Just adding my two cents to this thread: About a year ago my pi3 started going wonky. I’ve since discovered that it was a a power supply issue, but at the time I was really annoyed with it and looking for a new SBC. Of course, the pi shortage was still in full effect at that point, and I was having a hard time finding an SBC with decent specs for a reasonable price.
And then I discovered the world of used 1-litre mini PCs. I scoured eBay, and picked up a Lenovo M910Q for $120. Cheaper than many of the SBCs I’d been considering!
Knowing that this little computer was going to be massive overkill for just openHAB, I looked for other things that I could run on it, and soon discovered Proxmox, and other self-hosted services like Nextcloud, Paperless-ngx, a Minecraft server for my son… And the backups! I’d struggled with figuring out Amanda and never really felt confident that it was correctly set up. I’d tried other things, like periodically manually duplicating the SD card (which worked until I got lazy and didn’t bother doing it frequently enough.
But the backups and backup pruning available via Proxmox has been incredible, and has already saved me multiple times from buggy updates (not openHAB, luckily!) and user error.
I got bit by the homelab bug.
Now, a little over a year later, I have added two additional miniPCs to play with High Availability redundancy, a separate NAS running TrueNAS, and I just picked up a cheap Topton box with a 6-port 2.5G NIC to use as a router running OPNsense.
All of that it obviously overkill for openHAB, but even if you don’t want to get into the homelab hobby, I’d highly recommend finding a used miniPC and running Proxmox or something similar. The ease of backups alone is worth it, for me. And the ease up spinning up additional containers to separate MQTT, nodeRED, or anything else that you might want to experiment with, without putting your core openHAB in danger, is great. I can play with all sorts of services and then quickly wipe them out without worrying about conflicting dependencies or configurations.
