Announce new HomeKit client binding
The current version of the binding does not support video. The reason is that OH does not have a dedicated Item type for video or any other media. It only has the standard Switch, Dimmer, String, Number, Color, Contact item types. But if OH would have such a media item type, then we could eventually use it.
Thanks for quick reply. Is it possible to get the snapshot from camera and use that in image type?
Short answer is no.
Longer answer is that we could perhaps make some experiments, if you are willing to be a test guinea pig. But we would need to get your system running on OH v5.1 first, so such testing would not be without effort or risk to you. And in any case I cannot guarantee 100% if the tests will be positive.
Hi, i m on 5.1 v. I can help with testing. What i m thinking is if we can get the updated snapshot based on the event , say on doorbell press or i m able to refresh the snapshot on demand.
I have few aqara cameras too that are homekit enabled. So far I have not added them in homekit binding. So I m not sure what channels show up for them
Amin
P.S. I dont have apple device if anything is needed from that.
It is not.
Brilliant. Before we start, can you please disable the camera thing in the Homekit binding, then enable trace logging on this binding, then reenable the thing, and finally post the log entry containing the ‘GET /accessories’ request’s ‘HTTP 200 OK’ response.
Please find below the log:
-01-11 16:48:59.957 [DEBUG] [nternal.hapservices.PairVerifyClient] - Pair-Verify M4: Confirm validation; derive session keys
2026-01-11 16:48:59.959 [TRACE] [nternal.hapservices.PairVerifyClient] -
 - 0x06: 04 {1}
2026-01-11 16:48:59.963 [TRACE] [mekit.internal.transport.IpTransport] - setSessionKeys()
2026-01-11 16:48:59.966 [TRACE] [mekit.internal.transport.IpTransport] - setSessionKeys() org.openhab.binding.homekit.internal.session.SecureSession@31a3b01f
2026-01-11 16:48:59.967 [DEBUG] [.handler.HomekitBaseAccessoryHandler] - homekit:accessory:b053d8d1b141 restored pairing was verified
2026-01-11 16:49:01.968 [TRACE] [.handler.HomekitBaseAccessoryHandler] - homekit:accessory:b053d8d1b141 throttling call for PT1.999970469S to respect minimum interval
2026-01-11 16:49:03.970 [TRACE] [mekit.internal.transport.IpTransport] - HTTP request:
GET /accessories HTTP/1.1
Host: Doorbell\032Repeater-F667._hap._tcp.local.:39359
2026-01-11 16:49:04.237 [TRACE] [mekit.internal.transport.IpTransport] - HTTP response:
HTTP/1.1 200 OK
Transfer-Encoding: chunked
Content-Type: application/hap+json
3AF
{"accessories":[{"aid":1,"services":[{"iid":1,"type":"3E","primary":false,"hidden":false,"characteristics":[{"iid":65537,"type":"14","format":"bool","perms":["pw"]},{"iid":65538,"type":"20","format":"string","value":"Aqara","perms":["pr"],"ev":false,"enc":false},{"iid":65539,"type":"21","format":"string","value":"CH-C11E","perms":["pr"],"ev":false,"enc":false},{"iid":65540,"type":"23","format":"string","value":"Doorbell Repeater-F667","perms":["pr"],"ev":false,"enc":false},{"iid":65541,"type":"30","format":"string","value":"a9275cbecbe8f667","perms":["pr"],"ev":false,"enc":false},{"iid":65542,"type":"52","format":"string","value":"4.5.20","perms":["pr","ev"],"ev":false,"enc":false},{"iid":65543,"type":"53","format":"string","value":"1.1","perms":["pr"],"ev":false,"enc":false},{"iid":65544,"type":"34AB8811-AC7F-4340-BAC3-FD6A85F9943B","format":"string","value":"6.3;e6e82026","perms":["pr","hd"],"ev":false,"enc":false},{"iid":65545
3FB
