV/00:04:4B:F1:A8:38
2023-03-04 17:02:21.561 [TRACE] [l.googletv.GoogleTVConnectionManager] - Serial number: 1665976001535
2023-03-04 17:02:21.561 [DEBUG] [l.googletv.GoogleTVConnectionManager] - Returning empty certificate for getAcceptedIssuers
2023-03-04 17:02:21.568 [INFO ] [l.googletv.GoogleTVConnectionManager] - 74046a0a - Error opening GoogleTV SSL connection to 192.168.2.238:6466 Connection reset by peer (Write failed)
2023-03-04 17:02:21.569 [DEBUG] [l.googletv.GoogleTVConnectionManager] - 74046a0a - Disconnecting GoogleTV
2023-03-04 17:02:21.569 [DEBUG] [l.googletv.GoogleTVConnectionManager] - 74046a0a - Scheduling GoogleTV connection retry in 60 seconds
2023-03-04 17:02:21.804 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:02:21.805 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:02:21.931 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:02:21.931 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:02:22.681 [TRACE] [.androidtv.internal.AndroidTVHandler] - 74046a0a - Command received at handler: pincode 535389
2023-03-04 17:02:22.681 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Command received: pincode
2023-03-04 17:02:22.681 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - ShieldTV PIN Process Started
2023-03-04 17:02:22.682 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080a121f08d108121a0a06353335333839121036646564646461326639366635646261
2023-03-04 17:02:26.805 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:02:26.806 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:02:26.807 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:02:26.808 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:02:31.806 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:02:31.807 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:02:31.808 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:02:31.809 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:02:36.807 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:02:36.807 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:02:36.851 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:02:36.851 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
2023-03-04 17:02:41.808 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Sending ShieldTV keepalive query
2023-03-04 17:02:41.808 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Raw ShieldTV command decodes as: 080028fae0a6c0d130
2023-03-04 17:02:41.857 [TRACE] [tocol.shieldtv.ShieldTVMessageParser] - 74046a0a - Received ShieldTV message from: SHIELD - Message: 080028fae0a6c0d130
2023-03-04 17:02:41.857 [TRACE] [l.shieldtv.ShieldTVConnectionManager] - 74046a0a - Canceling ShieldTV scheduled reconnect job.
@morph166955 could you please share an older binding? I would like to try it to see if it works.
I’ll grab a jar in a few and push it back up. For google, make sure google video is installed and updated. They made some major changes back in November.
Second question, does the nvidia shield app work from your phone to the shield?
This is the log when I switch on TV manually:
> 2023-03-04 18:04:17.225 [DEBUG] [l.googletv.GoogleTVConnectionManager] - 70C94E569D06 - Scheduling GoogleTV connection retry in 5 seconds
> 2023-03-04 18:04:22.226 [DEBUG] [l.googletv.GoogleTVConnectionManager] - 70C94E569D06 - Opening GoogleTV SSL connection to fe80:0:0:0:72af:24ff:fe14:24b4:6466
> 2023-03-04 18:04:22.228 [INFO ] [l.googletv.GoogleTVConnectionManager] - 70C94E569D06 - Error opening GoogleTV SSL connection to fe80:0:0:0:72af:24ff:fe14:24b4:6466 Invalid argument or cannot assign requested address
> 2023-03-04 18:04:22.229 [DEBUG] [l.googletv.GoogleTVConnectionManager] - 70C94E569D06 - Disconnecting GoogleTV
BTW: I have temporarely set reconnect to 5s.
Autodiscovery and pair process was OK.
Ah! IPv6! Lol I have done 0 IPv6 testing on this. Does it work with IPv4?
Aahhh, this was from Auto-Discovery ![]()
Changed Host-Name now to IP4 and Thing did go immediately to Online ![]()
Only thing I’m waiting now is switching the Apps.
Interesting. Its supposed to only pick IPv4 addresses from discovery. Ill check that.
App changing is on the list. The code is there, I just haven’t nailed down the command structure yet to do it. It’s not in the app so I can’t just capture and mirror. Once I figure that out I’ll gladly add it. Volume control too.
