Hi Guys,
probably another stupid question but here goes…
I’m trying to update an item (that is linked to a ModBus data channel) in a python script.
events.postUpdate("itm_vva_ahu_01_ei_ht_req_lw", "3")
Thing is, the item receives the update but the update is not “written” to the slave (The binding does not perform an actual RTU write). If I link the item to my sitemap I can write the values manually via the sitemap, so there is nothing “wrong” with the binding or the configuration of the binding. I probably must use something else instead of postUpdate? Tips welcome.
Thanks & wash your hands often!
StevenT
