It’s branded as AirconWithMe and listens on port 80, but under the hood and according to their support it’s an Intesis device. Initially, it also communicated with (among others) the Intesis servers. The vendor appears to be Spanish and the client app still relies on the cloud based control. I’ve blocked all that at network level and only use OH to control it, but that’s how it used to work. The port you mentioned is closed, but even nmap (well, the OUI database) agrees that it’s an Intesis device.
PORT STATE SERVICE
3310/tcp closed dyna-access
MAC Address: CC:3F:1D:01:35:68 (Intesis Software SL)
Here’s the info from the (now available) HTTP interface:
|Device Model|MH-AC-WIFI-1|
|Device Firmware Version|1.3.1; 1.2.0; 1.3; 1.0.0.9|
|Wireless Firmware Version|1.2.0|
MH stands for Mitsubishy Heavy Industries (as opposed to Mitsubishi Electric, another section of the company). Unfortunately, I’m not quite sure what kind of microcontroller is embedded in the unit. I’ll see whether I can crack it open tomorrow. I’m betting it’s either an ESP8xxx or something very similar - after all it just does Wifi w/ HTTP and some GPIO for the bus.
Also just came across this, which appears to be exactly my unit:
This is the brand I have though: https://www.airconwithme.com/
I didn’t actually get much time to pick a controller as the originally intended AC technician pulled a no-show after I bought the house and I needed it up and running before moving the server room (you’re legally obliged to have AC installed by a certified technician in the Netherlands due to insurance technicalities). This was apparently “what they always provide for network based control”. I figured for ~70 euros, on top of the cost of the split unit, it was worth a shot before I got down and dirty with the control bus. Ended up not needing to do that and solved it all at software/network level. Guess I was lucky…
Depending on the chip inside I might be able to dump the ROM, but I don’t know whether you want to blindly attempt a re-flash of your own unit. I’m pretty sure that’s not covered by warranty, hehe.
Let me know how the gateway thingy works out. What I saw back then was that they only did 1-way communication with the unit, i.e. fire-and-forget iR blasting. If that’s the approach, you might as well build it yourself and have the controller do exactly what you want it to if you ask me…
Cheers,
PelliX
