I’m running official OH 3.1.0 and Java:
openjdk version “11.0.11” 2021-04-20 LTS
OpenJDK Runtime Environment Zulu11.48+21-CA (build 11.0.11+9-LTS)
OpenJDK Client VM Zulu11.48+21-CA (build 11.0.11+9-LTS, mixed mode)
I have a rule whereby I want to perform a lock (zwave) only if the door is fully closed. If the door is open then wait 10 seconds and check again if the door is open. I’ve created a simulation rule which I’m hoping someone here can help me identify the cause of the error.
Many thanks for helping me here… Kind of not sure what I’m doing incorrectly.
rule "SIMULATION"
Item TestSwitch changed to OFF
val itm = triggeringItemName
var Timer tmr = null
val sec = 10
logInfo("Simulation","[A] STARTING SIMULATION.")
if (tmr === null) {
tmr = createTimer(now.plusSeconds(sec), [ |
val now = TestDoor.state
logInfo("Simulation","[B] ITEM: {}, DOOR: {}", itm, now)
if ( now == CLOSED ) { itm.sendCommand("ON")
tmr = null
} else {
logInfo("Simulation","[C] THIS DOOR IS OPEN, RETRYING IN [{}] SECONDS.", sec)
tmr.reschedule(now.plusSeconds(sec))
And my items file:
Switch TestSwitch
Contact TestDoor
And the error:
14:43:59.165 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'TestSwitch' received command OFF
14:43:59.194 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'TestSwitch' changed from ON to OFF
14:43:59.197 [INFO ] [.openhab.core.model.script.Simulation] - [A] STARTING SIMULATION.
14:44:09.222 [INFO ] [.openhab.core.model.script.Simulation] - [B] ITEM: TestSwitch, DOOR: OPEN
14:44:09.259 [INFO ] [.openhab.core.model.script.Simulation] - [C] THIS DOOR IS OPEN, RETRYING IN [10] SECONDS.
14:44:09.335 [WARN ] [core.internal.scheduler.SchedulerImpl] - Scheduled job failed and stopped
java.lang.reflect.UndeclaredThrowableException: null
at com.sun.proxy.$Proxy1347.apply(Unknown Source) ~[?:?]
at org.openhab.core.model.script.actions.ScriptExecution.lambda$0(ScriptExecution.java:82) ~[?:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$12(SchedulerImpl.java:184) ~[?:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$1(SchedulerImpl.java:87) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: org.openhab.core.model.script.engine.ScriptExecutionException: 'plusSeconds' is not a member of 'org.openhab.core.types.State'; line 20, column 19, length 20
at org.openhab.core.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:133) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:878) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:243) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1222) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1152) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1098) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:475) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:251) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:492) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:267) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:213) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:47) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:30) ~[?:?]
... 10 more
