While searching for an outdoor light/brightness sensor i found the Eltako FAH65S. I would like to give that one a try, if i knew it works with openhab + EnOcean binding.
The sensor is not on the list provided with the EnOcean binding description. There is an other light sensor mentioned:
lightSensor A5-06 0x01 illumination Eltako TF-AHDSB Discovery
Some specification for the FAH65S i found in this document is
FAH65S, FIH65S (EEP: ÄHNLICH A5-06-01 PLUS DATA_BYTE3)
ORG = 0x07
Data_byte3 = Helligkeit 0…100 lux (0…100)
(nur gültig, wenn DB2 = 0x00)
Data_byte2 = Helligkeit 300…30.000 lux (0…255)
Data_byte1 = -
Data_byte0 = 0x0F
Lerntelegramm: 0x18080D87
As i’d have to buy the sensor plus an USB300 or an EnOceanPi, i’d like to be quite shure to have a chance to get it working before ordering. I’d be quite happy, if someone here can comment on this. Thx!
PS: i’m running a rasppi 3B+ + z-wave + zigbee + rfxcom + openhab 2.5.4 up to now. Most of the times i’m quite happy with all this. But i’d very much like to get rid of all the battery powered thingies.
