Hello all
I used this tutorial: https://github.com/ThomDietrich/miflora-mqtt-daemon get data from a miflora sensor in to openhab. Now i would like to have it working under the new mqtt addon.
But the data is being send to Mosquitto trough a JSONPATH and i have no idea what to do.
This is what i have from the mqtt 1.x binding:
.items
// miflora.items - Generated by miflora-mqtt-daemon.
// Adapt to your needs! Things you probably want to modify:
// Room group names, icons,
// "gAll", "broker", "UnknownRoom"
// Mi Flora specific groups
Group gMiFlora "All Mi Flora sensors and elements" (gAll)
Group gLightIntensity "Mi Flora Sunlight Intensity elements" (gAll, gMiFlora)
Group gAirTemperature "Mi Flora Air Temperature elements" (gAll, gMiFlora)
Group gSoilMoisture "Mi Flora Soil Moisture elements" (gAll, gMiFlora)
Group gSoilConductivity "Mi Flora Soil Conductivity/Fertility elements" (gAll, gMiFlora)
Group gBattery "Mi Flora Sensor Battery Level elements" (gAll, gMiFlora)
// Mi Flora "miflora1" (C4:7C:8D:66:DB:F0)
Group ghomemiflora1 "Mi Flora Sensor miflora1" (gMiFlora, ghome)
Number home_miflora1_LightIntensity "Sunlight Intensity [%d lux]" <text> (ghomemiflora1, gLightIntensity) {mqtt="<[broker:miflora/miflora1:state:JSONPATH($.light)]"}
Number home_miflora1_AirTemperature "Air Temperature [%.1f °C]" <text> (ghomemiflora1, gAirTemperature) {mqtt="<[broker:miflora/miflora1:state:JSONPATH($.temperature)]"}
Number home_miflora1_SoilMoisture "Soil Moisture [%d %%]" <text> (ghomemiflora1, gSoilMoisture) {mqtt="<[broker:miflora/miflora1:state:JSONPATH($.moisture)]"}
Number home_miflora1_SoilConductivity "Soil Conductivity/Fertility [%d µS/cm]" <text> (ghomemiflora1, gSoilConductivity) {mqtt="<[broker:miflora/miflora1:state:JSONPATH($.conductivity)]"}
Number home_miflora1_Battery "Battery Level [%d %%]" <text> (ghomemiflora1, gBattery) {mqtt="<[broker:miflora/miflora1:state:JSONPATH($.battery)]"}
.sitemap
Text item=home_miflora1_LightIntensity
Text item=home_miflora1_AirTemperature
Text item=home_miflora1_SoilMoisture
Text item=home_miflora1_SoilConductivity
Text item=home_miflora1_Battery
Now do i have the add JSONPATH to the .things file or in the .items file. And how do i do that.
Can someone point me in the right direction.
Greetings