,"type":"220","format":"data","value":"xDsGO6gtae8=","perms":["pr"],"ev":false,"enc":false,"maxDataLen":8},{"iid":65546,"type":"A6","format":"uint32","value":0,"perms":["pr","ev"],"ev":false,"enc":false}]},{"iid":2,"type":"A2","primary":false,"hidden":false,"characteristics":[{"iid":131074,"type":"37","format":"string","value":"1.1.0","perms":["pr"],"ev":false,"enc":false}]},{"iid":4,"type":"22A","primary":false,"hidden":false,"characteristics":[{"iid":262145,"type":"22B","format":"bool","value":1,"perms":["pr"],"ev":false,"enc":false},{"iid":262146,"type":"22C","format":"uint32","value":11,"perms":["pr"],"ev":false,"enc":false,"minValue":0,"maxValue":15,"minStep":1},{"iid":262147,"type":"22D","format":"tlv8","value":"","perms":["pr","pw","ev","tw","wr"],"ev":false,"enc":false}]},{"iid":5,"type":"239","primary":false,"hidden":false,"characteristics":[{"iid":327681,"type":"23C","format":"data","value":"","perms":["pr"],"ev":false,"enc":false,"maxDataLen":0}]},{"iid":16,"type":"7E","primary":false,"hidden"
40F
:false,"characteristics":[{"iid":1048578,"type":"23","format":"string","value":"Security System","perms":["pr"],"ev":false,"enc":false},{"iid":1048579,"type":"66","format":"uint8","value":3,"perms":["pr","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":4,"minStep":1,"valid-values":[0,1,2,3,4]},{"iid":1048580,"type":"67","format":"uint8","value":3,"perms":["pr","pw","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":3,"minStep":1,"valid-values":[0,1,2,3]},{"iid":1048581,"type":"60CDDE6C-42B6-4C72-9719-AB2740EABE2A","format":"tlv8","value":"","perms":["pr","pw"],"ev":false,"enc":false,"description":"Stay Arm Trigger Devices"},{"iid":1048582,"type":"4AB2460A-41E4-4F05-97C3-CCFDAE1BE324","format":"tlv8","value":"","perms":["pr","pw"],"ev":false,"enc":false,"description":"Alarm Trigger Devices"},{"iid":1048583,"type":"F8296386-5A30-4AA7-838C-ED0DA9D807DF","format":"tlv8","value":"","perms":["pr","pw"],"ev":false,"enc":false,"description":"Night Arm Trigger Devices"}]},{"iid":17,"type":"9715BF53-AB63-4449-8DC7-2785D617390A"
3E0
,"primary":false,"hidden":true,"characteristics":[{"iid":1114121,"type":"B1C09E4C-E202-4827-B863-B0F32F727CFF","format":"bool","value":0,"perms":["pr","pw","ev","hd"],"ev":false,"enc":false,"description":"New Accessory Permission"},{"iid":1114122,"type":"75D19FA9-218B-4943-997E-341E5D1C60CC","format":"string","perms":["pw","hd"],"description":"Remove Accessory"},{"iid":1114123,"type":"7D943F6A-E052-4E96-A176-D17BF00E32CB","format":"int","value":-1,"perms":["pr","ev","hd"],"ev":false,"enc":false,"description":"Software New Status","minValue":-65535,"maxValue":65535,"minStep":1},{"iid":1114124,"type":"A45EFD52-0DB5-4C1A-9727-513FBCD8185F","format":"string","perms":["pw","hd"],"description":"Software New URL","maxLen":256},{"iid":1114125,"type":"40F0124A-579D-40E4-865E-0EF6740EA64B","format":"string","perms":["pw","hd"],"description":"Software New Checksum"},{"iid":1114126,"type":"96BF5F20-2996-4DB6-8D65-0E36314BCB6D","format":"string","value":"4.5.20_0026.0092","perms":["pr","hd"
3FF
],"ev":false,"enc":false,"description":"Software Number"},{"iid":1114127,"type":"36B7A28B-3200-4783-A3FB-6714F11B1417","format":"string","value":"lumi.camera.agl006","perms":["pr","hd"],"ev":false,"enc":false,"description":"Software Behavior"},{"iid":1114128,"type":"F5329CB1-A50B-4225-BA9B-331449E7F7A9","format":"uint8","value":1,"perms":["pr","hd"],"ev":false,"enc":false,"description":"Selected IoT Platform","minValue":0,"maxValue":4,"minStep":1},{"iid":1114129,"type":"ED080A16-3A60-433A-B983-F6CB5228B138","format":"string","perms":["pw","hd"],"description":"Run Scene"}]},{"iid":18,"type":"F49132D1-12DF-4119-87D3-A93E8D68531E","primary":false,"hidden":true,"characteristics":[{"iid":1179650,"type":"25D889CB-7135-4A29-B5B4-C1FFD6D2DD5C","format":"string","value":"","perms":["pr","pw","hd"],"ev":false,"enc":false,"description":"Country Domain"},{"iid":1179651,"type":"C7EECAA7-91D9-40EB-AD0C-FFDDE3143CB9","format":"string","value":"lumi3.a9275cbecbe8f667","perms":["pr","hd"],"ev":false,"enc":false,"description"
