Hi, @AndrewFG , let me try rhis. Will share the updated soon.
Hi @AndrewFG . updated the jar. Still same error. I restarted the device to change the port and then binding is not able to connrect. I setup the log entries as suggested but I can see following error logs for this device
00:00:13.117[DEBUG] [org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler] - homekit:bridge:3b601af646c7 polling error java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@2e9d2a1c[Not completed, task = org.openhab.binding.homekit.internal.transport.IpTransport$$Lambda/0x0000000101878880@4f44ffc0] rejected from java.util.concurrent.ThreadPoolExecutor@64db2661[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 11], reconnecting..
00:00:13.124[TRACE] [org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler] - homekit:bridge:3b601af646c7 stack trace: java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@2e9d2a1c[Not completed, task = org.openhab.binding.homekit.internal.transport.IpTransport$$Lambda/0x0000000101878880@4f44ffc0] rejected from java.util.concurrent.ThreadPoolExecutor@64db2661[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 11] at java.base/java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.reject(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.execute(Unknown Source) at java.base/java.util.concurrent.AbstractExecutorService.submit(Unknown Source) at java.base/java.util.concurrent.Executors$DelegatedExecutorService.submit(Unknown Source) at org.openhab.binding.homekit.internal.transport.IpTransport.execute(IpTransport.java:187) at org.openhab.binding.homekit.internal.transport.IpTransport.get(IpTransport.java:149) at org.openhab.binding.homekit.internal.hapservices.CharacteristicReadWriteClient.readCharacteristics(CharacteristicReadWriteClient.java:54) at org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler.lambda$12(HomekitBaseAccessoryHandler.java:722) at org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler$Throttler.call(HomekitBaseAccessoryHandler.java:168) at org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler.refresh(HomekitBaseAccessoryHandler.java:722) at org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler.lambda$13(HomekitBaseAccessoryHandler.java:799) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source) at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.base/java.lang.Thread.run(Unknown Source)
00:00:13.130[INFO] [openhab.event.ThingStatusInfoChangedEvent] - Thing 'homekit:bridge:3b601af646c7' changed from OFFLINE (COMMUNICATION_ERROR): Polling error: 'java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@5ef8e186Not completed', reconnecting... to OFFLINE (COMMUNICATION_ERROR): Polling error: 'java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@2e9d2a1cNot completed', reconnecting...
00:01:13.131[DEBUG] [org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler] - homekit:bridge:3b601af646c7 polling error java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@1ca865d7[Not completed, task = org.openhab.binding.homekit.internal.transport.IpTransport$$Lambda/0x0000000101878880@6a7e8861] rejected from java.util.concurrent.ThreadPoolExecutor@64db2661[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 11], reconnecting..
00:01:13.134[TRACE] [org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler] - homekit:bridge:3b601af646c7 stack trace: java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@1ca865d7[Not completed, task = org.openhab.binding.homekit.internal.transport.IpTransport$$Lambda/0x0000000101878880@6a7e8861] rejected from java.util.concurrent.ThreadPoolExecutor@64db2661[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 11] at java.base/java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.reject(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.execute(Unknown Source) at java.base/java.util.concurrent.AbstractExecutorService.submit(Unknown Source) at java.base/java.util.concurrent.Executors$DelegatedExecutorService.submit(Unknown Source) at org.openhab.binding.homekit.internal.transport.IpTransport.execute(IpTransport.java:187) at org.openhab.binding.homekit.internal.transport.IpTransport.get(IpTransport.java:149) at org.openhab.binding.homekit.internal.hapservices.CharacteristicReadWriteClient.readCharacteristics(CharacteristicReadWriteClient.java:54) at org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler.lambda$12(HomekitBaseAccessoryHandler.java:722) at org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler$Throttler.call(HomekitBaseAccessoryHandler.java:168) at org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler.refresh(HomekitBaseAccessoryHandler.java:722) at org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler.lambda$13(HomekitBaseAccessoryHandler.java:799) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source) at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.base/java.lang.Thread.run(Unknown Source)
00:01:13.143[INFO] [openhab.event.ThingStatusInfoChangedEvent] - Thing 'homekit:bridge:3b601af646c7' changed from OFFLINE (COMMUNICATION_ERROR): Polling error: 'java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@2e9d2a1cNot completed', reconnecting... to OFFLINE (COMMUNICATION_ERROR): Polling error: 'java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@1ca865d7Not completed', reconnecting...
00:02:13.142[DEBUG] [org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler] - homekit:bridge:3b601af646c7 polling error java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@626f48ac[Not completed, task = org.openhab.binding.homekit.internal.transport.IpTransport$$Lambda/0x0000000101878880@8105e50] rejected from java.util.concurrent.ThreadPoolExecutor@64db2661[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 11], reconnecting..
