Hi All,
Looking for any advice others can offer as I shop around and source parts to build a hot air transfer system to pull hot air from the room with a wood fireplace and dump the hot air into colder rooms.
Looking to design it around this Variable Speed EC Motor Centrifugal Fan 150mm (6 inch ducts) that has the ability to be fully speed controllable via 0-10volt, PWM or Modbus signals. Can be used standalone and adjusted via the built in knob.
Also looking at controlling 24volt dampers to turn zones on and off.
Anyone done this and can offer advice? thanks.