3F2
:"Lumi Did"},{"iid":1179652,"type":"80FA747E-CB45-45A4-B7BE-AA7D9964859E","format":"string","perms":["pw","hd"],"description":"Lumi Bindkey"},{"iid":1179653,"type":"C3B8A329-EF0C-4739-B773-E5B7AEA52C71","format":"bool","value":1,"perms":["pr","hd"],"ev":false,"enc":false,"description":"Lumi Bindstate"},{"iid":1179654,"type":"18E85FEB-C219-43AB-8CD4-15ED1D2B5086","format":"uint8","value":1,"perms":["pr","hd"],"ev":false,"enc":false,"description":"Selected Lumi Bindtype","minValue":0,"maxValue":5,"minStep":1}]},{"iid":22,"type":"96","primary":false,"hidden":false,"characteristics":[{"iid":1441794,"type":"23","format":"string","value":"Battery Sensor","perms":["pr"],"ev":false,"enc":false},{"iid":1441795,"type":"68","format":"uint8","value":100,"perms":["pr","ev"],"ev":false,"enc":false,"unit":"percentage","minValue":0,"maxValue":100,"minStep":1},{"iid":1441797,"type":"79","format":"uint8","value":0,"perms":["pr","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1,"valid-values":[0,1
413
]},{"iid":1441796,"type":"8F","format":"uint8","value":2,"perms":["pr","ev"],"ev":false,"enc":false,"minValue":2,"maxValue":2,"minStep":1,"valid-values":[2]}]},{"iid":26,"type":"129","primary":false,"hidden":false,"characteristics":[{"iid":1703937,"type":"130","format":"tlv8","value":"AQMBAQA=","perms":["pr"],"ev":false,"enc":false},{"iid":1703938,"type":"131","format":"tlv8","value":"","perms":["pr","pw","wr"],"ev":false,"enc":false},{"iid":1703939,"type":"37","format":"string","value":"1.0","perms":["pr"],"ev":false,"enc":false}]},{"iid":27,"type":"110","primary":false,"hidden":false,"characteristics":[{"iid":1769474,"type":"B0","format":"uint8","value":1,"perms":["pr","pw","ev","tw"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1},{"iid":1769475,"type":"120","format":"tlv8","value":"AQEA","perms":["pr","ev"],"ev":false,"enc":false},{"iid":1769476,"type":"114","format":"tlv8","value":"AVwBAQACDgEBAQIBAAAAAgECAwEAAwsBAkAGAgKwBAMBHgAAAwsBAgAFAgLAAwMBHgAAAwsBAoACAgLgAQMBHgAAAwsBAuABAgJoAQMBHgAAAwsBAkABAgLwAAMBHg=="
3E0
,"perms":["pr"],"ev":false,"enc":false},{"iid":1769477,"type":"115","format":"tlv8","value":"AQ4BAQICCQEBAQIBAAMBAQIBAA==","perms":["pr"],"ev":false,"enc":false},{"iid":1769478,"type":"116","format":"tlv8","value":"AgEAAAACAQEAAAIBAg==","perms":["pr"],"ev":false,"enc":false},{"iid":1769479,"type":"118","format":"tlv8","value":"","perms":["pr","pw"],"ev":false,"enc":false},{"iid":1769480,"type":"117","format":"tlv8","value":"","perms":["pr","pw"],"ev":false,"enc":false}]},{"iid":28,"type":"110","primary":false,"hidden":false,"characteristics":[{"iid":1835010,"type":"B0","format":"uint8","value":1,"perms":["pr","pw","ev","tw"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1},{"iid":1835011,"type":"120","format":"tlv8","value":"AQEA","perms":["pr","ev"],"ev":false,"enc":false},{"iid":1835012,"type":"114","format":"tlv8","value":"AU0BAQACDgEBAQIBAAAAAgECAwEAAwsBAgAFAgLAAwMBHgAAAwsBAoACAgLgAQMBHgAAAwsBAuABAgJoAQMBHgAAAwsBAkABAgLwAAMBHg==","perms":["pr"],"ev":false,"enc"
3FC