00:02:13.145[TRACE] [org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler] - homekit:bridge:3b601af646c7 stack trace: java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@626f48ac[Not completed, task = org.openhab.binding.homekit.internal.transport.IpTransport$$Lambda/0x0000000101878880@8105e50] rejected from java.util.concurrent.ThreadPoolExecutor@64db2661[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 11] at java.base/java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.reject(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.execute(Unknown Source) at java.base/java.util.concurrent.AbstractExecutorService.submit(Unknown Source) at java.base/java.util.concurrent.Executors$DelegatedExecutorService.submit(Unknown Source) at org.openhab.binding.homekit.internal.transport.IpTransport.execute(IpTransport.java:187) at org.openhab.binding.homekit.internal.transport.IpTransport.get(IpTransport.java:149) at org.openhab.binding.homekit.internal.hapservices.CharacteristicReadWriteClient.readCharacteristics(CharacteristicReadWriteClient.java:54) at org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler.lambda$12(HomekitBaseAccessoryHandler.java:722) at org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler$Throttler.call(HomekitBaseAccessoryHandler.java:168) at org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler.refresh(HomekitBaseAccessoryHandler.java:722) at org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler.lambda$13(HomekitBaseAccessoryHandler.java:799) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source) at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.base/java.lang.Thread.run(Unknown Source)
00:02:13.152[INFO] [openhab.event.ThingStatusInfoChangedEvent] - Thing 'homekit:bridge:3b601af646c7' changed from OFFLINE (COMMUNICATION_ERROR): Polling error: 'java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@1ca865d7Not completed', reconnecting... to OFFLINE (COMMUNICATION_ERROR): Polling error: 'java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@626f48acNot completed', reconnecting...
00:03:13.152[DEBUG] [org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler] - homekit:bridge:3b601af646c7 polling error java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@59742283[Not completed, task = org.openhab.binding.homekit.internal.transport.IpTransport$$Lambda/0x0000000101878880@6ca430a2] rejected from java.util.concurrent.ThreadPoolExecutor@64db2661[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 11], reconnecting..
00:03:13.159[TRACE] [org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler] - homekit:bridge:3b601af646c7 stack trace: java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@59742283[Not completed, task = org.openhab.binding.homekit.internal.transport.IpTransport$$Lambda/0x0000000101878880@6ca430a2] rejected from java.util.concurrent.ThreadPoolExecutor@64db2661[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 11] at java.base/java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.reject(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.execute(Unknown Source) at java.base/java.util.concurrent.AbstractExecutorService.submit(Unknown Source) at java.base/java.util.concurrent.Executors$DelegatedExecutorService.submit(Unknown Source) at org.openhab.binding.homekit.internal.transport.IpTransport.execute(IpTransport.java:187) at org.openhab.binding.homekit.internal.transport.IpTransport.get(IpTransport.java:149) at org.openhab.binding.homekit.internal.hapservices.CharacteristicReadWriteClient.readCharacteristics(CharacteristicReadWriteClient.java:54) at org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler.lambda$12(HomekitBaseAccessoryHandler.java:722) at org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler$Throttler.call(HomekitBaseAccessoryHandler.java:168) at org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler.refresh(HomekitBaseAccessoryHandler.java:722) at org.openhab.binding.homekit.internal.handler.HomekitBaseAccessoryHandler.lambda$13(HomekitBaseAccessoryHandler.java:799) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source) at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.base/java.lang.Thread.run(Unknown Source)
00:03:13.169[INFO] [openhab.event.ThingStatusInfoChangedEvent] - Thing 'homekit:bridge:3b601af646c7' changed from OFFLINE (COMMUNICATION_ERROR): Polling error: 'java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@626f48acNot completed', reconnecting... to OFFLINE (COMMUNICATION_ERROR): Polling error: 'java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@59742283Not completed', reconnecting...
Those are obvioulsy the messages AFTER it fails to reconnent. I need to see the message BEFORE that!! Please look for the messages that I highlighted you to look for in the Github post.
And also long AFTER it goes offline, say 30..60 minutes) for the next mDNS discovery to find the device again.
EDIT: just to summarise the requirements for this to work:
- The thing must have been created from the inbox (managed thing) and not from a .things file.
- The thing must be discoverable via mDNS (you can use an external app to verify that).
- The thing must have a macAddress property (check it in Main UI).
- When the thing goes offline and comes back again, it chooses another port for itself. So the thing cannot go online with the old port.
- After the restart the thing must advertise itself again with the new port (check via the external app).
- The mDNS service will re-discover the thing with the new port.
- The OH Inbox will inform the thing via the
handleConfigurationUpdate()callback about the new port. You should see thehandleConfigurationUpdate()in the log. - The thing should dispose its current state and reinitialize with the new port.
Hi @AndrewFG
I have created the thing from inbox only. As this is a bridge device I belive the binding creates one as a bridge and then another as a thing for actual device automatically.
The bridge thing goes offline when the physical device port changes. Somehow only for bridge thing this happens. All non-bridge accessory work just fine.
I m not seeing handleConfigurationUpdate in logs. Let me recheck if the logging level is taking effect. I have used log viewer to enable trace for discovey package you mentioned in your git post.
Can you please send me the full list of your bridges and things with their respective configuration parameters. And what things are child of what bridge etc. And also the thing / bridge properties.
Hi @AndrewFG ,
Updated to your new jar and result is positive. Thing updated to latest port autmatically. It took around a minute or so for the thing to come back online. Let me keep testing this version. Will report back if I find anything new.
Thanks for your quick support!
Hi @AndrewFG ,
Any possibility to add talk back support for cameras? This will remove dependency on camera apps for this feature.
Amin
That would be a big addition in terms of code. But I will look into it. However please tell me how you would intend to talk and listen to the camera, as OH does not have channel types of its own to support talk or listen?
Hi @AndrewFG ,
I was checking oh-video-card widget. It has a option to send audio for two way comms. I have not tested it but I use it to show video on web ui for ipcamera binding.
I think ideal way will be to get both video and audio from homekit binding and then use oh-video-card as UI.
Thanks,
Amin
Can you point me to where this is located in OH? Is there a ReadMe for it?
Hi
This the documentation link
