until now I had openHab 1 with Aotec Usb gen 5 and sensative strip configured. Everything was working fine. I’m trying to upgrade to version 2 and I have a problem. It looks like there are no events coming from the sensative strip. The events log is empty. But if I switch logging to debug I actually see that there are messages coming from the device to openhab. Is anyone able to point me to what is not working?
2017-02-23 06:13:34.318 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2017-02-23 06:13:34.496 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2017-02-23 06:13:34.527 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2017-02-23 06:13:34.529 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2017-02-23 06:13:34.569 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2017-02-23 06:13:34.571 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2017-02-23 06:13:36.861 [WARN ] [e.sshd.server.channel.ChannelSession] - Unknown pty opcode value: 42
2017-02-23 06:13:37.863 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2017-02-23 06:13:37.867 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 2: Node found
2017-02-23 06:13:37.871 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2017-02-23 06:13:37.873 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2017-02-23 06:13:37.877 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2017-02-23 06:13:37.880 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 2
2017-02-23 06:13:37.883 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2017-02-23 06:13:41.192 [WARN ] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Initialising Thing Node...
2017-02-23 06:18:46.173 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 02 03 30 03 FF 3F
2017-02-23 06:18:46.184 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-02-23 06:18:46.192 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 02 03 30 03 FF 3F
2017-02-23 06:18:46.196 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 02 03 30 03 FF 3F
2017-02-23 06:18:46.199 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 02 03 3$
2017-02-23 06:18:46.205 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Application Command Request (INITIALIZING:WAIT)
2017-02-23 06:18:46.207 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Node is ALIVE. Init stage is WAIT.
2017-02-23 06:18:46.210 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveNodeStatusEvent
2017-02-23 06:18:46.213 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node Status event during initialisation - Node is ALIVE
2017-02-23 06:18:46.215 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer - WAIT: queue length(0), free to send(true)
2017-02-23 06:18:46.217 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: loop - WAIT try 1: stageAdvanced(false)
2017-02-23 06:18:46.219 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: WAIT - Listening=false, FrequentlyListening=false
2017-02-23 06:18:46.221 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: WAIT - Still waiting!
2017-02-23 06:18:46.223 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2017-02-23 06:18:46.225 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Setting ONLINE
2017-02-23 06:18:46.228 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 2: Node Status event - Node is ALIVE
2017-02-23 06:18:46.232 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Incoming command class SENSOR_BINARY
2017-02-23 06:18:46.235 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 2: Received SENSOR_BINARY command V1
2017-02-23 06:18:46.239 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 2: Sensor Binary report, type=Unknown, value=255
2017-02-23 06:18:46.241 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveBinarySensorValueEvent
2017-02-23 06:18:46.242 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2017-02-23 06:18:46.243 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_BINARY, value = 255
2017-02-23 06:18:46.247 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 255: Transaction not completed: node address inconsistent. lastSent=255, incoming=255
2017-02-23 06:18:49.162 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 02 03 30 03 00 C0
2017-02-23 06:18:49.166 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2017-02-23 06:18:49.169 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 02 03 30 03 00 C0
2017-02-23 06:18:49.171 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 02 03 30 03 00 C0
2017-02-23 06:18:49.173 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 02 03 3$
2017-02-23 06:18:49.174 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Application Command Request (ALIVE:WAIT)
2017-02-23 06:18:49.176 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 2: Incoming command class SENSOR_BINARY
2017-02-23 06:18:49.177 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 2: Received SENSOR_BINARY command V1
2017-02-23 06:18:49.178 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 2: Sensor Binary report, type=Unknown, value=0
2017-02-23 06:18:49.179 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveBinarySensorValueEvent
2017-02-23 06:18:49.180 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2017-02-23 06:18:49.181 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_BINARY, value = 0
2017-02-23 06:18:49.183 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 255: Transaction not completed: node address inconsistent. lastSent=255, incoming=255
