As the title sais, anyone got the tampering alarm on the FGSS001 z-wave smoke sensor working in OH2?
It was working in OH1 but now nothing happens. Is the item correct?
Not that I needs it but it is somewhat annoying none the less…
OH1 *.items
Contact livingRoomSmoke_tamper "Smoke Detector Tamper trigger [%s]" <fire> (GF_Living) { zwave="13:0:command=sensor_alarm,alarm_type=0" }
OH2 *.items
Contact FGSS001_1_alTamp "FGSS001_1 - Tamperig Alarm [%s]" <contact> (stat) { channel="zwave:device:15912e68c95:node13:alarm_general" }
jaydee73
(Stefan)
December 30, 2016, 10:06pm
2
No, the item isn’t correct. In OH2 alarm_general is a SWITCH type, not a CONTACT.
Now I’m a bit confused.
Running it as a switch type works. Thx jaydee.
Has this changed from OH1 to OH2? I ran it as a contact in OH1 and that worked there…
What about smoke and heat. Should they also be switch type?
Contact FGSS001_1_alSmoke "FGSS001_1 - Smoke Alarm [%s]" <contact> (stat) { channel="zwave:device:15912e68c95:node13:alarm_smoke" }
Switch FGSS001_1_alTamp "FGSS001_1 - Tampering Alarm [%s]" <contact> (stat) { channel="zwave:device:15912e68c95:node13:alarm_general" }
Contact FGSS001_1_alHeat "FGSS001_1 - Heat Alarm [%s]" <contact> (stat) { channel="zwave:device:15912e68c95:node13:alarm_heat" }
In general, how do I know if it should be a switch or a contact type in OH2? Can I see that in HABmin?
jaydee73
(Stefan)
January 2, 2017, 3:42pm
4
Yes, this has changed and yes, smoke and heat are also SWITCH types now.
You can see all types of all zwave related channels in Chris’ database:
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/openhab-2-channel-types
Euphi
(Ian Hubbertz)
January 13, 2017, 11:46pm
5
Is there a reason for the change to Switch?
Can I map a Switch to a Contact or is it possible to render a Switch in BasicUI as a contact?
I mean, it does not make sense to set a Smoke Alarm (or Tamper alarm) to a value, so it really should be “read-only”.
jaydee73
(Stefan)
January 14, 2017, 9:27am
6
No, as Contact is no valid element type for sitemaps. See here:
http://docs.openhab.org/configuration/sitemaps.html
But you can map the Switch to a text item (that’s what I did). So it is read-only. And if you need some mapping to make it a little prettier, you can easily do the mapping in your Switch item definition and then display the whole item as a text item in your sitemap.
