In addition, this is on the console when entering the Aeon Gen5 USB stick:
[41659.759782] usb 3-2: new full-speed USB device number 4 using uhci_hcd
[41659.940727] Got empty serial number. Generate serial number from product.
[41662.320319] cdc_acm 3-2:1.0: This device cannot do calls on its own. It is not a modem.
[41662.328451] cdc_acm 3-2:1.0: ttyACM0: USB ACM device
[41662.335941] usbcore: registered new interface driver cdc_acm
[41662.341742] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
I’ve also tried the addon z-wave binding version 1.8.0-SNAPSHOT, no difference, still
"Port /dev/ttyACM0 does not exist"…
Yes I did do a restart after adding the user to the dialout group.
The settings of the /dev/ttyACM0 I have to do again after every reboot or unpluggin/plugin of the z-wave stick. It’s created as root/root and permission 600
I found this post in a synology forum:
Now I have spent many hours trying to figure this out, why it works for some and others not.
Aotec Gen 5 stick uses cdc-acm driver.
It looks like your NAS have an older kernel with an older cdc-acm driver and that’s the problem.
I’ll try to find a solution, but no promises.
Regards
Jadahl
This is the version on my Synology:
Linux version 3.10.35 (root@build2) (gcc version 4.7.3 20130102 (prerelease) (crosstool-NG 1.18.0) ) #5644 SMP Fri Jan 22 13:38:47 CST 2016
Synology Nas is up to date.
Info:
DS412+
Current DSM version: DSM 5.2-5644 Update 5
DSM date: 2016/02/18
Also all packages are up to date.
I’ve been browsing the web in search for a newer version of the “cdc-acm driver” for the Aeon Gen 5 z-wave stick to be installed on Linux version 3.10.35, I can’t seem to find it.
Any ideas on where to find one that supports the stick and can be installed on Linux version 3.10.35 ?
Any ideas what to do to get rid of this message: “Port /dev/ttyACM0 does not exist”?
Is anyone familiar with a functioning configuration consisting of a Synology NAS with DSM 5.2 and the Aeon z-wave stick Gen5?
Or a configuration with Linux version 3.10.35 and the z-wave stick?
Adjust user id and groups
- Create groups “dialout” and “uucp” in DSM
- Change user id of “openhab” to make it a system user
○ Edit /etc/passwd and replace id by a number < 100 (e.g. 95)
○ Change user id for existing files to new user id, here 1066 is the old user id and 95 the new one:
- find / -user 1066 -exec chown -h 95 {} ;
- Change group ids of “dialout” and "uucp"
○ Edit /etc/group and replace group ids by 800 / 801
○ Assign user openhab to both groups (also in /etc/group)
Adjust owner and rights for usb serial
- In terminal:
○ chown -R root.uucp /var/lock
○ chmod -R g+w /var/lock/
○ chown -R root.dialout /dev/ttyACM0
○ chmod 660 /dev/ttyACM0
- If openhab was started as roots, there may be lock-files remaining in folder /var/locks that cannot be removed by user openhab, so remove them manually
BTW, I didn’t replace the id numbers. Just created the groups, added the user and adjusted the owner and rights for the usb serial. I think the essential thing was the rights to the /var/lock file.
Next I would like to have the ownership and permission to the ACM0 port set correctly by default. So that I wouldn’t have to change them manually after each NAS startup or renewed plugin of the USB stick.
So now the settings for the /dev/ttyACM0 are right, but…
How to get the settings for /var/lock set right after reboot?
It’s these commands:
I tried 2 scenario’s:
1 - create a xxx.conf file with these commands in the folder /etc/init
2 - added the commands to the startup file start_runtime.sh
Both strategies didn’t work.
Anyone any suggestions on what might be the problem or the solution?
I’m new to OpenHAB and I’m having the same problem as LeoVe.
I’m running a Synology DS1815+ with DSM 6.07321 I have OpenHAB 1.8.2, the latest HABmin, and the demo running.
I plugged in the Aeon Gen 5 z-wave stick and the Synology sees the device and assigns it /dev/ttyACM0, it even shows it plugged into the system via the control panel.
[ 25.111311] cdc_acm 2-2:1.0: This device cannot do calls on its own. It is not a modem.
[ 25.120340] cdc_acm 2-2:1.0: ttyACM0: USB ACM device
[ 25.128397] usbcore: registered new interface driver cdc_acm
I followed these steps as per the previous posts:
created a dialout group via DSM
created a uucp group via DSM
assigned the openhab user to both groups via DSM
ran chown -R root.dialout /dev/ttyACM0 as root
ran chmod 660 /dev/ttyACM0 as root
ran chown -R root.uucp /var/lock as root
ran chmod -R g+w /var/lock/ as root
Created a file named openhab-zwave.rules in /lib/udev/rules.d with this content:
ACTION==“add”, KERNEL==“ttyACM0”, MODE=“0660”, GROUP=“dialout” as root
restarted the DSM, and reran ran chown -R root.uucp /var/lock as root & ran chmod -R g+w /var/lock/ as root
When I run ls -l /dev/ttyACM0 I get:
crw-rw---- 1 root dialout 166, 0 Mar 31 02:09 /dev/ttyACM0
My openhab.log still tells me:
23:46:38.991 [ManagedService Update Queue] ERROR o.o.b.z.i.protocol.ZWaveController - Serial Error: Port /dev/ttyACM0 does not exist
23:46:38.997 [org.openhab.core.internal.logging.OSGILogListener$NLogListener@99d7fe9] ERROR OSGi - port : Port /dev/ttyACM0 does not exist
org.openhab.binding.zwave.internal.protocol.SerialInterfaceException: Port /dev/ttyACM0 does not exist
Did I miss a step? I realize that the lock permissions will need to be reassigned every reboot without a script, but I can’t get it to run at all.