:false},{"iid":1835013,"type":"115","format":"tlv8","value":"AQ4BAQICCQEBAQIBAAMBAQIBAA==","perms":["pr"],"ev":false,"enc":false},{"iid":1835014,"type":"116","format":"tlv8","value":"AgEAAAACAQEAAAIBAg==","perms":["pr"],"ev":false,"enc":false},{"iid":1835015,"type":"118","format":"tlv8","value":"","perms":["pr","pw"],"ev":false,"enc":false},{"iid":1835016,"type":"117","format":"tlv8","value":"","perms":["pr","pw"],"ev":false,"enc":false}]},{"iid":29,"type":"204","primary":false,"hidden":false,"linked":[26,33],"characteristics":[{"iid":1900545,"type":"B0","format":"uint8","value":0,"perms":["pr","pw","ev","tw"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1},{"iid":1900546,"type":"205","format":"tlv8","value":"AQSgDwAAAggDAAAAAAAAAAMLAQEAAgYBBKAPAAA=","perms":["pr","ev"],"ev":false,"enc":false},{"iid":1900547,"type":"206","format":"tlv8","value":"AUoBAQACCwEBAQIBAAAAAgECAwsBAkAGAgKwBAMBHgAAAwsBAgAFAgLAAwMBHgAAAwsBAkAGAgKwBAMBDwAAAwsBAgAFAgLAAwMBDw==","perms":["pr","ev"],"ev":false,"enc":false
3F7
},{"iid":1900548,"type":"207","format":"tlv8","value":"AQ4BAQACCQEBAQIBAAMBAQ==","perms":["pr","ev"],"ev":false,"enc":false},{"iid":1900549,"type":"209","format":"tlv8","value":"","perms":["pr","pw","ev"],"ev":false,"enc":false},{"iid":1900550,"type":"226","format":"uint8","value":0,"perms":["pr","pw","ev","tw"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1}]},{"iid":30,"type":"21A","primary":false,"hidden":false,"characteristics":[{"iid":1966081,"type":"223","format":"uint8","value":1,"perms":["pr","pw","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1},{"iid":1966082,"type":"225","format":"uint8","value":1,"perms":["pr","pw","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1},{"iid":1966083,"type":"21B","format":"uint8","value":1,"perms":["pr","pw","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1},{"iid":1966085,"type":"21D","format":"uint8","value":1,"perms":["pr","pw","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep"
3FA
:1},{"iid":1966086,"type":"11B","format":"bool","value":1,"perms":["pr","pw","ev"],"ev":false,"enc":false}]},{"iid":31,"type":"112","primary":false,"hidden":false,"characteristics":[{"iid":2031618,"type":"23","format":"string","value":"Microphone","perms":["pr"],"ev":false,"enc":false},{"iid":2031619,"type":"11A","format":"bool","value":0,"perms":["pr","pw","ev"],"ev":false,"enc":false},{"iid":2031620,"type":"119","format":"uint8","value":53,"perms":["pr","pw","ev"],"ev":false,"enc":false,"unit":"percentage","minValue":0,"maxValue":100,"minStep":1}]},{"iid":32,"type":"113","primary":false,"hidden":false,"characteristics":[{"iid":2097154,"type":"23","format":"string","value":"Speaker","perms":["pr"],"ev":false,"enc":false},{"iid":2097155,"type":"11A","format":"bool","value":0,"perms":["pr","pw","ev"],"ev":false,"enc":false},{"iid":2097156,"type":"119","format":"uint8","value":78,"perms":["pr","pw","ev"],"ev":false,"enc":false,"unit":"percentage","minValue":0,"maxValue":100,"minStep":1}]},{"iid":33,"type"
3F7
:"85","primary":false,"hidden":false,"characteristics":[{"iid":2162690,"type":"23","format":"string","value":"Motion Sensor","perms":["pr"],"ev":false,"enc":false},{"iid":2162691,"type":"22","format":"bool","value":0,"perms":["pr","ev"],"ev":false,"enc":false},{"iid":2162692,"type":"75","format":"bool","value":1,"perms":["pr","ev"],"ev":false,"enc":false}]},{"iid":34,"type":"121","primary":true,"hidden":false,"characteristics":[{"iid":2228226,"type":"23","format":"string","value":"Video Doorbell","perms":["pr"],"ev":false,"enc":false},{"iid":2228227,"type":"73","format":"uint8","value":null,"perms":["pr","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":0,"minStep":1,"valid-values":[0]},{"iid":2228228,"type":"11A","format":"bool","value":0,"perms":["pr","pw","ev"],"ev":false,"enc":false},{"iid":2228229,"type":"232","format":"tlv8","value":"AQEA","perms":["pr","ev"],"ev":false,"enc":false},{"iid":2228230,"type":"119","format":"uint8","value":50,"perms":["pr","pw","ev"],"ev":false,"enc":false,"unit"
