This is anecdotal, I have no hard facts, but it feels like the number of problems with failing SSE connections and authentication errors have increased significantly in my dev environment lately. They have always been there, I take it that some of it is due to me making changes, restarting bundles, using multiple browser tabs etc., but not with the frequency I’ve experienced now.
The symptoms are usually that the UI becomes unresponsive or buggy, and if I then reload the page, I must reauthenticate. My assumption is that authentication has timed out and then failed to renew, or something like that.
I’ve found stuff like this in OH’s log, but I don’t know whether it’s related to what I’m experiencing:
22:33:16.429 [WARN ] (qtp1276505738-311 ) [.io.rest.auth.internal.TokenResource] - Not refreshing token for session 8a003405-5e7b-4e64-bb23-c35d8ec3d849 of user Nadar, missing or invalid session cookie
22:33:16.429 [WARN ] (qtp1276505738-311 ) [.io.rest.auth.internal.TokenResource] - Token issuing failed: invalid_grant
In the UI, I see things like this:
…and this in the browser console:
auth?response_type=code&client_id=http%3A%2F%2Flocalhost%3A8081&redirect_uri=http%3A%2F%2Flocalhost…:1 [DOM] Input elements should have autocomplete attributes (suggested: "current-password"): (More info: https://www.chromium.org/developers/design-documents/create-amazing-password-forms) <input class="field" type="password" placeholder="Passord" name="password" required>
02:30:26.667 Navigated to http://localhost:8081/?code=b48c5778a2e6469d9e6c136c817c81b2&state=d49f5e9163
02:30:26.888 client:733 [vite] connecting...
02:30:27.201 client:827 [vite] connected.
02:30:27.442 App.vue:635 sseConnected undefined
02:30:27.449 main.ts:83 App initialization: 21.00 ms
02:30:27.494 api.js:53 POST http://localhost:8081/rest/auth/token 400 (Bad Request)
(anonymous) @ request.js:406
(anonymous) @ request.js:22
(anonymous) @ api.js:53
(anonymous) @ auth-mixin.js:85
(anonymous) @ auth-mixin.js:74
created @ App.vue:957
callWithErrorHandling @ runtime-core.esm-bundler.js:199
callWithAsyncErrorHandling @ runtime-core.esm-bundler.js:206
callWithAsyncErrorHandling @ runtime-core.esm-bundler.js:217
callHook @ runtime-core.esm-bundler.js:3922
applyOptions @ runtime-core.esm-bundler.js:3839
finishComponentSetup @ runtime-core.esm-bundler.js:8206
handleSetupResult @ runtime-core.esm-bundler.js:8157
setupStatefulComponent @ runtime-core.esm-bundler.js:8126
setupComponent @ runtime-core.esm-bundler.js:8055
(anonymous) @ runtime-core.esm-bundler.js:5992
(anonymous) @ runtime-core.esm-bundler.js:5958
(anonymous) @ runtime-core.esm-bundler.js:5464
(anonymous) @ runtime-core.esm-bundler.js:6773
mount @ runtime-core.esm-bundler.js:4232
(anonymous) @ runtime-dom.esm-bundler.js:1891
(anonymous) @ main.ts:79
02:30:27.495 auth-mixin.js:99 Refreshing access token failed Bad Request
02:30:27.495 App.vue:963 Error while using the stored refresh_token to get a new access_token: Bad Request. Logging out & cleaning session.
(anonymous) @ App.vue:963
Promise.catch
created @ App.vue:962
02:30:27.611
02:30:27.644 prepare.js:1 🍍 "user" store installed 🆕
02:30:27.645 prepare.js:1 🍍 "components" store installed 🆕
02:30:27.645 prepare.js:1 🍍 "model" store installed 🆕
02:30:27.673 api.js:53 POST http://localhost:8081/rest/auth/logout 401 (Unauthorized)
(anonymous) @ auth-mixin.js:118
(anonymous) @ auth-mixin.js:111
(anonymous) @ App.vue:964
Promise.catch
02:30:27.673 auth-mixin.js:126 Failed to log out Unauthorized
02:30:27.676 api.js:53 POST http://localhost:8081/rest/auth/token?useCookie=true 400 (Bad Request)
(anonymous) @ auth-mixin.js:49
(anonymous) @ auth-mixin.js:20
(anonymous) @ App.vue:978
onceHandler @ events-class.js:38
(anonymous) @ events-class.js:96
(anonymous) @ events-class.js:95
emit @ events-class.js:89
(anonymous) @ f7.js:73
(anonymous) @ app-class.js:267
init @ app-class.js:275
(anonymous) @ app.js:277
(anonymous) @ runtime-core.esm-bundler.js:3081
(anonymous) @ runtime-core.esm-bundler.js:3061
flushPostFlushCbs @ runtime-core.esm-bundler.js:385
flushJobs @ runtime-core.esm-bundler.js:427
Promise.then
queueFlush @ runtime-core.esm-bundler.js:322
queueJob @ runtime-core.esm-bundler.js:317
(anonymous) @ runtime-core.esm-bundler.js:6228
trigger @ reactivity.esm-bundler.js:267
endBatch @ reactivity.esm-bundler.js:325
trigger @ reactivity.esm-bundler.js:743
set @ reactivity.esm-bundler.js:1069
set @ runtime-core.esm-bundler.js:3415
(anonymous) @ App.vue:965
Promise.catch
02:30:27.676 auth-mixin.js:65 Exchanging authorization code failed Bad Request
02:30:27.677 auth-mixin.js:129 Uncaught (in promise) Unauthorized
(anonymous) @ auth-mixin.js:129
Promise.catch
(anonymous) @ auth-mixin.js:125
Promise.catch
02:30:27.712 api.js:53 XHR failed loading: POST "http://localhost:8081/rest/auth/token".
02:30:27.727 api.js:53 XHR failed loading: POST "http://localhost:8081/rest/auth/logout".
Promise.catch
02:30:27.734 api.js:53 XHR failed loading: POST "http://localhost:8081/rest/auth/token?useCookie=true".
Promise.then
Promise.catch
It’s hard for me to pinpoint what triggered the changed, because I’ve recently updated/rebased both my core and MainUI work branches. I’ve also started running the sitemap bundles, which I haven’t used to have running.
…and it could all be in my head/coincidence.
Does anybody have anything to add, any similar experiences or ideas about what might have changed?