Try to just reinstall the package spk so that all files from openhab have the correct permissions.
The rest of the commands i use to exept the 660 is not needed in 5.2, i do not have 6 installed
I have reinstalled several times. I can run the debug as root and I can see my devices nodes 2, 3, &4 and they send update events.
However I don’t see the values updating on the UI (standard) and if I go back to launching from DSM now I get a does not exist even though it is there. I even tired adding -Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0 to start.sh as suggested on another thread. no dice.
19:31:06.357 [ManagedService Update Queue] INFO o.o.b.z.i.protocol.ZWaveController - Starting Z-Wave controller
19:31:06.358 [ManagedService Update Queue] INFO o.o.b.z.i.protocol.ZWaveController - Z-Wave timeout is set to 5000ms. Soft reset is false.
19:31:06.358 [ManagedService Update Queue] INFO o.o.b.z.i.protocol.ZWaveController - Connecting to serial port /dev/ttyACM0
19:31:06.421 [ManagedService Update Queue] ERROR o.o.b.z.i.protocol.ZWaveController - Serial Error: Port /dev/ttyACM0 does not exist
19:31:06.426 [NTP Refresh Service] INFO o.o.c.service.AbstractActiveService - NTP Refresh Service has been started
19:31:06.426 [NTP Refresh Service] DEBUG o.o.binding.ntp.internal.NtpBinding - There is no existing NTP binding configuration => refresh cycle aborted!
19:31:06.434 [org.openhab.core.internal.logging.OSGILogListener$NLogListener@4233cd6] ERROR OSGi - port : Port /dev/ttyACM0 does not exist
################################ Z-Wave Binding ######################################
# The Z-Wave controller port. Valid values are e.g. COM1 for Windows and /dev/ttyS0 or
# /dev/ttyUSB0 for Linux
zwave:port=/dev/ttyACM0
# Z-Wave nightly heal time. This is the hour (eg 2AM) at which the automatic nightly
# network heal will be performed.
zwave:healtime=4
#zwave:masterController=True
items
group All
Group Main_Floor (All)
Group Basement (All)
Group Second_Floor (All)
Group Doors (All)
Group Batteries (All)
Contact frontdoor_sensor "Front door is [%s]" <door> (Doors,Main_Floor) {zwave="2:command=BASIC"}
Number frontdoor_battery "Front door sensor battery [%d %%]" <battery> (Batteries) {zwave="2:command=BATTERY"}
Contact sidedoor_sensor "Side door is [%s]" <door> (Doors,Main_Floor) {zwave="3:command=BASIC"}
Number sidedoor_battery "Side door sensor battery [%d %%]" <battery> (Batteries) {zwave="3:command=BATTERY"}
Contact Motion_Main_Floor "Motion [MAP(motion.map):%s]" <motion> (Main_Floor) {zwave="4:command=sensor_binary,respond_to_basic=true" }
/*Number Alarm_Main_Floor "Alarm: [%s]" (Main_Floor) {zwave="4:command=alarm" }*/
Number Temp_Main_Floor "Temperature: [%.1f °C]" <temperature> (Main_Floor) {zwave="4:command=sensor_multilevel,sensor_type=1,sensor_scale=0" }
Number Humid_Main_Floor "Humidity: [%.0f %%]" (Main_Floor) {zwave="4:command=sensor_multilevel,sensor_type=5" }
Number Lumin_Main_Floor "Luminance: [%.0f Lux]" (Main_Floor) {zwave="4:command=sensor_multilevel,sensor_type=3" }
Number UV_Main_Floor "Luminance: [UV index %d]" (Main_Floor) {zwave="4:command=sensor_multilevel,sensor_type=27" }
Number Battery_Main_Floor "Battery: [%d %%]" <battery> (Batteries) {zwave="4:command=battery" }
sitemp
sitemap piggpin label="Home"
Frame label="Pig Pen" {
Text label="Main Floor" icon="groundfloor"{
Group item=Main_Floor
Text item=frontdoor_sensor
Text item=sidedoor_sensor
Text item=Temp_Main_Floor
Text label="Second Floor" icon="firstfloor"{
Group item=Second_Floor
Text label="Basement" icon="cellar"{
Group item=Basement
I got some feedback from a friend and he suggested that I edit the start-stop-status.sh and add chmod 777 /dev/ttyACM0 and chmod 777 /run/lock/
It worked. I know that 777 is bad juju but I tried that on the command line for the device and it didn’t help. Wan it /run/lock? I already had /var/lock set as root.uucp and openhab was added to the group.
First thing, never run openhab as root, it will change a lot of files on synology, other systems no problem i think.
The last comment i see that you change rights on the device and its lockfile en thats correct, that is how it works for me to.
Search google for how to install openhab on xpenology, you will find a tut i wrote in the old forums.
I’m running OpenHAB2 on a DS214play, and finally (after trying a million different things from different webpages, including some of what’s above) got OpenHAB2 to see the z-stick when I ran start.sh from the commandline as root. If I run it from the package manager OpenHAB2 tells me that /dev/ttyACM0 doesn’t exist.
Can someone please advise me of the best way to cure this (what I guess is a rights) issue so that I can run Openhab as a normal package?
