I can’t get the mios binding to work, so I wonder if ther’s any good guide/how to/tutorial how to get the z-wave devices I have in my Vera to work in OpenHAB2
Have a look at these:
Once you have used the scripts, its pretty straightforward… and very reliable.
I have installed the addon miOSbindning 1.9.0 to my OpenHAB2 and I put the IP to my Vera Edge in the mios.cfg and I ran the miosLoad.sh, miosTransform.sh and I put the .items file in /etc/openhab2/items
In OpenHAB2 (Paper UI, Config, Items) I can see all items from my Vera.
But then I’m stuck. I’m not sure what do do from here so that I can turn on/off the switches.
So have you created a sitemap file to show these items as switches etc?
Are you just getting started with OH?
It takes a bit of effort to get your head around initially, but once it clicks its well worth it!
The sitemap is what allow you to see on a webpage the items and interact with them.
Try HABpanel to control your items. It has less of a learning curve than a sitemap.
Oh, I haven’t created any sitemap, so that’s what I need.
Will try to find info regarding the sitemap
what part in this string should be in the sitemap
Switch FloorLivingRoomStatus "Floor Living Room Status" (GDevices,GRoom2) {mios="unit:LiBE,device:126/service/SwitchPower1/Status"}
or should be another part from the item files,
sorry for all the beginner questions. I’m beginning to understand the sitemap files, but not the mios binding and sitemaps.
A simple sitemap entry for that item would be:
Switch item=FloorLivingRoomStatus
edit… oops, I missed the “floor” part.
as this is another problem to what I started with, I have created a topic and kind of close this on.