3F8
:"percentage","minValue":0,"maxValue":100,"minStep":1}]},{"iid":35,"type":"236","primary":false,"hidden":true,"characteristics":[{"iid":2293762,"type":"234","format":"tlv8","value":"","perms":["pr","ev"],"ev":false,"enc":false},{"iid":2293763,"type":"235","format":"tlv8","value":"AQEAAgIsAQ==","perms":["pr","ev"],"ev":false,"enc":false}]}]},{"aid":65,"services":[{"iid":1,"type":"3E","primary":false,"hidden":false,"characteristics":[{"iid":65537,"type":"14","format":"bool","perms":["pw"]},{"iid":65538,"type":"20","format":"string","value":"Aqara","perms":["pr"],"ev":false,"enc":false},{"iid":65539,"type":"21","format":"string","value":"AS074","perms":["pr"],"ev":false,"enc":false},{"iid":65540,"type":"23","format":"string","value":"Presence Sensor","perms":["pr"],"ev":false,"enc":false},{"iid":65541,"type":"30","format":"string","value":"54ef441000dba772","perms":["pr"],"ev":false,"enc":false},{"iid":65542,"type":"52","format":"string","value":"0029","perms":["pr"],"ev":false,"enc":false},{"iid":65543,
3FF
"type":"53","format":"string","value":"1","perms":["pr"],"ev":false,"enc":false}]},{"iid":4,"type":"86","primary":true,"hidden":false,"characteristics":[{"iid":262146,"type":"23","format":"string","value":"Occupancy Sensor","perms":["pr"],"ev":false,"enc":false},{"iid":262148,"type":"71","format":"uint8","value":0,"perms":["pr","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1,"valid-values":[0,1]},{"iid":262150,"type":"75","format":"bool","value":1,"perms":["pr","ev"],"ev":false,"enc":false}]}]},{"aid":66,"services":[{"iid":1,"type":"3E","primary":false,"hidden":false,"characteristics":[{"iid":65537,"type":"14","format":"bool","perms":["pw"]},{"iid":65538,"type":"20","format":"string","value":"Aqara","perms":["pr"],"ev":false,"enc":false},{"iid":65539,"type":"21","format":"string","value":"AS077","perms":["pr"],"ev":false,"enc":false},{"iid":65540,"type":"23","format":"string","value":"Presence Sensor","perms":["pr"],"ev":false,"enc":false},{"iid":65541,"type":"30","format":"string","value"
3F8
:"54ef44100146ec93","perms":["pr"],"ev":false,"enc":false},{"iid":65542,"type":"52","format":"string","value":"5234","perms":["pr"],"ev":false,"enc":false},{"iid":65543,"type":"53","format":"string","value":"1.1","perms":["pr"],"ev":false,"enc":false}]},{"iid":4,"type":"86","primary":true,"hidden":false,"characteristics":[{"iid":262146,"type":"23","format":"string","value":"Occupancy Sensor","perms":["pr"],"ev":false,"enc":false},{"iid":262148,"type":"71","format":"uint8","value":0,"perms":["pr","ev"],"ev":false,"enc":false,"minValue":0,"maxValue":1,"minStep":1,"valid-values":[0,1]}]},{"iid":5,"type":"84","primary":false,"hidden":false,"characteristics":[{"iid":327682,"type":"23","format":"string","value":"Light Sensor","perms":["pr"],"ev":false,"enc":false},{"iid":327683,"type":"6B","format":"float","value":94,"perms":["pr","ev"],"ev":false,"enc":false,"unit":"lux","minValue":0,"maxValue":100000,"minStep":1}]},{"iid":6,"type":"8A","primary":false,"hidden":false,"characteristics":[{"iid":393218,"type"
3F8
:"23","format":"string","value":"Temperature Sensor","perms":["pr"],"ev":false,"enc":false},{"iid":393219,"type":"11","format":"float","value":25.6,"perms":["pr","ev"],"ev":false,"enc":false,"unit":"celsius","minValue":-50,"maxValue":100,"minStep":0.1}]},{"iid":7,"type":"82","primary":false,"hidden":false,"characteristics":[{"iid":458754,"type":"23","format":"string","value":"Humidity Sensor","perms":["pr"],"ev":false,"enc":false},{"iid":458755,"type":"10","format":"float","value":42,"perms":["pr","ev"],"ev":false,"enc":false,"unit":"percentage","minValue":0,"maxValue":100,"minStep":1}]},{"iid":8,"type":"96","primary":false,"hidden":false,"characteristics":[{"iid":524290,"type":"23","format":"string","value":"Battery Sensor","perms":["pr"],"ev":false,"enc":false},{"iid":524291,"type":"68","format":"uint8","value":100,"perms":["pr","ev"],"ev":false,"enc":false,"unit":"percentage","minValue":0,"maxValue":100,"minStep":1},{"iid":524293,"type":"79","format":"uint8","value":0,"perms":["pr","ev"],"ev":false
E8
,"enc":false,"minValue":0,"maxValue":1,"minStep":1,"valid-values":[0,1]},{"iid":524292,"type":"8F","format":"uint8","value":2,"perms":["pr","ev"],"ev":false,"enc":false,"minValue":2,"maxValue":2,"minStep":1,"valid-values":[2]}]}]}]}
0
Just to reconfirm this is Aqara Doorbell G410.
Thanks for your help.
Don’t use quotations, but ‘backticks’: `
Hi, used a code formatter now. Sorry pasting this from Phone.
But now it’s all on one line :sweat_smile:
Edit: put 3 backticks on the line above the first, and 3 on the line below the last.
Thanks added the three backticks now. Dont know the Editor formatter puts all this in single line. Added backticks manually before pasting then it worked I think as intended. :slight_smile:
Thanks for posting.
Your accessory uses chunked encoding which explains why the json formatting is rubbish. But no worries I sorted it out manually.
The result is very interesting. It contains many service types that are not documented in the public version of the Apple Homekit specification. So perhaps one day I may be able to figure out their meanings and eventually add new features to the binding.
So I created a PR for this (link below). The top post contains a link to the JAR file. You need to uninstall the official Homekit binding, and drop the version from this link into your addons folder. Also keep the trace logging turned on for the time being.
Hi @AndrewFG , I updated the jar file. But no new channel is created. Do I have to re pair and create th thing again ?
No.
Ok. Can you please again show the logs after the thing is initialized? There will be an entry for each channel. Also can you please show the Properties page? If you prefer it, you can send it to me by PM.
Hi @AndrewFG , Sent you details in DM. Let me know if you need anything else.
This is Thing property page
Binding property page
Aren’t channels made at Thing creation?
I have already crated and paird the thing. Just updated the Jar shared by Andrew. And restarted thing.
Not seeing any new channel so asked the Andrew if I have to repair
Indeed they are. When you disable and reenable the Thing, OH momentarily destroys and (re) creates the Thing. There is no need to physically remove the Thing from OH, nor any need to reset the accessory, nor any need to re-pair it.
Tried with Aqara G100 homekit camera. Same behaviour, no channel created for image snapshot. Also, restarted OH.
Thanks for testing. I made another build that should detect the camera service and add the respective extra channel. The new JAR is in the same location [binding.homekit] [experimental] Add camera snapshot channel by andrewfg · Pull Request #20035 · openhab/openhab-addons · GitHub as before..
